bo dawg 570 #1 Posted yesterday at 02:11 AM What is the difference with these 2 spindle housings. I understand bearing sits lower in the one on the left and it gets a spacer on top of bearing with the shorter pipe in side. And the one on right gets a longer pipe inside due to bearing sits higher. So is the one on left just for 3/4” spindle and one on the right gets the 5/8” spindle. Or…….. Share this post Link to post Share on other sites
JoeM 9,717 #2 Posted 19 hours ago (edited) Yes, one on left is metric 17mm (6203 bearing 17mmx40mmx12mm), an the other is imperial bore 3/4" (6203-12 3/4"x40(mm)x12(mm) using a seal and inner spacer. I have used the smaller metric shaft in the deep bearing housing by using an old bearing race as a spacer under the bearing. I knock the guts out of and old bearing and left over bearing race is the right thickness. This eliminates the seal and seal carrier spacer. Edited 19 hours ago by JoeM 1 1 1 Share this post Link to post Share on other sites
peter lena 9,815 #3 Posted 13 hours ago @bo dawg personally only use lucas x tra hd green chassis grease in any related bearing, over kill ? nope , that 550 degree flash point , really stands up to abuse , also polyurea rating ensures lube retention , all my decks and related mule drive bearings have this in them , the always easy engage ment , spin up is effortless , no belt squeal at all , using this on my units for years , no noise or failures . pete Share this post Link to post Share on other sites
