kpinnc 18,851 #26 Posted April 10 4 hours ago, FLtractor said: Interesting. What size bolts did you use inside the facet fuel pump mounting holes? They were the ones that came with it. About 1/4 inch diameter as I recall. Share this post Link to post Share on other sites
FLtractor 196 #27 Posted April 10 28 minutes ago, kpinnc said: They were the ones that came with it. About 1/4 inch diameter as I recall. Oh ok. Mine didn’t come with any. Just the 2 brass fuel end fittings for fuel pump Share this post Link to post Share on other sites
Retired Wrencher 6,901 #28 Posted April 11 @FLtractor This is what I use for hold down of the fuel pump. A milled steel. Also somewhat flexible . 1 Share this post Link to post Share on other sites
Retired Wrencher 6,901 #29 Posted April 19 FL tractor how did things work out? I’m the 856? Share this post Link to post Share on other sites
