pfrederi 21,156 #26 Posted April 22 Stator looks correct. Yellow wire is for your head lights. The dark wire should be for charging. Peel back the sleeve from the connector end yo should find the diode. That wire needs to get to the ignition switch A terminal or R terminal Share this post Link to post Share on other sites
Railboy 13 #27 Posted April 22 pfrederi, is the below Kohler Stator Trouble Shooting Guide the one I need to go by and use for the Stator that is already on the Tractor? I am going to double check things, that is for sure. But yes, thank you for the help, so this is my next question for I am inquisitive to clear it up. The Diode as you said goes to the A Accessory White Wire Rectifier Input on the Ignition. Correct? This is on the Wiring Diagram. Kohler Stator Trouble Shooting Guide I found on the RedSquare Site, which I think is for mine??? Follows... Also, I can do the lead to lead test of the Stator, but have a question if it is accurate for grounding, for I see two winds tied together and anchored to the Green Plate with a flat-head screw on the Stator that is grounding I would think??? Why the question if the Trouble Shooting Guide is accurate for mine? This is the 3b. section. See, the Stator is grounded out to the block, which is to the chassis for test 3b and will fail it, Correct? And also, read that between the leads of the Stator, in one direction with a continuity meter it can have the .1-.2 Ohms. but in the opposed direction, not, the leads will show an "open" circuit? I think I have my thoughts comprehensible with that of the Stator Image and in contrast to the below Guide. Which to me is baffling regarding the "Chassis Grounding" test??? Share this post Link to post Share on other sites
pfrederi 21,156 #28 Posted April 23 3 hours ago, Railboy said: pfrederi, is the below Kohler Stator Trouble Shooting Guide the one I need to go by and use for the Stator that is already on the Tractor? I am going to double check things, that is for sure. But yes, thank you for the help, so this is my next question for I am inquisitive to clear it up. The Diode as you said goes to the A Accessory White Wire Rectifier Input on the Ignition. Correct? This is on the Wiring Diagram. Kohler Stator Trouble Shooting Guide I found on the RedSquare Site, which I think is for mine??? Follows... Also, I can do the lead to lead test of the Stator, but have a question if it is accurate for grounding, for I see two winds tied together and anchored to the Green Plate with a flat-head screw on the Stator that is grounding I would think??? Why the question if the Trouble Shooting Guide is accurate for mine? This is the 3b. section. See, the Stator is grounded out to the block, which is to the chassis for test 3b and will fail it, Correct? And also, read that between the leads of the Stator, in one direction with a continuity meter it can have the .1-.2 Ohms. but in the opposed direction, not, the leads will show an "open" circuit? I think I have my thoughts comprehensible with that of the Stator Image and in contrast to the below Guide. Which to me is baffling regarding the "Chassis Grounding" test??? Wrong guide you do not have a 15 amp stator. 1 Share this post Link to post Share on other sites
Railboy 13 #29 Posted April 24 (edited) pfrederi, I am not certain of the Stator in the engine at this time, I have never seen it. But the Engine is on a 1987 Wheel Horse M10 Platform. So, in regards to that, are there any test I can do with the Engine Off, Engine/Tractor Connector Disconnected and I can do test with the Engine Connector to the Stator? See, that way I can also test out the new Stator I have. And if there is an I.D. method there, we will know for sure what Stator I have in the Engine Currently. But here you go. During the Engine Start, I blow the 15 amp. fuse. So, I am not sure of how to conduct the Guide that is above Test's? Why I am looking for an Engine Off, and Disconnected Engine Connector Test Guide? Thank you for your help, and hope you are having a good day, and everyone, thank you for helping. Note- Bet the Stator Leads got reversed.... Why I like to test with Engine Off, at the Connector the Stator Leads again to see if it is fried? But also, can do as I said above, test the new stator for certainty that it is fine before install. Yea I am currently using the tractor, grass season is here. Edited April 24 by Railboy Share this post Link to post Share on other sites
pfrederi 21,156 #30 Posted April 24 Since the engine runs after the fuse blows you can do the tests above. You can test your new stator #3 and # 4 Use the metal ring of the stator as the ground. Share this post Link to post Share on other sites
Railboy 13 #31 Posted April 24 pfrederi, do you know if you can take the sheathing off to the diode on the tractor with the Shroud on? That way I can trace the wires... But also, know if the Charing Side(Diode) if I got it right is connected to the White Wire Rectifier at the Ignition Side first before Testing. But yes, guess leave the Fuse alone if I do the test and real quick question for I do not know. Will the Engine continue to run with out the Positive Battery Cable Connected to the battery? Some cars do, but some do not is why I am asking on the M10? Share this post Link to post Share on other sites
