Raider69 125 #1 Posted April 19 Does anyone know if there's a height difference between a K series that bolts directly to the frame and a cradle mount K series? I'm repowering a '68 Raider 9 with a K341AQS out of a JD using the pan and cradle mount from a C series WH. I'm also repowering my '75 B100 with a K301AQS out of a JD using the same style C series pan and cradle mount. Just wondering if I may run into hood clearance issues. TIA. Share this post Link to post Share on other sites
953 nut 69,303 #2 Posted April 19 I am reasonably sure the center line of the crankshaft will be the same as your Tecumseh. Wheel horse made the cradle mount to compensate for the crankshaft height to be the same as the standard oil pan Kohler. Those issues were all covered in this thread. 3 Share this post Link to post Share on other sites
ebinmaine 80,695 #3 Posted April 19 47 minutes ago, 953 nut said: I am reasonably sure the center line of the crankshaft will be the same as your Tecumseh I'd agree with that based on the 1974 C160-8 Tecumseh / Kohler belt guard being interchangeable. 1 Share this post Link to post Share on other sites
pfrederi 21,150 #4 Posted April 19 (edited) Here is a shaker mount K bolted direct to frame. Spacers are the same ones used in a 8hp shaker mount plus 3 washers... No belt guard mods needed Edited April 19 by pfrederi 7 Share this post Link to post Share on other sites
953 nut 69,303 #5 Posted April 19 (edited) 2 hours ago, ebinmaine said: I'd agree with that based on the 1974 C160-8 Tecumseh / Kohler belt guard being interchangeable. Looked into this a bit further. Acording to our friends on AI all Kohler 241,301, 321, and 341 have the same crankshaft center line but the HH100 Tecumeh is about 2 1/2" shorter. The Ponds were nororiouslt thrifty so the Tecumseh was on a mounting riser to make it work with the same belt guard as shown below. But, since he has a K-301 on the B-100 now I'm rather sure the cradle will work out foe that one too. For 10-16 HP Kohler K-Series engines (K241, K301, K321, K341), the centerline of the crankshaft to the mounting base (deck height) is typically 8.625 inches. This dimension is consistent across the 10-16 HP cast iron block series, facilitating interchangeability. The factory crankshaft centerline distance from the base of the engine (mounting plate) for a Tecumseh HH100 is typically 6.125 inches. well, the site won't let me add the drawing with the engine riser here so I will do another thread. OK, It let me edit the post with the drawing. Edited April 19 by 953 nut 1 1 Share this post Link to post Share on other sites
Raider69 125 #6 Posted April 20 Thanks for the responses everyone, they've all been VERY helpful! 21 hours ago, pfrederi said: Here is a shaker mount K bolted direct to frame. Spacers are the same ones used in a 8hp shaker mount plus 3 washers... No belt guard mods needed So, since I'm using this same pan on both engines I don't need the cradles? 20 hours ago, 953 nut said: Looked into this a bit further. Acording to our friends on AI all Kohler 241,301, 321, and 341 have the same crankshaft center line but the HH100 Tecumeh is about 2 1/2" shorter. The Ponds were nororiouslt thrifty so the Tecumseh was on a mounting riser to make it work with the same belt guard as shown below. But, since he has a K-301 on the B-100 now I'm rather sure the cradle will work out foe that one too. For 10-16 HP Kohler K-Series engines (K241, K301, K321, K341), the centerline of the crankshaft to the mounting base (deck height) is typically 8.625 inches. This dimension is consistent across the 10-16 HP cast iron block series, facilitating interchangeability. The factory crankshaft centerline distance from the base of the engine (mounting plate) for a Tecumseh HH100 is typically 6.125 inches. well, the site won't let me add the drawing with the engine riser here so I will do another thread. OK, It let me edit the post with the drawing. The HH100 out of my Raider is long gone but I do remember that riser plate now that I see the diagram. I'm not sure if I still have it or not. I was going to put an HH120 back in it until I realized Tecumseh engines and I don't pay well together. I also think I may have a belt guard out of a roached '68 Electro 12 I parted out years ago. A friend has an Electro 12 so I gave him the carcass to pick over and I don't remember what all was still on it. I would have kept it but it was in REALLY bad shape, I still have the engine though sitting next to the HH120 i'll probably never use. I'll have to dig out my parts boxes and see what I kept. 2 Share this post Link to post Share on other sites
ebinmaine 80,695 #7 Posted April 20 7 hours ago, Raider69 said: Thanks for the responses everyone, they've all been VERY helpful! So, since I'm using this same pan on both engines I don't need the cradles? IF the oil pan has the correct bolt holes in the bottom, no. 7 hours ago, Raider69 said: The HH100 out of my Raider is long gone but I do remember that riser plate now that I see the diagram. I'm not sure if I still have it or not. I was going to put an HH120 back in it until I realized Tecumseh engines and I don't pay well together. Seems a consistent theme. The overall structure of the Tecumseh engine is very good. The carburetor and ignition however, are both VERY sensitive. 7 hours ago, Raider69 said: I also think I may have a belt guard out of a roached '68 Electro 12 I parted out years ago. A friend has an Electro 12 so I gave him the carcass to pick over and I don't remember what all was still on it. I would have kept it but it was in REALLY bad shape, I still have the engine though sitting next to the HH120 i'll probably never use. I'll have to dig out my parts boxes and see what I kept. If'n you need parts lemme know. It's likely we've got a spare belt guard from that vintage long hood with a manual transmission. Share this post Link to post Share on other sites
Raider69 125 #8 Posted April 21 16 hours ago, ebinmaine said: Seems a consistent theme. The overall structure of the Tecumseh engine is very good. The carburetor and ignition however, are both VERY sensitive. I've had 3 of them let go on the bottom end with no warning. The original HH100 and 2 VH80's in my Commando V8 and CG8, all were full of clean oil. No ticking beforehand just a very loud and sudden BRRTTTT and locked up. To be fair I was plowing snow when the HH100 died but the other 2 weren't even under a load. I've had old Briggs I damn near ran out of oil that I'd top off expecting the death rattle at any minute but they just kept going for year after year after year. They smoked a bit, a couple of them a lot LOL, but I never had one let go like that. 1 Share this post Link to post Share on other sites
