dsmreaper 12 #1 Posted March 30 So, I had to do some terminal work, basically I needed to install shims on the top post terminals as they were tight but still loose, any who, after I began I noticed the positive of the battery was hooked strait to the frame!!! Does that mean my tractor(67' 1077) is what they call a positive ground? Anyone have diagrams on this? Share this post Link to post Share on other sites
rmaynard 17,494 #2 Posted March 30 (edited) The 1077 is a negative ground system. Edited March 30 by rmaynard 1 4 Share this post Link to post Share on other sites
pfrederi 20,992 #3 Posted March 30 (edited) It is possible that some PO really messed up. But as long as he switched the wires to the coil and you have an S/G that gets polarized when you start it ... it may work. I know regulators are sometimes listed as + or - grd. but they still sometimes work.... Is the small + terminal on the coil hooked to the ignition switch or is it hooked to the points and condenser. Edited March 30 by pfrederi 1 Share this post Link to post Share on other sites
ranger 1,860 #4 Posted March 31 Has someone fitted a positive cable, which has a larger clamp, to the negative post on the battery? That could explain why it is loose? Assuming the battery has the conical posts of course? 3 Share this post Link to post Share on other sites
wallfish 20,380 #5 Posted March 31 23 hours ago, dsmreaper said: ) is what they call a positive ground? If that's how it's actually connected, then that's what they call a mistake. That should be a negative ground system Could be someone wasn't paying attention Share this post Link to post Share on other sites
dsmreaper 12 #6 Posted April 1 On 3/30/2026 at 7:23 PM, pfrederi said: It is possible that some PO really messed up. But as long as he switched the wires to the coil and you have an S/G that gets polarized when you start it ... it may work. I know regulators are sometimes listed as + or - grd. but they still sometimes work.... Is the small + terminal on the coil hooked to the ignition switch or is it hooked to the points and condenser. What is an S/G? I am not new to mechanics or automotive work and systems, but tractors and small engines, albeit sometimes similar, are a whole new game to me. 2 hours ago, wallfish said: If that's how it's actually connected, then that's what they call a mistake. That should be a negative ground system Could be someone wasn't paying attention it is for sure hooked up backwards, I will have to check the coil like another commentor stated, I did not check the rest of the wiring, just that I have a 26 group battery and noticed the positives cable ran strait to the frame about 4 inches away!!! 14 hours ago, ranger said: Has someone fitted a positive cable, which has a larger clamp, to the negative post on the battery? That could explain why it is loose? Assuming the battery has the conical posts of course? this is possible, but both clamps were actually lose, they are the softer lead style and seems to have been over tightened previously as well, and were not down all the way on the posts either, which did not help either. On 3/30/2026 at 7:23 PM, pfrederi said: It is possible that some PO really messed up. But as long as he switched the wires to the coil and you have an S/G that gets polarized when you start it ... it may work. I know regulators are sometimes listed as + or - grd. but they still sometimes work.... Is the small + terminal on the coil hooked to the ignition switch or is it hooked to the points and condenser. I will check and get back to the post on this one. Share this post Link to post Share on other sites
dsmreaper 12 #7 Posted April 1 Yeah not sure what is going on, the + on the coil goes to the ignition switch though. You can also see the POS on the battery clearly in the photo. Share this post Link to post Share on other sites
wallfish 20,380 #8 Posted April 1 (edited) Does it start and run like that? Can't imagine it would charge the battery Kinda looks like someone slid the battery in backwards and hooked'er up. Reversing the polarity I've never tried that, yet! LOL SG for Starter /Generator of which that engine has. Edited April 1 by wallfish 2 Share this post Link to post Share on other sites
dsmreaper 12 #10 Posted April 1 24 minutes ago, wallfish said: Does it start and run like that? Can't imagine it would charge the battery Kinda looks like someone slid the battery in backwards and hooked'er up. Reversing the polarity I've never tried that, yet! LOL SG for Starter /Generator of which that engine has. Oh okay, and yes it does start and run, I haven't check the charging system while running so I can't say for sure it charges.perhaps the older models and tech were so simple it didn't matter as long as there is voltage? I definitely had the thought the battery is in backwards though when I saw how close the terminals were to the S/G though. Share this post Link to post Share on other sites
ineedanother 2,769 #11 Posted April 1 If it were me, the first step I would take would be to check polarity. If I'm not mistaken, that battery could have actually be charged backwards had it been depleted at some point. 1 Share this post Link to post Share on other sites
Handy Don 17,188 #12 Posted April 1 10 hours ago, ineedanother said: he first step I would take would be to check polarity. I recommend getting out a voltmeter and start testing. Battery first and then onward. 2 Share this post Link to post Share on other sites
