Mike'sHorseBarn
1996 314H Hydro Release?
Mike'sHorseBarn
Went to work on it tonight. Was told it ran last year, the carburetor would argue otherwise. It was so gunked up it was hard to get apart. Dang near ruined the head of the high speed needle and I don't have walbro stuff laying around 😕
Anywhere, got that off and cleaned up, gotta order a kit, choke cable is broke, gotta get one of those too and an air filter. I put a battery in it and it did turn over after I put a new battery in it. More to come...
  • Like 4
WHX??
Little dirty but that'll buff out. :thumbs2:
Handy Don
I've (expensively) learned that when there is resistance, penetrant and patience are allies and haste is the enemy.
953 nut
  • Haha 1
Mike'sHorseBarn
I FINALLY got it going tonight! Washed it up and tested it, changed all the fluids! Now to put it to work!
  • Excellent 5
DLF
On 4/7/2026 at 8:43 AM, sqrlgtr said:
Guess I'm in the minority I just can't get comfortable with the foot control, but around here you have to be able to slide around on the seat to keep right side up :auto-swerve:. I can see the foot control being handy pushing with dozer blade or using front end loader though. BTW great score on the 314-H.
I improved on the console hand control om my 520-H.
Handy Don
How did you handle the “neutral to start” microswitch?
sqrlgtr
I just assumed that is what the 2 screws or holding in the plate he has made but might not be?
DLF
I moved the switch with the two small screws.
sqrlgtr
where to? I thought it looked like the control stick was making switch it when it went into the neutral spot you had made into plate?
Edited by sqrlgtr
DLF
The original neutral slot was deeper had to move the switch for that half circle notch. Also had to cut  out some the original plate for the straight groove.
cleat
That looks like how wheel horse should have done it from the start.
If mine weren't all foot control I would do that as well.
Looks like it would be a more natural movement from forward to reverse.
