Gatucker 0 #1 Posted 15 hours ago I have a 656 and the shifter will move through the neutral gate but will not go in any gear. tractor will not roll forewarn or backward. If I lift the rear the wheels will turn in opposite directions. what might be the problem. Share this post Link to post Share on other sites
ri702bill 11,868 #2 Posted 14 hours ago Welcome!! Is it stuck in two gears at the same time?? It can happen, particurly with the early Unidrives (it was addressed in later versions). Do a search in the "Transmissions" section for that issue. It is able to be corrected but requires removing the shifter to realign the forks. 2 Share this post Link to post Share on other sites
953 nut 65,270 #3 Posted 13 hours ago Read through this thread, should solve your problem. 1 1 Share this post Link to post Share on other sites
kpinnc 17,914 #5 Posted 9 hours ago 5 hours ago, Gatucker said: have a 656 Concord NC? You're just 20 minutes away. Nice to see another local member. Welcome to the sickness! 1 Share this post Link to post Share on other sites
