Handy Don 17,557 #1 Posted April 1 (edited) The mid-hitch on my 854 (pre-Attach-a-Matic) is pesky to operate when mounting the mower deck. Small, awkward levers plus clevis pins to lock closed or open. As well, I’m nearly done adapting a heavy Allis-Chalmers mid-mount grader and I’m concerned that for doing real work the factory hitch might not be strong enough. I have a couple of recent mid-hitches off of 500-series tractors and am contemplating an upgrade! Has anyone gone this route? Would it make more sense to find a way to strengthen the factory hitch? From measuring, I know these are not a direct replacement. The newer hitch’s: - Overall height is ½” less (4.5 vs. 5.0 inches) which moves the “mount point” a half-inch higher (the fore/aft position is the same). To keep the deck happy, I’d cannibalize another pair of side plates to add the ½” to the height. - Right side plate doesn’t have the pivot shaft for the PTO clutch/idler pulley’s support arm. I’d add that. - Clearance to the tie rods might be tight where the locking mechanism juts forward (lengthening of the later frames put more distance between the hitch and tie rods) Edited April 1 by Handy Don 1 Share this post Link to post Share on other sites
squonk 48,210 #2 Posted April 1 (edited) Tried it and the 2 things you mentioned is true. The PTO arm and the tie rod interference (short frame brings the rods closer to the hitch. ) Unless you plan on pounding on some serious hard pack dirt I don't think the normal hitch would be a problem. Edited April 1 by squonk 1 Share this post Link to post Share on other sites
ri702bill 13,187 #3 Posted April 1 Different generation WH grader blades had 2 types of mounts. The early mid mount - like a mower deck, and the later that used the Unidrive plow / tiller mount. So, would you rather do a "push" mount or a "pull" one?? Share this post Link to post Share on other sites
