Brockport Bill
B100 - 36 inch mower compatibility?
Brockport Bill
Perhaps the Forum Administrators or other members can help clarify this issue?
the B100 Tractor is listed as manufactured in 74,75,76,77............there were 36 inch mower decks listed for those respective years as models 5-0721; 5-0621; 5-0722; 5-0622; 65-36ms01; 65-36xr01; 75-36ms01; and 75-36xr01. Also perhaps, 76-36xr01 ????
there were "next generation" or "successor" 36" rear discharge model decks including later in the 80's --- eg: 36 inch r.d. models 05-36mr01,and 02,03,04 etc
Can the 36 inch decks from the 80's be used on the B100 of the 1970s? Are they compatible? Thanks, Bill
  • Heart 1
702854boy
I think they are
JoeM
this is a 75 with a newer deck, was my first WH bought it in the 80's used.
gwest_ca
This is a list put together from the Attachment Interchange. It lists the deck (2) that replaced the original (1) and the deck that was available when the Interchange was created (4). What is missing are the decks (3) between (2) and (4). They are listed but you have to follow a deck year by year to find the others.
Mower DNA
1972 model 5-0620 replaced by
1973-1974 model 5-0621
1975 model 5-0622
1976 model 65-36XR01
1977 model 75-36XR01
1977 model 75-36XR02
1978 model 85-36MR01
1979 model 95-36MR00 (Blades up to this point have the 5/8" x 3/4" double-D center hole unless the spindle has been upgraded)
(These decks used blades with a 3/4" center hole)
1979 model 95-36MR01 replaced by
1980-1982 model 05-36MR01 - Last year for bearings with 3/4" ID
1983-84 model 05-36MR02 - First year for bearings with 17mm ID unless older spindles were updated.
1985 model 05-36MR03
1986-1990 model 05-36MR04
1991-1993 model 05-36MR05
1993-2006 model 78305
Note - 17mm is .669"
Racinbob
The decks thru their final year in 2007 will work just fine on the 1977 and older B's. I'm still using a deck I purchased in the 70's on my 2005. I initially purchased it for a 76 B. Keep in mind that in 78 the B-series became lawn tractors so the interchangeability isn't there.
clueless
My 1974 B-80 came with a 36" RD deck, that is pretty much the same as the one that came with my 1987 310-8.
Brockport Bill
Mower DNA
1975 model 5-0622
i looked at the Interchange list - the list does not answer my question because the list shows the concurrent mower decks of that era (1970s) that fit on that B100 tractor for the years tractor was manufactured......... what the Interchange list DOES NOT do is then list attachments in later years that go back in years to tell us what "future" attachment would fit on an earlier year tractor? My issue is trying to confirm if a mower deck like a 1980's 36 inch 05-36mr01 fits on an older B100 tractor from the prior decade of the 1970s - - - - the Interchange does not provide that information? That's the confirmation I am seeking? thanks, Bill
Brockport Bill
when you say "pretty much the same" - - that's helpful but i was trying to know if it actually is a fit and usable on a 80's 36 inch deck and fits on a 70s B100? thanks Bill
Brockport Bill
when you say "newer deck" -- that deck looks to me like a 80s era version  of a 36 -- in the family of 05-36mr01, 02,03,04? yes ?
Racinbob
Those interchange lists can't see into the future. Just rest assured, ALL the decks from the tach-a-matic years are interchangeable. Just to simplify things, ignore the 37" and 60" and the lawn tractors. That means from 72-73 thru 2007. Any differences in the p/n's doesn't affect the interchangeability. I'm running a late 70's deck on a 2005 and a 2005 deck on a 1976. It's as simple as that.
  • Excellent 2
JoeM
1 hour ago, Brockport Bill said:
yes ?
Yes
the machine came with the deck on the front of the manual that I highlighted. in the later 80's I purchased a new deck and replaced the original one. the one in the pic is the newer 80's deck
gwest_ca
The right side of the attachment interchange list tells you what deck replaced the original deck and the current deck available when the interchange was created. The (2) footnote calls for a different belt.
The list I posted includes all of them.
Brockport Bill
thanks  --forgot all about that end column being over there -- :)