pfrederi 21,156 #32 Posted April 24 A magneto engine will run with no battery Share this post Link to post Share on other sites
clueless 3,439 #33 Posted April 24 Disconnect your test light switch and the oil switch, looks like they are the only two things that would blow the 15amp fuse. Share this post Link to post Share on other sites
Railboy 13 #34 Posted April 24 (edited) Clueless, with the Engine Connector Plugged up to the Tractor, is there not a ground on either of the Stator Wires grounding out the Fuse? Why I say this, is the Ignition is still part of the equation and can be in the circuit for the charging circuit. Which is fused in, correct? By the way, I think we are way-over-thinking this. I just have two wires to hook-up, so trace them and be done, while putting in the new ignition switch, to make sure that is not a short. Edited April 24 by Railboy Share this post Link to post Share on other sites
wallfish 20,618 #35 Posted April 24 The ignition is not part of the charging system Share this post Link to post Share on other sites
Railboy 13 #36 Posted April 25 wallfish, I had read that at times internally the ignition can go bad, conducting a cross-over. Something I read in the threads.... 1 Share this post Link to post Share on other sites
pfrederi 21,156 #37 Posted April 25 Have you run the stator tests on the engine yet??? 1 Share this post Link to post Share on other sites
wallfish 20,618 #38 Posted April 25 1 hour ago, Railboy said: wallfish, I had read that at times internally the ignition can go bad, conducting a cross-over. Something I read in the threads.... Which would still have nothing to do with the charging system in a magneto ignition engine. The only problem is the engine wouldn't run with a bad magneto "conducting a cross-over" so it can't spin the magnets for the stator to work. That's about the only connection. You've also read they have nothing to do with each other so please do the diagnostics necessary to determine what is correct and what isn't. Maybe the confusion here is with a battery ignition which could possibly short and cause charging issues with a stator. IDK 1 Share this post Link to post Share on other sites
Railboy 13 #39 Posted April 25 Ok, well here is the skinny... I took the Wheel Horse to the engine builder for he had the tools to address install of the Stator, but this is what he found. He ended up putting in a new Voltage Meter and also the Ignition that I just purchased which is a Wheel Horse model. And yea it costed like a Wheel Horse. And what he found out for he just contacted me is now it is not blowing the fuse with those parts installed and started it 5-8 times with no issue and also everything is working. I am not sure why it cooked the original Stator, but have read, ignition, voltage meter or reversed wiring can do it. So, point, next week I get the mower back and now I am going to have the cutting blades sharpened, Yea! Thanks for all the input and also the pre-existing threads I read. But I am not 100% sure on what the culprit was, but anyway one of those things. Hope ya'll have a good day. 1 Share this post Link to post Share on other sites
702854boy 1,150 #40 Posted April 26 A few weeks ago I had accidentally wired my volt meter in backwards and it blew the 15 amp fuse I installed. It is possible there was an internal short in the volt meter Share this post Link to post Share on other sites
Railboy 13 #41 Posted April 26 The coincidental part of this is that this all happened once I put the engine back in after a rebuild, and a Oil Sender taken out. I ended up having to by-pass the relay for the Oil Sender not to have an issue, but at time of start-up after the engine went in the 15 amp fuse was blowing, but would start. I have read that the ignition can faulter internally between I think the rectifier input and ground and a charging lead, I am not 100% sure right now but yea, a 40 year old ignition can go bad, just coincidentally at time of the engine going in, but also yea, volt meter went shot on me, which I had read the same, it can ground out. Just a fluke, and they have been rare to me, but has happened to me and I am 55 yrs. old, so, yea, guess it happens.... But yea, I just got the Wheel Horse last grass season, so the unit is entirely new to me, and wiring diagrams and parts... Share this post Link to post Share on other sites
clueless 3,439 #42 Posted April 29 That was a long journey just to find out about the volt meter. Share this post Link to post Share on other sites
Railboy 13 #43 Posted April 29 Well, I am not certain it was the Volt Meter or the Ignition as of yet. Thing is when I get back the parts, if I get back any parts. But question is this, what is the conclusion you have based on, most often Volt Meters go and ground out vs. Ignitions? Yea, I am the Newbie here, but just wondering what has been seen being most curious? Share this post Link to post Share on other sites
