Goldnboy 1,134 #1 Posted April 16 I know a lot of members here run V61's on there tractors but I don't recall anyone mentioning that the mule drive can interfere with turning. I couldn't turn left fully without rubbing on te mule drive. So i added a 1/2" collar on the spindle two machine washers and then inserted a bushing inside the rim along with a longer bolt and problem solved. However for those running newer machines that use a snap ring in place of a bolt this would not be a viable solution. 1 1 1 Share this post Link to post Share on other sites
8ntruck 9,040 #2 Posted April 16 They fit without any issue on my C-195. Then again, that is a completely different animal mule drive wise. Share this post Link to post Share on other sites
sqrlgtr 3,237 #3 Posted April 16 2 hours ago, Goldnboy said: I know a lot of members here run V61's on there tractors but I don't recall anyone mentioning that the mule drive can interfere with turning. What Mochine are you running those on? I put a set on a C160 but I havent had a mule drive on since mounting the V61's. Share this post Link to post Share on other sites
Goldnboy 1,134 #4 Posted April 16 These are the original wide rims on a C120 8 speed. 1 Share this post Link to post Share on other sites
sqrlgtr 3,237 #5 Posted April 16 1 hour ago, Goldnboy said: These are the original wide rims on a C120 8 speed. Well, I assume I would have clearance problems with the C160 also. I don't foresee using a mule drive on this tractor but was always nice to have options. Share this post Link to post Share on other sites
DLF 74 #6 Posted April 17 What year model do you have? I know the 1976 and 1977 C-120 came with 5 3/8" wide wheels I have seen some 1974 and 1975 C-120 with 4" wide wheels. Lee1977 Share this post Link to post Share on other sites
sqrlgtr 3,237 #7 Posted April 17 (edited) Here is mine on the C160 and they look like they have enough room for mule drive but I hadn't had one on this mochine in awhile. 1974 year model Edited April 17 by sqrlgtr 1 1 Share this post Link to post Share on other sites
Goldnboy 1,134 #8 Posted April 17 These are the original wide rims on a C120 8 speed. Share this post Link to post Share on other sites
Goldnboy 1,134 #9 Posted April 17 I am using a 1974 C120 special with a toasted techy that has a Kohler magnum 12 take over. The V61's are the smaller 16x6.50x8/170x60x8.. I didn't confirm my rim size but had 16x6.50x8 turfs on previously they leaked and had previously been slimed and which corroded the rims and required JB to fix rust holes. 1 Share this post Link to post Share on other sites
sqrlgtr 3,237 #10 Posted April 17 11 hours ago, Goldnboy said: The V61's are the smaller 16x6.50x8/170x60x8. same thing on the C160 pictured above and I "think" they are on 4" wide wheels. Share this post Link to post Share on other sites
