RBM 14 #1 Posted April 21 Hello...I want to put shell rotella t6 5w-40 in my kohler k301? I just have seen people do this before...Will this better the engines lubrication system? Is it good insurance? What are your thoughts? Thank You. 1 Share this post Link to post Share on other sites
Darb1964 1,174 #2 Posted April 21 I have used 15w-40 in some of my kohler in the summer and they seemed to do fine with it. 3 Share this post Link to post Share on other sites
953 nut 69,724 #3 Posted April 21 Your engine is splash lubricated with relatively wide clearances when compared to a modern automotive pressure lubricated engine, I would go with 30 as stated in the engine manual. 5 4 1 Share this post Link to post Share on other sites
clueless 3,439 #4 Posted April 21 T-6 is not going to do anything better for you engine than T-1 (30w) or T-2 (40w). Full Syn and Blends in these old loose tolerance dirty port engines just burn off some of it after a couple of hours of use. Rotella T-6 is expensive overkill for these old flatheads. 2 3 Share this post Link to post Share on other sites
oldlineman 1,814 #5 Posted April 21 I have used Rotella T1 30w for years, summer and winter without any problems. IMHO it is the best oil for these older engines that is made. Bob 9 Share this post Link to post Share on other sites
8ntruck 9,328 #6 Posted April 21 I believe that the Rotella T1 was originally developed for use in diesel engines. It has a better extreme pressure additive package suitable for the higher bearing loads in compression ignition engines. When used in our antique Kohlers, and Onans, that same extreme pressure package helps protect our journal type crank and rod bearings and the non roller lifters and cam shaft. These surfaces have largely sliding type of friction. The current automotive engine oils are designed for tighter crank and rod bearings clearances - often with special coatings - and roller lifters running on the cam. All of these features are efforts to reduce friction and increase fuel efficiency, which, was not a concern when our antiques were designed and built. 4 2 Share this post Link to post Share on other sites
JoeM 10,316 #7 Posted April 21 I use 5w-40 diesel oil in just about everything, one real advantage is the synthetic oils ability to transfer heat. And of course we are talking about air cooled engines. That oil is top of the line and will out preform just about anything out there. Most thoughts are built on old school thinking and not science. Part of my old job was closely tied to lubrication and we had a lot of sensors gathering data around the clock. Synthetic oils lowered internal temps up to 20%, at the first oil change. You have to remember those old service manuals were written over 30 years ago. Oil has come a long way since then, and if you want to use it, It will be fine. 3 1 Share this post Link to post Share on other sites
rick 318 #8 Posted April 21 Does the Rotella T-1 have more zinc additive than normal 30wt oil? 1 Share this post Link to post Share on other sites
RBM 14 #10 Posted April 21 I have about 4qts of this oil...Is it fine to use will it damage anything or is it just unnecessary? Thank you. 1 Share this post Link to post Share on other sites
ri702bill 13,162 #11 Posted April 21 4 hours ago, 8ntruck said: The current automotive engine oils are designed for tighter crank and rod bearings clearances - often with special coatings - and roller lifters running on the cam. All of these features are efforts to reduce friction and increase fuel efficiency, which, was not a concern when our antiques were designed and built. And their severe duty flat tappet ZDDP Zinc is 5% of what it was - due to the Zinc clogging catalytic converters. That is why modern car engines use roller lifters - no more flat tappets. Rotella still has a reasonable amount of zinc in it. Not recommended - using just modern multiweight motor oil alone. You CAN use it with a rather expensive zinc supplement added to it. Better off just to buy the conventional (not full synthetic) Rotella. TSC - $16 a gallon..... 4 1 Share this post Link to post Share on other sites
