FLtractor
856: voltage regulator wiring question.
FLtractor
Afternoon,
Based on 856 wiring diagram .. the middle voltage regulator wire.. to make sure I read the diagram correctly … the middle voltage regulator wire… goes to the positive battery terminal then the positive battery terminal goes to the B on ignition.. is this correct way or do I wire the voltage regulator middle wire directly to ignition Battery terminal?
Edited by FLtractor
pfrederi
12/14ga wire Center regulator terminal to the Battery +
4/6ga wire Battery Plus to B terminal on ignition switch
You need to seriously clean up regulator terminals
Handy Don
And any other connections in similar condition. It doesn’t take a lot of rust to seriously impede the flow of those poor little electrons trying to do their job!
pfrederi
My answer above assumes this is an original 4 terminal regulator.  You really should  clean the terminal and make sure it says BAT not GEN...On 3 wire regulators the  center  terminal is GEN and goes to the A terminal on the genny.
  • Excellent 2
squonk
While you cleaning up the regulator. Repair that connection on that new switch!
Edited by squonk
FLtractor
Battery plus - you mean positive battery terminal to ignition?
Some light 220 grit sand paper the terminal to clean up the rust?
FLtractor
Where would the words BAT and Gen be.. on the circled pieces?
when you say center terminal GEN.. where is the A terminal on generator that that connects to?
FLtractor
Which connection repair? This one ?
pfrederi
The marks are stamped into the regulator terminal.  Wire brush?  As rusty as the one is it may have corroded the stamping away.  Is yours a 3 or 4 terminal regulator (the 4th terminal is on the bottom if it is a 4  term and a light wire runs from it to the A terminal on the Generator body
Heavy 4/6 ga wire Battery + terminal to the Ignition switch.
There are two terminals on the generator body and there is a stampd letter next to them an A which has two wires one light one heavy and and F one wire from the F terminal on the regulator
Edited by pfrederi
pfrederi
 There are normally only two wires here I assume the new red one is for the fuel pump you are installing and is not the new red one in the regulator picture that would be wrong.
squonk
Yes. Those wire connections are junk. Dirty, exposed wires. Bent almost 90°. All of that makes heat. The only one that looks like it might be ok ok is the main red wire with the yellow connector.
FLtractor
Only see 3 terminals on voltage regulator.
light wire as in for headlights ?
FLtractor
The old red wire is coil to I on ignition.
new wire is fuel pump to I on ignition.
Old black wire is to the jewel generator Warning 856 dash- to the I on ignition.
Edited by FLtractor
pfrederi
If the bare rusty terminal cleans up to show "L" Then you have a 4 terminal system.  AGAIN... is there a terminal and wire coming out the bottom of your regulator????
When i say light I mean light gauge wire...
Where does the new red wire with yellow crimp terminate on your regulator go.
Look I am getting old an I try to use a variety of wire colors makes tracing things  much easier.... not all red
Edited by pfrederi
FLtractor
Don’t see any L…
the new red wire with yellow on middle voltage regulator.. goes from there to battery + on battery itself .. then the battery wire to the B on ignition.
there is this wire underneath my voltage regulator.. see picture.. which I think goes to the starter gen nut terminal on top of the starter .as seen in my 2nd picture here .:  .. does that mean it’s a 4 terminal? If so.. what exactly do all the terminals .. 3 on front where red middle wire do and are for exactly?
Edited by FLtractor
702854boy
You might not want to work on my tractors, I use all black except for the positive battery cables, granted black is all I have to work with at the moment so that also plays a part
  • Haha 1
953 nut
Makes troublesooting soooooooooooo easy, the problem is the BLACK wire,       can't go wrong.            :ychain:
  • Haha 3
pfrederi
2 hours ago, FLtractor said:
Don’t see any L…
  you have a 4 terminal regulator.  From the top of this picture .."F"  Field  wire goes to the F terminal on the generator body  Center is Battery goes to the Positive (+) terminal on the battery , Bottom rusty one is the L load terminal (could power your cigar lighter). The wire coming out from under neath goes to the Genny A terminal. If you cleanup the Generator body you will see the stamped F and A marking the two terminals.  A has the heavy and light wire.
as mentioned above you really need to clean things up.  Makes wiring easier.
Edited by pfrederi
702854boy
It looks like you might need to redo the bottom wire on your regulator
squonk
I had to do some electrical work on a new motor home that was a prototype of Winnebago's new design. Every wire behind the dash was white!
  • Heart 1
FLtractor
So is F the wire here I circled- that goes to top or leftest terminal voltage regulator.
The wire underneath- that goes to generator- does that power the voltage regulator?
FLtractor
It appears I should
