FLtractor 223 #1 Posted April 8 (edited) Evening, My 856.. rear wheels heavily rusted due to calcium chloride, has hub caps on both wheels.. Given the aluminum can’t rust but can corrode.. is it possible they’ve been on there so long with so much rust, upon removal they simply disintegrate? If not.. what’s the recommended way to remove them off the wheels… would like to polish them up? Edited April 8 by FLtractor Share this post Link to post Share on other sites
Retired Wrencher 6,989 #2 Posted April 8 (edited) I would say small moves all the way around the caps or moons. A long screw driver or small prybar. Send up a picture of them if you can. How do you like the 856? This one came from the big show a few years back. I like it. Edited April 8 by Retired Wrencher 5 Share this post Link to post Share on other sites
sqrlgtr 3,932 #3 Posted April 8 856 one of my Favorites. This one came back with me from Big Show last year. 1 Share this post Link to post Share on other sites
953 nut 69,313 #4 Posted April 8 I use a 7" wonder bar, work your way around the edge like @Retired Wrencher said. 4 1 Share this post Link to post Share on other sites
peter lena 10,065 #5 Posted April 8 @ FL TRACTOR , penetrating oil drive around , then wonder bar , pop off , regularly put lubrication on anything , for cleaning and rust tracking stop , pete 2 Share this post Link to post Share on other sites
953 nut 69,313 #6 Posted April 8 20 hours ago, FLtractor said: has hub caps on both wheels.. Given the aluminum can’t rust but can corrode. Are the hub caps aluminum? I have seen chromed steel and plastic Wheel Horse hubcaps but never have seen aluminum. 1 Share this post Link to post Share on other sites
sqrlgtr 3,932 #7 Posted April 8 (edited) 5 minutes ago, 953 nut said: Are the hub caps aluminum? I have seen chromed steel and plastic Wheel Horse hubcaps but never have seen aluminum. wow it didn't even register with me that aluminum was mentioned..... Guess I need to quite speed reading . Edited April 8 by sqrlgtr 1 Share this post Link to post Share on other sites
FLtractor 223 #8 Posted April 9 (edited) 2 hours ago, 953 nut said: Are the hub caps aluminum? I have seen chromed steel and plastic Wheel Horse hubcaps but never have seen aluminum. Ooooo.. whatever the Wheelhorse hubs caps material is.. I said aluminum because it looks like it but chromed steel makes much more sense Edited April 9 by FLtractor Share this post Link to post Share on other sites
FLtractor 223 #9 Posted April 9 12 hours ago, 953 nut said: I use a 7" wonder bar, work your way around the edge like @Retired Wrencher said. Hey!! I have one Of those!! what holds the hubcaps on the wheels? Share this post Link to post Share on other sites
Retired Wrencher 6,989 #10 Posted April 9 On 4/8/2026 at 7:22 AM, sqrlgtr said: On 4/8/2026 at 7:22 AM, sqrlgtr said: 856 one of my Favorites. This one came back with me from Big Show last year. Nice looking 856. They made them to last back then. Does yours still have the original fuel pump or did you put an e pump on it? Share this post Link to post Share on other sites
peter lena 10,065 #11 Posted April 9 @FLtractor those wonder bars , are also the prefect tool for mower deck spindle pulley removal , slide 2 of them , under the bottom of pulley , on top of spindle mount bolts , push them both EQUALLY OUTWARD , perfect leverage advantage . done my decks , makes a bearing refresh much easier . since doing my decks over , with lucas green chassis lube , in every rotational bearing , no bearing whine or scream , regularly refer to this change , it is the fix , another GOLD MINE , improvement zone . my decks spin by hand at mule drive belt connection . ELIMINATE REPEDITIVE PROBLEMS , make a change , pete Share this post Link to post Share on other sites
FLtractor 223 #12 Posted April 9 2 hours ago, peter lena said: @FLtractor those wonder bars , are also the prefect tool for mower deck spindle pulley removal , slide 2 of them , under the bottom of pulley , on top of spindle mount bolts , push them both EQUALLY OUTWARD , perfect leverage advantage . done my decks , makes a bearing refresh much easier . since doing my decks over , with lucas green chassis lube , in every rotational bearing , no bearing whine or scream , regularly refer to this change , it is the fix , another GOLD MINE , improvement zone . my decks spin by hand at mule drive belt connection . ELIMINATE REPEDITIVE PROBLEMS , make a change , pete Happen to have a picture of which pully your referring to Share this post Link to post Share on other sites
FLtractor 223 #13 Posted April 9 On 4/8/2026 at 8:24 AM, peter lena said: @ FL TRACTOR , penetrating oil drive around , then wonder bar , pop off , regularly put lubrication on anything , for cleaning and rust tracking stop , pete What holds the hubcaps on? Is there clips that simply pop back onto the wheel lip edge when putting the hubcaps back on? Share this post Link to post Share on other sites
sqrlgtr 3,932 #14 Posted April 9 10 hours ago, Retired Wrencher said: Nice looking 856. They made them to last back then. Does yours still have the original fuel pump or did you put an e pump on it? Not original but it does have one of the later plastic mechanical pumps on it. The PO had installed it but works great so far. Share this post Link to post Share on other sites
Sparky-(Admin) 26,360 #15 Posted April 9 5 hours ago, FLtractor said: What holds the hubcaps on? Is there clips that simply pop back onto the wheel lip edge when putting the hubcaps back on? The hub cap has 4 clips that “bite” into the rim Share this post Link to post Share on other sites
Retired Wrencher 6,989 #16 Posted April 10 13 hours ago, sqrlgtr said: Not original but it does have one of the later plastic mechanical pumps on it. The PO had installed it but works great so far. You can buy an E-pump you and save it until the one you have fails.Those plastic pumps is not the way to go. You will be happy with it. Quick starts. Share this post Link to post Share on other sites
CasaytheMann 265 #17 Posted April 10 You could also use a heat gun to heat the hubcap up some, then use a flat (wonder) pry bar to pop it off. Using a rubber mallet to tap the pry bar might help too. Share this post Link to post Share on other sites
hotajax 284 #18 Posted April 12 On 4/8/2026 at 8:18 AM, 953 nut said: I use a 7" wonder bar, work your way around the edge like @Retired Wrencher said. One of the greatest tools ever designed. Except I rarely use it for what it was intended Share this post Link to post Share on other sites
953 nut 69,313 #19 Posted April 12 10 hours ago, hotajax said: One of the greatest tools ever designed. Except I rarely use it for what it was intended Another unintended use for the 7" wonder bar that I have come up with is removing the 1533 bearings from a transaxle. Put the bent end into the axle opening and place it in contact with the bearing, give the other end a light tap with a hammer and the bearing will pop right out. Share this post Link to post Share on other sites
