AHS
‘99 314-8 i got it running!!
AHS
Here’s a video of it running after 3 minutes, (if you can see the video)
  • Like 7
My_horse
Looks like mine!  Have fun with it. I have the bervac rear weight bracket and weights for mine when I used the blower. I just have the single stage WH blower. The weights pretty much make it unstoppable!
ebinmaine
9 hours ago, AHS said:
Fired right to life
Niiiiice
AHS
Ya, the weights and chains were thrown in with it!
Retired Wrencher
AHS: That looks like a great worker for you. Keep checking things until you feel you have all the bugs out. Enjoy the ride.
  • Like 4
AHS
Yes! I was worried about the tranny belt, cause it hadn’t been driven in so long!! Well the belt is in pieces!! I got a new belt ordered. I have snowblowed / mowed with an ‘00 312, i got rid of that. The 314 is next!!!
sqrlgtr
On 4/12/2026 at 7:17 PM, AHS said:
it fired right to life!!
Always a great feeling. I have a  99 (I think) 312-8 that must be its little bro looks just like yours with them fancy floorboards and such :D. I didnt relize how much better I liked the 8" front wheels better than the 6" until I got them beside each other. Anyone know what year they went back to the 8" wheels.
Edited by sqrlgtr
OutdoorEnvy
Great work!  It's satisfying on so many levels to bring one back to life and put it back to work!  Good on ya!  :handgestures-thumbupright:
AHS
I have this problem! Will it run? How cheap can i get for? Ive got Wheelhorse / Toro problems!!! Ive got “wheelhorse”,’toro’ and “Wheel horse” in my marketplace finds. I have Wheelhorse problems, i need to seek help!!! BUT!!! There’s always 1 other guy who has 15+ Wheelhorses… and i think, “nah it’ll be fine!!”:D
  • Haha 3
SylvanLakeWH
:text-yeahthat:
  • Haha 3
AHS
I don’t know if you could get the 8” wheels specifically? Im assuming that it whatever the dealer had? I think* the 310 and the 312s were 6”? Im almost certain one you got into the 314s, and the 99+ 315 they had 8” front wheels. Ive had plenty of 310s and 312s with 6” front wheels. There may have been 310s or 312s that had 8” front wheels!!
Retired Wrencher
Good luck with all your projects. Just take your time and enjoy what you’re doing.
rick
Wheel Horse garden tractors were not matched with a deck when shipped, you bought the tractor and chose a deck at time of purchase/order.  The 6" wheels were/are required when the tractor is equipped with the 37" cutting deck.  The 37" deck has two blades with the left blade offset to the front causing interference with the 8" left front tire on sharp left turns. The lower horsepower rated tractors were more apt to be purchased with the 37" deck than the 14 horsepower and up units.
Now why in the world my 1990 416H tractor was factory equipped with 6" wheels is a mystery to me.
  • Like 5
sqrlgtr
:ROTF:
Retired Wrencher
15 hours ago, sqrlgtr said:
:ROTF:
I guess we can say the same thing about the 73 no name 8 had a totally different rims and tires on them with extended axels.. Also, If I remember correctly. They only had a 3 bolt rims and very small tires front and rear.
clueless
you could get the 37" deck on the 400 series also if you ordered it, it just came with the 6" wheels. An optional bagger kit was for the 37" deck.
sqrlgtr
A few tid bits of info I had not heard before in above post.
I had seen one before and thought that someone had done this on there on and didn't realize they came from the factory like that.
kpinnc
Yep. 10 inch rear wheels, 6 inch fronts. Rear axles were about 2.5 inches longer than standard to make up for the wheel offset. Mine did have 5 bolt hubs though.
rick
Understood, but who would do that?
SylvanLakeWH
Pedestrian gate access only yards... only way to get through is if smaller mower deck...
clueless
Obviously someone who wanted a bagger.
clueless
Rear axles??
Handy Don
As noted, narrower and the 37 is also the only deck that could handle a bagger without a vacuum/blower attachment--it could be equipped with blades with stronger “lift”.
The target market for the lower powered tractors was smaller suburban lawns and modest snow clearing.
