Hayden 2 #1 Posted Monday at 07:13 PM Got my mower deck out to install and found these bracket attachments loose. One bearing was broken in half and both of them were loose in the bracket. I attached a part number, how can I track down new brackets and bearings? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,066 #2 Posted Monday at 07:50 PM If Toro has them they will be priced here https://www.partstree.com/models/c5-60sc01-toro-60-side-discharge-mower-deck-for-tractors-1988/ 1 Share this post Link to post Share on other sites
Handy Don 16,058 #3 Posted yesterday at 05:40 PM (edited) On 3/30/2026 at 3:13 PM, Hayden said: Hmmm. Per the Toro parts diagram, there is no bearing in the factory build! This looks to me like a PO drilled out the bracket to “re-round” the hole and then added bushings in the hope that they’d absorb the wear instead of the bracket. Only your caliper and some testing can determine the state of the bracket holes. If you have the skills (or know someone who does), I’d strongly consider doing the same thing again. My go-to for specific bearing/bushing sizes that I cannot find in the Hillmann drawers at Lowes or the hardware store is McMaster-Carr (although I did once get a lathe-owning friend to custom-turn a set down from a “stock” OD). Just keep in mind that the position of the bracket hole relative to the deck need not be overly precise-- ±0.125 inches is not a problem! CORRECTION: courtesy of @cleat who clarified that they are indeed bushings in the factory build. I’d still check the bracket hole for excess wear before simply adding the bushing and reassembling. Edited 6 hours ago by Handy Don Share this post Link to post Share on other sites
Hayden 2 #4 Posted 17 hours ago Sure seems like index #44 on sheet 2 is what I need. There were 2 in a local store that I got them ordered too. We will see. Thanks for the help! Share this post Link to post Share on other sites
cleat 8,834 #5 Posted 8 hours ago 9 hours ago, Hayden said: Sure seems like index #44 on sheet 2 is what I need. There were 2 in a local store that I got them ordered too. We will see. Thanks for the help! Yes, that is them. I don't know why they are called spacers in the parts diagrams but they are indeed bushings. 1 Share this post Link to post Share on other sites
gt14rider 1,081 #6 Posted 5 hours ago Those spacers are made of steel not brass. The hole in bracket needs to be restored and spacer installed or in stall bronze bushings Share this post Link to post Share on other sites