pfrederi 20,992 #13 Posted April 1 I have a couple old big tractors with positive ground and old school generators and the whole thing works great... but that your coil + is fed from the ignition switch is a question. I think (not sure) they will run with the coil reversed just not well. In your case I would switch back to a negative ground. After you do make sure have 12v at the small + on the coil when the ignition switch is in run. The S/G will polarize itself the first time you start it. Does your Generator red warning light work at all?? Also from your photo it is hard to see if your regulator is wired correctly. It is easy the terminals on the regulator are marked . The 3 you can see should be F field and that wire should go to the F terminal on the generator body. There is a B and that wire will go to the + on the battery (when you redo you r system). the L load goes to the cigar lighter. There is a hidden terminal on the bottom of the regulator it goes to the A terminal on the generator body along with the heavy wire already there. 2 Share this post Link to post Share on other sites
dsmreaper 12 #14 Posted April 1 28 minutes ago, pfrederi said: I have a couple old big tractors with positive ground and old school generators and the whole thing works great... but that your coil + is fed from the ignition switch is a question. I think (not sure) they will run with the coil reversed just not well. In your case I would switch back to a negative ground. After you do make sure have 12v at the small + on the coil when the ignition switch is in run. The S/G will polarize itself the first time you start it. Does your Generator red warning light work at all?? Also from your photo it is hard to see if your regulator is wired correctly. It is easy the terminals on the regulator are marked . The 3 you can see should be F field and that wire should go to the F terminal on the generator body. There is a B and that wire will go to the + on the battery (when you redo you r system). the L load goes to the cigar lighter. There is a hidden terminal on the bottom of the regulator it goes to the A terminal on the generator body along with the heavy wire already there. I am not sure about the light, it has not come on yet any way, I will have to check the wiring and all because stranger still, I did probe it with a multimeter, and it does in fact say the positive is positive. So the battery is in backwards and still somehow works!!?? 1 Share this post Link to post Share on other sites
dsmreaper 12 #15 Posted April 1 My question now is, What would happen if I swap the battery to normal? I will look at the wiring diagram again, but if its all normal as it should be, shouldnt it be fine if I swap the battery around to how it should be connected? I just dont want to burn anything critical up since I know this stuff isnt just sitting on a shelf locally anywhere anymore now a days. Share this post Link to post Share on other sites
pfrederi 20,992 #16 Posted April 2 The light should come on the moment you turn the key to run. Not sure I understand how you tested to find out Positive is positive. Swap in another battery and wire it correctly (you can borrow it from another tractor or a car). + terminal to the heavy cable going to the ignition switch - terminal to the engine block. 1 Share this post Link to post Share on other sites
dsmreaper 12 #17 Posted April 2 43 minutes ago, pfrederi said: The light should come on the moment you turn the key to run. Not sure I understand how you tested to find out Positive is positive. Swap in another battery and wire it correctly (you can borrow it from another tractor or a car). + terminal to the heavy cable going to the ignition switch - terminal to the engine block. The light has never come on at all so probably not or isn't connected correctly. As far as the battery test, I used a multimeter and put red to red and black to black set to vdc, got a positive of almost 12 volts, when I reverse the probes red to neg and black to pos, it shows the same voltage as a negative, telling me the POS terminal is actually positive. 2 Share this post Link to post Share on other sites
953 nut 68,139 #18 Posted April 3 Here is a simplified diagram of your electrical system and how the parts and pieces interact. 1 Share this post Link to post Share on other sites
dsmreaper 12 #19 Posted April 6 (edited) Okay, so I have a little update and a question. After asking my friend and coworker who gifted this tractor to be, about the battery connection. He told me that is how the previous owner had done it as that's the only way they could get the cables to reach(I do not believe they tried hard enough!!) and connect to the battery. He also stated that whatever was changed, wiring wise, was done by the same owner. So my question is this, what exactly would you change to make it run with a negative ground? I already checked the coil wires and such and they all seem correct, I will double check them with an appropriate wiring diagram with me next time. Also, I will add that upon closer inspection, all the diagrams posted here, have 4 connections it appears on the voltage regulator, mine only has 3. I have checked and double checked, and there is for sure only 3 terminals on it in total. Edited April 6 by dsmreaper Share this post Link to post Share on other sites
pfrederi 20,992 #20 Posted April 6 Look on the bottom of the regulator there may be a A/ Gen terminal there. The three terminals you can see. They may be F B L Share this post Link to post Share on other sites
dsmreaper 12 #21 Posted April 7 2 hours ago, pfrederi said: Look on the bottom of the regulator there may be a A/ Gen terminal there. The three terminals you can see. They may be F B L I did, I didn't see any terminals there either, there is a ground strap going from under the regulator to the base of it where its mounted to the S/G but nothing else. Share this post Link to post Share on other sites
pfrederi 20,992 #22 Posted April 7 If you have only 3 terminals they will be F goes to Field terminal on the genny body, B or Bat goes to Battery +...A or Gen goes to A terminal on Genny body.. Having only 3 means it is not the original regulator...but 3 terminal ones work just fine. 1 Share this post Link to post Share on other sites
