Gatucker 0 #1 Posted April 26 I have a 656 and the shifter will move through the neutral gate but will not go in any gear. tractor will not roll forewarn or backward. If I lift the rear the wheels will turn in opposite directions. what might be the problem. Share this post Link to post Share on other sites
ri702bill 13,392 #2 Posted April 26 Welcome!! Is it stuck in two gears at the same time?? It can happen, particurly with the early Unidrives (it was addressed in later versions). Do a search in the "Transmissions" section for that issue. It is able to be corrected but requires removing the shifter to realign the forks. 2 Share this post Link to post Share on other sites
953 nut 70,649 #3 Posted April 26 Read through this thread, should solve your problem. 1 1 Share this post Link to post Share on other sites
kpinnc 19,107 #5 Posted April 27 5 hours ago, Gatucker said: have a 656 Concord NC? You're just 20 minutes away. Nice to see another local member. Welcome to the sickness! 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,557 #6 Posted April 27 Once the shifter is out make sure the donut is secured to the shifter. Some are welded and not a problem. Others are retained by a roll pin that shares the hole with the dog point set screw. The pin can shear and allow the donut to rotate which hinders gear selection. 2 Share this post Link to post Share on other sites
