adsm08 4,801 #26 Posted April 17 2 hours ago, ebinmaine said: Work good? They kind of taste like Drain-O. But they have a kick to them. 2 Share this post Link to post Share on other sites
iwuzheerlater 4 #27 Posted April 18 Mmmm tastes just like the sun would... 2 Share this post Link to post Share on other sites
Handy Don 16,961 #28 Posted April 18 At age 13, my twin brothers and a friend were curious to see what gasoline mixed with powdered pool chlorine would do. In case you wondered, they react explosively, spraying burning fuel like bomb shrapnel in all directions. One brother nearly died from the burns and shock and still carries major scars. 1 Share this post Link to post Share on other sites
adsm08 4,801 #29 Posted April 18 Ok, so the fuel was coming out the vent, not the jet. I dropped the needle walking through the shop, can't find it, put a spare carb on and it is working, but this carb has it's own set of issues. Guess I need to find a good rebuild kit. Share this post Link to post Share on other sites
ebinmaine 79,714 #30 Posted April 18 9 minutes ago, adsm08 said: Guess I need to find a good rebuild kit. Done. https://billsplaceshop.com/products/new-genuine-oem-kohler-part-25-757-01-s-carburetor-kit-for-k91-k301-k321-k482?variant=47126773629231 You'll need a base gasket too. 1 1 Share this post Link to post Share on other sites
ohiofarmer 3,448 #31 Posted April 18 Answer and then a question.... A really easy way to judge whether or not a float is leaking or getting gas inside is this . Just get a container of warm water and hold the float under the surface. Bubbles =problem. I have fixed them with tank liner after heating them up in a metal bowl or whatever method you choose to heat and expel or burn the gas. Then put tank liner on them. Taryl and others have suggested that Hipa has some good carburetors that are decent quality. Do they make one for the K series for my c-160 ???? Share this post Link to post Share on other sites
adsm08 4,801 #32 Posted May 8 On 4/18/2026 at 5:24 PM, ebinmaine said: Done. https://billsplaceshop.com/products/new-genuine-oem-kohler-part-25-757-01-s-carburetor-kit-for-k91-k301-k321-k482?variant=47126773629231 You'll need a base gasket too. Well that's was a bust. After a week or so the order got canceled and refunded. 1 Share this post Link to post Share on other sites
ebinmaine 79,714 #33 Posted May 8 14 minutes ago, adsm08 said: Well that's was a bust. After a week or so the order got canceled and refunded. 💩 I can send you the pieces if need be. 1 1 Share this post Link to post Share on other sites
adsm08 4,801 #34 Posted May 8 48 minutes ago, ebinmaine said: 💩 I can send you the pieces if need be. I have a working carb right now. I robbed a known good needle and float from another one. It will get me to the show at least. I'll see if I can find stuff there. 2 Share this post Link to post Share on other sites
