Railboy
Ok, New Topic, Wheel Horse Rectifier Ignition?
pfrederi
Stator looks correct.  Yellow wire is for your head lights.  The dark wire should be for charging.  Peel back the sleeve from the connector end yo should find the diode.  That wire needs to get to the ignition switch A terminal or R terminal
Railboy
pfrederi, is the below Kohler Stator Trouble Shooting Guide the one I need to go by and use for the Stator that is already
on the Tractor?
I am going to double check things, that is for sure.  But yes, thank you for the help, so this is my next question for I am inquisitive to
clear it up.
The Diode as you said goes to the A Accessory White Wire Rectifier Input on the Ignition.  Correct?  This is on the Wiring Diagram.
Kohler Stator Trouble Shooting Guide I found on the RedSquare Site, which I think is for mine???  Follows...
Also, I can do the lead to lead test of the Stator, but have a question if it is accurate for grounding, for I see two winds tied together
and anchored to the Green Plate with a flat-head screw on the Stator that is grounding I would think???  Why the question
if the Trouble Shooting Guide is accurate for mine?  This is the 3b. section.
See, the Stator is grounded out to the block, which is to the chassis for test 3b and will fail it, Correct?
And also, read that between the leads of the Stator, in one direction with a continuity meter it can have the .1-.2 Ohms.
but in the opposed direction, not, the leads will show an "open" circuit?
I think I have my thoughts comprehensible with that of the Stator Image and in contrast to the below Guide.  Which to me is baffling
regarding the "Chassis Grounding" test???
pfrederi
on the Tractor?
clear it up.
Wrong guide you do not have a 15 amp stator.
Railboy
pfrederi, I am not certain of the Stator in the engine at this time, I have never seen it.  But the Engine is on a 1987 Wheel Horse M10 Platform.
So, in regards to that, are there any test I can do with the Engine Off, Engine/Tractor Connector Disconnected and I can do test with the
Engine Connector to the Stator?
See, that way I can also test out the new Stator I have.  And if there is an I.D. method there, we will know for sure what Stator I have in the
Engine Currently.
But here you go.  During the Engine Start, I blow the 15 amp. fuse.  So, I am not sure of how to conduct the Guide that is above Test's?
Why I am looking for an Engine Off, and Disconnected Engine Connector Test Guide?
Thank you for your help, and hope you are having a good day, and everyone, thank you for helping.
Note- Bet the Stator Leads got reversed....   Why I like to test with Engine Off, at the Connector the Stator Leads again to
          see if it is fried?  But also, can do as I said above, test the new stator for certainty that it is fine before install.   Yea I am
          currently using the tractor, grass season is here.
Edited by Railboy
pfrederi
Since the engine runs after the fuse blows you can do the tests above.
You can test your new stator #3 and # 4  Use the metal ring of the stator as the ground.
Railboy
pfrederi, do you know if you can take the sheathing off to the diode on the tractor with the Shroud on?
That way I can trace the wires...  But also, know if the Charing Side(Diode) if I got it right is connected to
the White Wire Rectifier at the Ignition Side first before Testing.
But yes, guess leave the Fuse alone if I do the test and real quick question for I do not know.  Will the Engine continue to
run with out the Positive Battery Cable Connected to the battery?  Some cars do, but some do not is why I am asking on the M10?
pfrederi
A magneto engine will run with no battery
clueless
Disconnect your test light switch and the oil switch, looks like they are the only two things that would blow the 15amp fuse.
