Goldnboy 1,094 #1 Posted 2 hours ago I know a lot of members here run V61's on there tractors but I don't recall anyone mentioning that the mule drive can interfere with turning. I couldn't turn left fully without rubbing on te mule drive. So i added a 1/2" collar on the spindle two machine washers and then inserted a bushing inside the rim along with a longer bolt and problem solved. However for those running newer machines that use a snap ring in place of a bolt this would not be a viable solution. 1 1 Share this post Link to post Share on other sites
