nyquil junkie 239 #1 Posted 7 hours ago I just won 2 wheelhorse 312s on a local online auction.... why did I do that? A WH 312-A and an 312 Hydro. I'll pick them up tomorrow. One runs, one doesn't. The hydro has a plow. I hope there are some manuals here for those. Still not sure why I did that. 5 2 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,110 #2 Posted 6 hours ago There are 3 models of each so post the model numbers and serial numbers when you get them. If not possible the engine spec number and engine serial number will help with identifiation. 2 Share this post Link to post Share on other sites
nyquil junkie 239 #3 Posted 6 hours ago Will do thanks. 1 Share this post Link to post Share on other sites
ebinmaine 78,110 #4 Posted 6 hours ago 21 minutes ago, nyquil junkie said: 312 Hydro One of the best, most simple, and most rugged workers there. 1 Share this post Link to post Share on other sites
nyquil junkie 239 #5 Posted 6 hours ago Oh the non running one is a 314-A, made a mistake there. Dunno if it runs but it has a good seat and 4 shiny chrome hubcaps... surely that was worth my 40 bucks. 1 1 Share this post Link to post Share on other sites
nyquil junkie 239 #6 Posted 6 hours ago Oh here is a question... the 312 is suppose to be running, the 314 is not. I'll assume neither will run when its time to put em on the trailer... If one is an auto and one us a hydro, how do you free wheel them to push em? 1 Share this post Link to post Share on other sites
nyquil junkie 239 #7 Posted 5 hours ago Here's a few screen caps. 2 Share this post Link to post Share on other sites
953 nut 65,016 #8 Posted 5 hours ago The one with the Eaton 1100 can be pushed with no problem, The Eaton 700 well need to have the rear wheels put on a pair of dollies. Share this post Link to post Share on other sites
nyquil junkie 239 #9 Posted 5 hours ago Mmm. aint got a dolly. maybe it'll rain tonight and it'll slide in the mud when I drag it on the trailer. That sucks. 1 Share this post Link to post Share on other sites
Pullstart 69,550 #10 Posted 5 hours ago 16 minutes ago, nyquil junkie said: Mmm. aint got a dolly. maybe it'll rain tonight and it'll slide in the mud when I drag it on the trailer. That sucks. If you give it a shove in a manner that you can spin a wheel backwards, it’ll scoot right along. Put your hip into it so that backwards spinning wheel is lighter than the forward spinning wheel. 2 Share this post Link to post Share on other sites
JCM 11,070 #11 Posted 5 hours ago Am I missing something. Both the A and the 1100 are both automatics correct. My Eaton 1100's don 't push very far at all. That's what your WH Classic should be equipped with. The A has the Eaton 700. Share this post Link to post Share on other sites
WHX?? 55,925 #12 Posted 5 hours ago 7 minutes ago, JCM said: My Eaton 1100's don 't push very far at all Mine do if you go rreeeaaalll slow. They don't look the worst Junkie ... the 314-A looks like it's got dash issues. 1 Share this post Link to post Share on other sites
wallfish 19,615 #13 Posted 4 hours ago (edited) 50 minutes ago, nyquil junkie said: Mmm. aint got a dolly. maybe it'll rain tonight and it'll slide in the mud when I drag it on the trailer. That sucks. What about a hand truck and a helper? You could probably lift the rear end up with a decent hand truck and doesn't need to be 2 ft in the air. What about removing the blade from the frame and using that frame end to lift and move it? Bring a battery and some carb spray and run it like that Spit balling again to what sticks Edited 4 hours ago by wallfish Share this post Link to post Share on other sites
wallfish 19,615 #14 Posted 4 hours ago What's the possibility of using a long mower belt from the PTO of the runner connected to the trans pulley from behind? If the front one is kinda dragging the runner slightly the belt should stay tight. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,110 #15 Posted 2 hours ago The 314-A is a 1985 model 21-14KE01 Share this post Link to post Share on other sites
