Snelly1985 3 #1 Posted April 17 I'm at about my wits end on this issue I'm struggling to resolve. It all began while mowing my yard, when my PTO deck shut off. I came to a stop then shut off the switch, then turned it back on, and nothing....at first. After a few seconds, it kicked off again. Did a repeat of actions and after a delay, it started up again; however, this time when it cut out, the engine started misfiring till it eventually just shut down. After some googling, it leaned toward either a weak battery, or malfunctioning PTO clutch that was killing the battery almost instantly. I also saw that if it was the latter situation, that sometimes it can overheat the PTO switch, to the point of being useless. Right or wrong, my next step was to bypass the PTO clutch connection. This still did not allow the tractor to fire up. Then, to eliminate some of the other possibilities that were mentioned online, I went ahead and ordered a new oem key switch, solenoid, and PTO switch while I had the battery charging (even though only a year old and was still about 12.8 volts prior to charging). I installed the new parts one at a time to see if anything made a difference, but to no avail. Finally, I was able to locate the wiring schematic online and replaced the 3 fuses (even though they weren't blown), and started testing/bypassing the safety switches. The schematic only shows 4 switches in the circuit, plus the PTO switch; however, mine had 2 neutral switches (schematic shows 1) for a total 5 switches & PTO switch. In the end, I managed to create a closed circuit that went to the seat switch, to the brake switch, parking brake switch and both neutral switches with a reading of 12.8 volts at each bypass. I can't remember the name at the moment, but I also replaced small rectangular, aluminum part that had a plug going to it at the same time as the other parts. I don't know what I did at one point in this process, but I did manage to get it to start, but then I couldn't shut off with the key (old ignition switch). I cleaned up the engine ground surface and replaced the connections with new. I don't know if it's some sort of ground issue, or it has something to do with having those 2 neutral switches instead of 1, or what. Maybe I should take another stab at it by replacing the "kill relay", maybe "switch relay" as well, just to eliminate those possible problems. I'm totally at a loss for things to try at this point; and any advice would be a blessing. Process of elimination hasn't seemed to bear any fruit yet. 2 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,320 #2 Posted April 17 Welcome to Red Square. Have you seen the wiring diagrams where each circuit has it's own diagram? Makes diagnosis easier. Double check the ignition switch with the one in the main diagram. Terminal identities and location are important. Although the tractor has magneto ignition it also uses a battery type of ignition switch to control a kill relay to turn the ignition on and off. Click on the picture of the tractor in this ink to see the diagram and download the 5-page file. We may also have pin-out diagrams for the individual switches to show how they should function. Look through them all as they are in a random order in this link. Also noticed the start and kill relays are the same part so a swap may help with diagnosis. https://www.wheelhorseforum.com/search/?q=72045&quick=1&type=downloads_file Keep us posted on your thoughts. 1 1 Share this post Link to post Share on other sites
953 nut 67,194 #5 Posted April 17 I do not own this model but based on other Wheel Horses I suspect that the fuse holders are located near the battery. If one of the fuse holders has become corroded due to fumes from the battery over time it will become a poor conductor of electricity and could be your problem. 4 Share this post Link to post Share on other sites
Snelly1985 3 #6 Posted April 18 Wow! You guys are awesome! Thanks to all for the contributions; I never thought the responses would show up so quick. I'll check things out and report back with the findings. Thanks again. 1 Share this post Link to post Share on other sites
Snelly1985 3 #8 Posted April 24 Well, I'm back again with the same issues. I just don't know what I'm missing. I feel like I'm further away than I was when I first started working on it. I don't hear a click at the solenoid when I turn on the switch. What makes things confusing to me, is that there is no power to the starter motor when the key is off, but as soon as I turn it to the first "on" position(lights), the starter gets full voltage. The 2nd position retains this voltage, and the "start" position still shows full voltage to the starter. Personally, I didn't think I should be getting power to the starter until I had the key turned all the way to the start position, so that caught me by surprise. Based on the schematic, the power completes the loop through the safety switch circuit with full voltage as well with everything jumpered out. All fuses are good as well. The harness that leaves the engine block shows power back to the underside of the "console" where I can't follow any further without tearing it completely down. At this point, I've replaced both relays, all fuses, ignition switch, 4 solenoids, PTO switch, and the rectifier. At this point, my only uncertainty comes from the "neutral" safety switch because the schematic shows 1 of them, but I pulled 2 out of it. Does that make sense? Is there something I'm missing there? My other question is that I don't understand the purpose/functionality of the 2 small terminals on the solenoid. I never see any "juice" out of either of them. I saw note online that said a simple test to determine if it was a solenoid issue or a safety issue, was to run a test wire from the battery negative to the small terminal on the same side of the solenoid as the power wire to the starter and try the key. If it starts, there is a safety switch issue. If it doesn't start, it is likely the solenoid being faulty. Since it is new, and I put it on and performed the test prior to any other tinkering, I can't imagine it is still a solenoid issue. Another puzzling find, is that VERY occasionally, when the switch is turned to at least the first on position, I'll sometimes hear a repeating and low volume clicking...almost like I'm hearing the ticking of a clock, but occurs what seems to be 5 seconds or so apart each time. When I most recently heard it, I immediately tried to crank it over, thinking that there was a shorting connection and that it would attempt to start, but I get absolutely nothing. Battery remains at 12.8 at all times, even after sitting for a few days. I love this tractor, but I don't know how much more I can take before I push it off a cliff!