markb 0 #1 Posted April 18 Does anyone know the part number or reference number and a place to get a 300 series (314H) front wheel bearings? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,485 #2 Posted April 18 Welcome to Red Square #110513 https://www.amazon.ca/Stens-215-211-Wheel-Bearing-Silver/dp/B006RYW1A0 1 Share this post Link to post Share on other sites
sqrlgtr 3,871 #4 Posted April 19 https://www.amazon.com/dp/B08HR2JNGJ?ref=ppx_yo2ov_dt_b_fed_asin_title Here is a link to some sealed bearings if you prefer them. I do . 1 Share this post Link to post Share on other sites
hotajax 284 #7 Posted April 20 So those bearings are all over ebay. Very plentiful. If you just ask for Wheel Horse front wheel bearings, most of what comes up will fit. There's a guy out there selling sealed lubricated bearings on eBay. Meaning: you don't have to lube that wheel. I think the price on ebay was around 16 bucks for those prelubed sealed bearings. I bot some cheap ones, and they fall out of the hub when you remove the wheel from the spindle. I mean they're really cheap. Share this post Link to post Share on other sites
Retired Wrencher 6,983 #8 Posted April 20 I find if you go to a bearing dealer you can get a better bearing. I am lucky enough to have two dealers in town I live in. Bearings like Timkin! This company has been in business for many years. Where I used to work, the maintenance crew guys that I knew very well always used Timpkin bearings for repairs. 1 Share this post Link to post Share on other sites
WHX?? 58,085 #9 Posted April 20 We were just discussing these. 1 Share this post Link to post Share on other sites
Racinbob 13,146 #10 Posted April 20 Been using these for quite a few years now. About $12.00/4. I can change a lot of bearings and still be ahead but I haven't had to yet. 4 Share this post Link to post Share on other sites
953 nut 69,187 #11 Posted April 20 Go ahead and buy a good quality bearing. A year from now you won't remember what it cost but if you buy the cheapest ones you will discover they weren't such a bargin when you are having to replace them. 2 Share this post Link to post Share on other sites
cleat 9,325 #12 Posted April 20 17 minutes ago, 953 nut said: Go ahead and buy a good quality bearing. A year from now you won't remember what it cost but if you buy the cheapest ones you will discover they weren't such a bargin when you are having to replace them. Especially if you end up damaging the spindle or wheel when a cheap bearing fails. 2 Share this post Link to post Share on other sites
WHX?? 58,085 #13 Posted April 20 34 minutes ago, 953 nut said: a good quality bearing. I've looked and looked for high speed or precision bearings as their called but yet to find any in flanged 1 3/8 x 3/4. Not sure if they are even worth it anymore Richard. All I know now is if they are advertised as wheel barrow bearings I stay away. 1 Share this post Link to post Share on other sites
cleat 9,325 #14 Posted April 20 What I have found is that if they at least look like a machined vs stamped bearing and have seals then they seem to work and last. If you get the cheap ones that are obviously just stamped out then not only do they not last or roll properly but they are often looser than a well worn machined bearing. I like to have a seal on at least the outboard side of the bearing to keep out dirt and water and keep the Grease in. Share this post Link to post Share on other sites
