RBM
Help with my Sundstrand 90-1136 transmission
RBM
What hydraulic filter should I use in my transmission? FYI this is on a 1973 wheel Horse 12 automatic. If anyone knows any please tell me...thank you.
gwest_ca
Welcome to Red Square
The preferred transmission filter for all models is a Wix 51410 or Napa 1410 because it does not have a by-pass valve
  • Excellent 2
  • Thanks 2
Ed Kennell
:text-welcomeconfetti: to the :rs:
953 nut
:WRS:
always glad to see a new member join the group. Tell us a bit about your :wh: and the story of how it came into your possession. Every one is interesting.
pfrederi
Welcome!!!!
RBM
Thank you for the help! This is the story of how I received my Wheel Horse...My grandfather bought it in the early 80s it was used but in good shape...He used it for about 35 years then he gave it to my Dad. My Dad used it to mow the grass for about 5 years then it sat in storage Until I decided to work on it with my grandfather. My grandfather and I got it running and have kept it running for 8 years and I plan to keep it running.20260404_203507.jpg.6781000fcefbe21c307d5e7a35381740.jpg
  • Excellent 4
  • Heart 3
pfrederi
Then fluid in your hydro should be 10w-30 motor oil.  Will look tan when you wipe the dipstick on a paper towel...This was a transition period the fluid may be ATF that would look pink.  Do not mix use what ever is in there to refill your hydro.
lynnmor
Now that is just the kind of story that we want to hear.  @953 nut will be glad he mentioned it.
RBM
The fluid was never replaced even when my grandfather owned it...so I replaced it with the equivalent to the original ATF. It was ATF so I put ATF in it. The old ATF was dirty and smelled burnt. So i'm happy I replaced it lol...Once I get the new filter I will replace it again to get any other crap out of it...I want to thank everyone that helped me! Thank You very much!!
pfrederi
953 nut
:woohoo:                                  Always glad to see a second and third generation show a Wheel Horse some love.                   :text-coolphotos:
