Skwerl58 843 #1 Posted April 21 I rewired my 1054 to "Solenoid Ignition" 3 years ago. I went to start it and the electric fuel pump kicks on but no go on the starter generator. I checked the solenoid and finally jumped it and it fired right up. I went and picked up a new Rotary solenoid and installed it and have the same problem. No starting but can hear the fuel pump running. Anyone have any idea where I should do next to try to get it going. I have checked connections, cleaned key switch, just looking for some help. Thanks! 1 Share this post Link to post Share on other sites
ri702bill 13,060 #2 Posted April 21 Check for power at the small solenoid wire with the key in the "start" position. Are you using a 3 or 4 terminal solenoid?? A 3 terminal grounds thru the mounting bracket, a 4 terminal requires one of the small terminals to be grounded to complete the "pull in" circuit... 2 Share this post Link to post Share on other sites
Skwerl58 843 #3 Posted April 21 The small terminal wire goes to the switch. Like previously wired, 2 large terminals and the smaller terminal Share this post Link to post Share on other sites
ineedanother 2,864 #4 Posted April 21 You're either not getting 12v from the switch to the small terminal when you turn the key to start, or your solenoid isn't grounded (or you have a bad solenoid). 2 Share this post Link to post Share on other sites
953 nut 69,298 #5 Posted April 21 When you did the rewire did you put in any fuses? Could be a bad fuse. Your wiring should look like this. Share this post Link to post Share on other sites
Skwerl58 843 #6 Posted April 21 953 nut that is the diagram I used. I did install a fuse and it is good. Will re check grounding and make certain of voltage on the small wire. If these check out will try to swap out another solenoid. 1 Share this post Link to post Share on other sites
Skwerl58 843 #7 Posted April 22 I have cleaned grounds and checked voltage at the small wire which is 12.3 and no click or anything. It seems odd to me that my old solenoid and a new do the same thing but that is what makes them faulty. Just thinking out loud but would the ignition switch be part of the issue or no since voltage does reach the small wire while turning the key. Could it be another circuit from the switch 1 Share this post Link to post Share on other sites
pfrederi 21,150 #8 Posted April 22 Run a temp jumper from Batt + to the small solenoid terminal...does it work then. maybe sufficient resistance in the ignition switch to prevent enough juice getting to the solenoid to trigger it. 2 Share this post Link to post Share on other sites
Skwerl58 843 #9 Posted April 22 Pfrederi Thanks for the tip. I tried it and no response from the solenoid. My local parts store has ordered a replacement for this one. I just hope it fires right up after replacing it. Interesting that they did not question it, may be common for new parts Share this post Link to post Share on other sites
squonk 48,123 #10 Posted April 22 5 hours ago, Skwerl58 said: I have cleaned grounds and checked voltage at the small wire which is 12.3 and no click or anything. It seems odd to me that my old solenoid and a new do the same thing but that is what makes them faulty. Just thinking out loud but would the ignition switch be part of the issue or no since voltage does reach the small wire while turning the key. Could it be another circuit from the switch Did you clean where that solenoid is mounted? Where did you mount it anyway. Perhaps what it's mounted to isn't grounded. Share this post Link to post Share on other sites
Skwerl58 843 #11 Posted April 22 I mounted it to the steel dash using the original push button mounting holes. I cleaned, sanded off paint and still same. Share this post Link to post Share on other sites
squonk 48,123 #12 Posted April 22 1 hour ago, Skwerl58 said: I mounted it to the steel dash using the original push button mounting holes. I cleaned, sanded off paint and still same. Make sure the dash is actually grounded well. I have seen throttle and choke cables melt during starting because of bad grounding. 1 2 Share this post Link to post Share on other sites
953 nut 69,298 #13 Posted April 22 3 hours ago, Skwerl58 said: I mounted it to the steel dash using the original push button mounting holes. I cleaned, sanded off paint and still same. I prefer mounting the solenoid directly to the engine near the S/G. You can get the heavy cables out from under the dashboard to a safer location that way. 2 Share this post Link to post Share on other sites
Skwerl58 843 #14 Posted April 23 I do understand grounds need to be good but some things just leave me scratching my head! I installed the new solenoid today after I decided to make 100% sure of ground. I had used this system for 3 years with no issues and this week cleaned all contact points, dash plate screws and triple checked all wiring. Still nothing so I made a mounting bracket and attached it to the engine block. Mounted the solenoid so it is above and behind the starter generator. Rewired, extended a couple of wires, turned the key and it fired right up. Moral of this story is grounds are quirky and if it worked yesterday doesn't mean it will today. Thanks for the suggestions and help. Great group to work with!! 1 Share this post Link to post Share on other sites
squonk 48,123 #15 Posted April 23 Knew it was a ground issue. 1 Share this post Link to post Share on other sites
pfrederi 21,150 #16 Posted April 24 You can trust your mother but not your ground.... Share this post Link to post Share on other sites
sqrlgtr 3,930 #17 Posted April 24 (edited) The grounding is the first thing I look at when running into mystery electrical issue's, 90% of the time that's what it turns out to be, a bad ground . Edited April 24 by sqrlgtr Share this post Link to post Share on other sites