☺ Please help, if you can. Thanks in advance. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,320 #9 Posted April 24 The clicking you hear may be the hour meter running. The two switches should be the neutral switch and the brake switch - they may be the same part number. Wondering if you don't have grounding issues. The (-) battery cable should go to the engine block as well a a small gauge wire which grounds the rest of the system. If in doubt add more grounds. You should never see any voltage on a black wire. If you do it is not grounded or has a poor ground connection. To test hook test light to negative battery post and probe for voltage at the black wire terminals as you apply power to a circuit. You will never get power out of the small solenoid terminals. The solenoid is just a heavy duty relay. When the green wire applies power from the start circuit the magnetic coil is energized as long as the other small terminal black wire is grounded it will close the big contacts joining the (+) battery cable to the starter cable - motor runs. If you have voltage at the small black solenoid wire in start key position that black wire is not grounded as it should be. You did download the 5-page wiring diagrams? Keep the questions coming. 1 Share this post Link to post Share on other sites
Snelly1985 3 #10 Posted April 27 I'll check the ground again. I already cleaned the block itself and replaced terminal ends of the grounds going to the block. If it's not that, I have something jumpered incorrectly. I just don't understand what happened. I have the diagrams printed out and have been using them, but I'm stuck from going around in so many circles. Appreciate the feedback. Share this post Link to post Share on other sites
Snelly1985 3 #11 Posted April 29 Filed the block to clean it up where it was grounded and added an additional heavy ground wire and extended it to frame where I ground off the paint. Did not make a bit of difference. I forgot to ask "gwest" about why I would have a pair of matching switching up next to my shifter (up on helm next to the steering wheel). I already have a brake switch down at the brake. As I mentioned previously, I have more switches than the wiring diagram calls out. Not that this would affect the starting, but I think I'm going to switch back to the original rectifier that was on it. The replacement doesn't quite look the same with regard to the aluminum fins on the one side and I never truly verified the old one was bad anyway. My next step is to get inside the engine by removing the shroud and have a look around. I also want to pull the starter off at this point, to bench test it. Other than that, I know nothing else to look into on this thing. Any help would be great....as usual. Thanks in advance. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,320 #12 Posted May 3 The parking brake switch has nothing to do with the starting or ignition. It powers a light to tell you the parking brake is applied. 2 Share this post Link to post Share on other sites
953 nut 67,194 #13 Posted May 4 On 4/29/2026 at 5:47 PM, Snelly1985 said: My next step is to get inside the engine by removing the shroud and have a look around. I also want to pull the starter off at this point, to bench test it. Other than that, I know nothing else to look into on this thing. Any help would be great....as usual. What will you be looking for? Here is guide you can follow, it is general in nature and not specific to any model. Why won’t my starter turn over from the key switch?\ Lets take a logical step by step inspection of your starter problem. Is your PTO in the ON position, a wheel horse will not start with the PTO on. Have you had the battery load tested at an auto parts store? Have you cleaned and tightened all electrical connections including grounds? Are all fuses good and fuse holders cleaned? If these have all been done, we can check components of the starting system as follows; don’t skip a step or you may miss the problem. Be sure the transmission is in neutral and the parking brake is set. Take a pair of automotive jumper cables and connect the black cable to your battery "-" and a good clean spot on the engine. Now connect the other cable to the large post on the starter and touch the other end to the battery "+" terminal, does the starter turn over? If the starter turns over the battery and starter are good. If it didn't turn over try the same steps with the battery in your car/truck, if that cures the problem then the "good" battery wasn't so good. Presuming the starter turned over move the jumper wire from the starter post to the other end of the wire going to the starter which is one of the large posts on the solenoid. If the starter turns over when the battery is touched by the jumper as before then that cable is good, if not you have found your problem. Presuming the starter turned over move that jumper to the other terminal of the solenoid, connect the other end to the battery and use a small piece of wire to temporarily connect the battery "+" terminal to the small terminal on the solenoid, this should cause the solenoid to close and the starter to turn over. If not, the solenoid is probably the problem. If this was successful remove the large jumper cable and use the small jumper wire to the small terminal of the solenoid, the solenoid should close and the starter turn over. If not the cable to the battery is the problem. Presuming all of these have been successful remove the black jumper wire and repeat the small jumper to small terminal, if the starter turns over the ground is good. If all of these components test good then remove your ignition switch, be sure the transmission is in neutral, parking brake on, clutch depressed and PTO off. Use a small jumper to connect the terminals that were connected to the “B” and “S” terminals of the ignition switch. If the starter turns over then the PTO switch and other safety switches are operating properly and your ignition switch may be bad Share this post Link to post Share on other sites
