FLtractor 157 #1 Posted 6 hours ago Evening, Is this supposed to be removed by thumb and hand motion? Just lubricant it? Or some kind of wrench or tools? Share this post Link to post Share on other sites
rmaynard 17,087 #2 Posted 6 hours ago (edited) Just use pliers on it. It will come off. Be careful not to use pliers on the front or it will scar it a bit. Sometimes it's easier if you remove the four screws hold the dash panel on. You will get more maneuverability Edited 6 hours ago by rmaynard Share this post Link to post Share on other sites
Ed Kennell 45,634 #3 Posted 2 hours ago 3 hours ago, rmaynard said: Be careful not to use pliers on the front or it will scar it a bit. If you need to hold the front with pliers, wrap it with several layers of duct tape ti prevent damage. Share this post Link to post Share on other sites
FLtractor 157 #4 Posted 2 hours ago 3 hours ago, rmaynard said: Just use pliers on it. It will come off. Be careful not to use pliers on the front or it will scar it a bit. Sometimes it's easier if you remove the four screws hold the dash panel on. You will get more maneuverability Thank you. Share this post Link to post Share on other sites
FLtractor 157 #5 Posted 2 hours ago 8 minutes ago, Ed Kennell said: If you need to hold the front with pliers, wrap it with several layers of duct tape ti prevent damage. Thank you Share this post Link to post Share on other sites
