Jayoutdoors 107 #1 Posted April 19 i know its probably been asked a million times. but i cant find it in here. anyone got a part number for the rubber or a fix to get rid of it? 1 Share this post Link to post Share on other sites
ineedanother 2,866 #2 Posted April 19 @Jayoutdoors - https://wheelhorsepartsandmore.com/product-category/fuel/ Share this post Link to post Share on other sites
ebinmaine 80,717 #3 Posted April 19 I get ours from Aircraft Spruce & Specialty. They have several types of valves, grommets, and the good quality electric fuel pumps available. Pricing is excellent. Service as well. 7 Share this post Link to post Share on other sites
peter lena 10,065 #5 Posted April 19 @Jayoutdoors do your self a favor , get some dielectric grease , small tube , makes that replacement easy simple , the rubber slide difference is amazing , also added a fuel filter at each end to carb along with a fuel check valve just before carb ? holds fuel up to carb for quicker starts , pete 1 Share this post Link to post Share on other sites
sqrlgtr 3,932 #6 Posted April 19 2 hours ago, peter lena said: do your self a favor , get some dielectric grease makes it so much easier. 1 Share this post Link to post Share on other sites
WHX?? 58,143 #7 Posted April 20 They are pretty common and yes greasy pete knows. https://www.amazon.com/dp/B0DM19STMB?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_1&th=1 1 Share this post Link to post Share on other sites
peter lena 10,065 #8 Posted April 20 @WHX?? see the opportunity with a tank clean and valve replacement ? repetitive rubber hose break down debris ? know its a very touchy subject , its always there , been using STA BIL to all my fuel for years , guess what ? starting with new hose throughout , thats another opportunity , I have had zero / none , fuel hose debris in any filter or fuel bowl , imagine that issue going away ? always add an ounce or two , to EVERY TANK TOP OFF , regularly suggest , using a 5/16 steel brake line , inside frame length , upper inside corner , eliminate hose issue , clear line to carb ? fuel check valve , verifying fuel hold to carb , love breaking down a REPEDITIVE PROBLEM , regularly experiment , very often , its a simple ENHANCEMENT TO ORIGINAL SET UP , realise , to the purest , this simply cannot be done . my stuff looks the same , but functions with ease , pete Share this post Link to post Share on other sites
AlexR 3,115 #9 Posted April 23 On 4/19/2026 at 12:09 PM, ebinmaine said: I get ours from Aircraft Spruce & Specialty. They have several types of valves, grommets, and the good quality electric fuel pumps available. Pricing is excellent. Service as well. This!! The prices are cheap, I think shipping is a little bit. But just get a bunch of them! 1 1 Share this post Link to post Share on other sites
peter lena 10,065 #10 Posted April 23 @ AlexR , most of my changes are based on REPEDITIVE FAILURE , very often just a re route , or lubrication based EASE OF MOVEMENT , been doing that for so long . its just the next step for me . often refer to , roller stool look around ? that comfortable sitting ease , lets me think and watch , plan a WHAT IF ? trial , think that shoulder bolt , for movement ease , and washer fill in , with an elastic Lok nut , is a game changer , on plow lever set ups . you dial in the perfect swing point , lubricate that , and lok nut , that setting . my lubricated , swing quadrant , sounds like a lubricated rifle bolt . it was always hiding in plane site . pete 1 Share this post Link to post Share on other sites
nyquil junkie 333 #11 Posted May 20 I freely admit the 12 yr old boy in me read the topic title and choked back a laugh and blew coffee out of my nose. I apologize. 1 3 Share this post Link to post Share on other sites
wallfish 20,618 #12 Posted May 20 1 hour ago, nyquil junkie said: I freely admit the 12 yr old boy in me read the topic title and choked back a laugh and blew coffee out of my nose. I apologize. No need to apologize except for the fact that you beat me to it! LOL 2 1 Share this post Link to post Share on other sites
