rmaynard 16,996 #1 Posted 4 hours ago Grandson Mason is working on a Raider 12. The engine needs quite a bit of work. I gave him a non Wheel Horse K301 that has less than 100 hours on it. The only problem is that the crankshaft end is 1" diameter, but his drive pulley from the Raider engine has a 1-1/8" inside diameter. Has anyone ever sleeved the shaft to make that work? Share this post Link to post Share on other sites
JoeM 9,688 #2 Posted 4 hours ago Yes. Sleeved a predator to use on a WH with parts from ebay. No issues. 2 Share this post Link to post Share on other sites
SylvanLakeWH 30,812 #3 Posted 4 hours ago Yes... Something like this... I'd compare pulley cost to shaft sleeve cost... Share this post Link to post Share on other sites
JoeM 9,688 #4 Posted 3 hours ago Bob, I have a 1 inch WH engine pulley for a gear drive. I can send it to you. Might cost you a sandwich at the show. Let me know. JoeM 1 Share this post Link to post Share on other sites
953 nut 64,684 #5 Posted 3 hours ago 13 minutes ago, SylvanLakeWH said: compare pulley cost to shaft sleeve cost... May require a stepped key also. 7 minutes ago, JoeM said: Bob, I have a 1 inch WH engine pulley for a gear drive. I can send it to you. Might cost you a sandwich at the show. Let me know. JoeM @JoeM is the best. 1 Share this post Link to post Share on other sites
rmaynard 16,996 #6 Posted 2 hours ago 1 hour ago, JoeM said: Bob, I have a 1 inch WH engine pulley for a gear drive. I can send it to you. Might cost you a sandwich at the show. Let me know. JoeM This is the pulley we are replacing. PTO plate mounts on it. Share this post Link to post Share on other sites
Racinbob 12,860 #7 Posted 2 hours ago Yes. I sleeved the entire shaft on my reborn B-80. I had the pulley and pto bearing race for the 1.125" shaft so I found a sleeve that covered the entire shaft. I may have trimmed it to fit. The sleeve required the key to be 1/4" x 5/16" and a full length key was provided. 1 Share this post Link to post Share on other sites
