Brockport Bill 2,407 #1 Posted April 2 Perhaps the Forum Administrators or other members can help clarify this issue? the B100 Tractor is listed as manufactured in 74,75,76,77............there were 36 inch mower decks listed for those respective years as models 5-0721; 5-0621; 5-0722; 5-0622; 65-36ms01; 65-36xr01; 75-36ms01; and 75-36xr01. Also perhaps, 76-36xr01 ???? there were "next generation" or "successor" 36" rear discharge model decks including later in the 80's --- eg: 36 inch r.d. models 05-36mr01,and 02,03,04 etc Can the 36 inch decks from the 80's be used on the B100 of the 1970s? Are they compatible? Thanks, Bill 1 Share this post Link to post Share on other sites
JoeM 10,070 #3 Posted April 2 this is a 75 with a newer deck, was my first WH bought it in the 80's used. 2 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,321 #4 Posted April 2 This is a list put together from the Attachment Interchange. It lists the deck (2) that replaced the original (1) and the deck that was available when the Interchange was created (4). What is missing are the decks (3) between (2) and (4). They are listed but you have to follow a deck year by year to find the others. Mower DNA 1972 model 5-0620 replaced by 1973-1974 model 5-0621 1975 model 5-0622 1976 model 65-36XR01 1977 model 75-36XR01 1977 model 75-36XR02 1978 model 85-36MR01 1979 model 95-36MR00 (Blades up to this point have the 5/8" x 3/4" double-D center hole unless the spindle has been upgraded) --------------------------------------------------------------------------------------------------------------------------------------------------------------------------- (These decks used blades with a 3/4" center hole) 1979 model 95-36MR01 replaced by 1980-1982 model 05-36MR01 - Last year for bearings with 3/4" ID 1983-84 model 05-36MR02 - First year for bearings with 17mm ID unless older spindles were updated. 1985 model 05-36MR03 1986-1990 model 05-36MR04 1991-1993 model 05-36MR05 1993-2006 model 78305 Note - 17mm is .669" 1 Share this post Link to post Share on other sites
Racinbob 13,021 #5 Posted April 2 The decks thru their final year in 2007 will work just fine on the 1977 and older B's. I'm still using a deck I purchased in the 70's on my 2005. I initially purchased it for a 76 B. Keep in mind that in 78 the B-series became lawn tractors so the interchangeability isn't there. 2 Share this post Link to post Share on other sites
clueless 3,421 #6 Posted April 2 My 1974 B-80 came with a 36" RD deck, that is pretty much the same as the one that came with my 1987 310-8. 1 1 Share this post Link to post Share on other sites
Brockport Bill 2,407 #7 Posted April 2 17 hours ago, gwest_ca said: This is a list put together from the Attachment Interchange. It lists the deck (2) that replaced the original (1) and the deck that was available when the Interchange was created (4). What is missing are the decks (3) between (2) and (4). They are listed but you have to follow a deck year by year to find the others. Mower DNA 1972 model 5-0620 replaced by 1973-1974 model 5-0621 1975 model 5-0622 1976 model 65-36XR01 1977 model 75-36XR01 1977 model 75-36XR02 1978 model 85-36MR01 1979 model 95-36MR00 (Blades up to this point have the 5/8" x 3/4" double-D center hole unless the spindle has been upgraded) --------------------------------------------------------------------------------------------------------------------------------------------------------------------------- (These decks used blades with a 3/4" center hole) 1979 model 95-36MR01 replaced by 1980-1982 model 05-36MR01 - Last year for bearings with 3/4" ID 1983-84 model 05-36MR02 - First year for bearings with 17mm ID unless older spindles were updated. 1985 model 05-36MR03 1986-1990 model 05-36MR04 1991-1993 model 05-36MR05 1993-2006 model 78305 Note - 17mm is .669" i looked at the Interchange list - the list does not answer my question because the list shows the concurrent mower decks of that era (1970s) that fit on that B100 tractor for the years tractor was manufactured......... what the Interchange list DOES NOT do is then list attachments in later years that go back in years to tell us what "future" attachment would fit on an earlier year tractor? My issue is trying to confirm if a mower deck like a 1980's 36 inch 05-36mr01 fits on an older B100 tractor from the prior decade of the 1970s - - - - the Interchange does not provide that information? That's the confirmation I am seeking? thanks, Bill Share this post Link to post Share on other sites
Brockport Bill 2,407 #8 Posted April 2 4 hours ago, clueless said: My 1974 B-80 came with a 36" RD deck, that is pretty much the same as the one that came with my 1987 310-8. when you say "pretty much the same" - - that's helpful but i was trying to know if it actually is a fit and usable on a 80's 36 inch deck and fits on a 70s B100? thanks Bill Share this post Link to post Share on other sites
Brockport Bill 2,407 #9 Posted April 2 10 hours ago, JoeM said: this is a 75 with a newer deck, was my first WH bought it in the 80's used. when you say "newer deck" -- that deck looks to me like a 80s era version of a 36 -- in the family of 05-36mr01, 02,03,04? yes ? 1 Share this post Link to post Share on other sites
Racinbob 13,021 #10 Posted April 2 Those interchange lists can't see into the future. Just rest assured, ALL the decks from the tach-a-matic years are interchangeable. Just to simplify things, ignore the 37" and 60" and the lawn tractors. That means from 72-73 thru 2007. Any differences in the p/n's doesn't affect the interchangeability. I'm running a late 70's deck on a 2005 and a 2005 deck on a 1976. It's as simple as that. 2 Share this post Link to post Share on other sites
JoeM 10,070 #11 Posted April 2 1 hour ago, Brockport Bill said: yes ? Yes the machine came with the deck on the front of the manual that I highlighted. in the later 80's I purchased a new deck and replaced the original one. the one in the pic is the newer 80's deck 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,321 #12 Posted April 3 The right side of the attachment interchange list tells you what deck replaced the original deck and the current deck available when the interchange was created. The (2) footnote calls for a different belt. The list I posted includes all of them. 1 Share this post Link to post Share on other sites
Brockport Bill 2,407 #13 Posted April 3 1 hour ago, gwest_ca said: The right side of the attachment interchange list tells you what deck replaced the original deck and the current deck available when the interchange was created. The (2) footnote calls for a different belt. The list I posted includes all of them. thanks --forgot all about that end column being over there -- 2 Share this post Link to post Share on other sites
John c 197 #14 Posted May 7 What is the wheel base on the 70's B100, if it's the longer one, I think it'd work. 1 Share this post Link to post Share on other sites
Racinbob 13,021 #15 Posted May 7 74 and 75 are medium. 76 and 77 are long. 1 Share this post Link to post Share on other sites