JoeM 10,316 #12 Posted April 22 17 hours ago, rick said: Does the Rotella T-1 have more zinc additive than normal 30wt oil? T-1 has about 1000 ppm zinc T-6 is >1100 ppm zinc Modern motor oils, for gas engines, used today have around 700 ppm Racing oils 1600 Break in oils >2000 Don't get caught up in the more is better thing. Zinc alone is destructive additive and should be used in conjunction with other chemicals to form the proper blend. Personally, I would never add anything to my oils. I would, like you are doing, get a good fit. If you really want to insure you have the best oil, Kohler sells motor oil that is to their spec with all the right additives and blends. 2 1 Share this post Link to post Share on other sites
rick 318 #13 Posted April 22 I've been using Schaeffer's 7000 30wt. in my iron Kohler engines. 2 Share this post Link to post Share on other sites
Retired Wrencher 6,993 #14 Posted April 24 I use a when I change the oil. It helps the tappets. 1 Share this post Link to post Share on other sites
clueless 3,439 #15 Posted April 24 (edited) On 4/21/2026 at 1:35 PM, RBM said: I have about 4qts of this oil...Is it fine to use will it damage anything or is it just unnecessary? Thank you. If you got it use it, it's still good lubricant just expensive and over kill for your engine, I would still change it at 25 hours, then just use T-1 or T-2. Edited April 24 by clueless 1 1 Share this post Link to post Share on other sites
peter lena 10,082 #16 Posted April 24 @Retired Wrencher been using that rislone zinc for for years , 4 oz per 2 qts of oil , bottle specs , often refer to it for smoking engines ? its VARNISH CUTTING ABILITY IS AMAZING , would pick up a used neglected engine , smoking , rough , run it in on a seperate gallon of heavily treated fresh fuel ? cleaned fuel bowl , STA BIL IN THE GAS . START THE IMEDIATE REVERSAL OF FUEL HOSE BREAK DOWN .while slowly recovering engine function . detail in carb , and related linkage function , usually a rusted / neglected mess . choke and related throttle, plate barely move , its amazing to me how close , original set ups were , verifying insuring areas , make them work with ease . just started up my , 1982 ,c 85 , swapped in a 12 magnum years back , still my favorite unit , also my test bed for a lot of ideas , pete 1 Share this post Link to post Share on other sites
sqrlgtr 4,077 #17 Posted April 24 Valvoline has a "racing oil" that has a 1200 to 1400 zinc count also. 2 Share this post Link to post Share on other sites
Retired Wrencher 6,993 #18 Posted April 25 21 hours ago, peter lena said: @Retired Wrencher been using that rislone zinc for for years , 4 oz per 2 qts of oil , bottle specs , often refer to it for smoking engines ? its VARNISH CUTTING ABILITY IS AMAZING , would pick up a used neglected engine , smoking , rough , run it in on a seperate gallon of heavily treated fresh fuel ? cleaned fuel bowl , STA BIL IN THE GAS . START THE IMEDIATE REVERSAL OF FUEL HOSE BREAK DOWN .while slowly recovering engine function . detail in carb , and related linkage function , usually a rusted / neglected mess . choke and related throttle, plate barely move , its amazing to me how close , original set ups were , verifying insuring areas , make them work with ease . just started up my , 1982 ,c 85 , swapped in a 12 magnum years back , still my favorite unit , also my test bed for a lot of ideas , pete Well Pete you told me about it so now I always have some in the oil lubes and what ever else box. 1 Share this post Link to post Share on other sites
peter lena 10,082 #19 Posted April 25 @Retired Wrencher thank you for the reply , regularly read about a lot of areas , that I experimented with , ( repetitive problem ) love those ? more often than not , it was the original build set up , on a production line , they were in a hurry , I AM NOT , the quality of another era made them survive , my original c-85 , was my test bed , for anything , similar / yet different , on my other horses , none of my engines , smoke or blow oil , transmissions , regularly , checked , clean / clear , that fuel hose issue , DISSAPEARED WITH STABIL , started at tank flushing , all new lines , never a speck of anything in filters , went on to carb , functional detailing , another , GOLD MINE of small issues , eliminated . as a long retired millwright , I just look at any problem differently , cleaning out a wide rubber side shield bearing, carb cleaner flush , LUCAS X-TRA HD , green chassis grease , never had a failure or whining noise , 3 tractors set up the same way , solid / reliable , coming to the end , pete Share this post Link to post Share on other sites
