Goldnboy
Tire clearance issues V61's
Goldnboy
I know a lot of members here run V61's on there tractors but I don't recall anyone mentioning that the mule drive can interfere with turning.
I couldn't turn left fully without rubbing on te mule drive. So i added a 1/2" collar on the spindle  two machine washers and then inserted a bushing inside the rim along with a longer bolt and problem solved. However for those running newer machines that use a snap ring in place of a bolt this would not be a viable solution.
8ntruck
They fit without any issue on my C-195. Then again, that is a completely different animal mule drive wise.
sqrlgtr
What Mochine are you running those on? I put a set on a C160 but I havent had a mule drive on since mounting the V61's.
Goldnboy
These are the original wide rims on a C120  8 speed.
sqrlgtr
Well, I assume I would have clearance problems with the C160 also. I don't foresee using a mule drive on this tractor but was always nice to have options.:D
DLF
What year model do you have?  I know the 1976 and 1977 C-120 came with 5 3/8" wide wheels  I have seen some 1974 and 1975 C-120 with 4" wide wheels.
Lee1977
sqrlgtr
58EE4B58-42D2-4FBC-9CB9-1C2F9B16F450.jpeg.02f8a12543c6357ccfb208fe47f0becf.jpegC694C307-D163-44FF-93CB-7B64297A8CA0.jpeg.581664b4e2659f7fa38554ada590ca82.jpeg
Here is mine on the C160 and they look like they have enough room for mule drive but I hadn't had one on this mochine in awhile. 1974 year model
Edited by sqrlgtr
Goldnboy
Goldnboy
I am using a 1974 C120 special with a toasted techy that has a Kohler magnum 12 take over.
The V61's are the smaller 16x6.50x8/170x60x8.. I didn't confirm my rim size but had 16x6.50x8 turfs on previously they leaked and had previously been slimed and which corroded the rims and required JB to fix rust holes.
