Railboy 11 #1 Posted Monday at 12:48 AM (edited) Hello and yes, another thread under Electrical. I did get the Wheel Horse out today and grass cut, but of course if you know that I have been working on it, I have been studying the Electrical Diagrams of a 1987 Wheel Horse 310-8. Here is my question, which wire on the diagram "Charges the Battery? Dark Blue Wire or Tan Wire? I am looking for a voltage regulator or rectifier of some sort and want to collaborate what the diagram says, that is the ignition has a rectifier built in? I have read this on the net and the net says the ignition has a built in rectifier in it, so wanting to confirm mine. Why, if the ignition switch has a rectifier, I will not over charge the battery. Is this true? Or is there a component I am missing that needs a wire for charging the battery and this is in the diagram and I am over looking it or a wire? And yes, some work has or will be having done to the electrical, I just want to have everything in mind taken care of before I dive iny. And yes, over-charging the battery is a concern if the other work plays out correct, illuminating a short-circuit, which I will do continuity checks to find out about. Thank you for your help. Edited Monday at 12:49 AM by Railboy Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,076 #2 Posted Monday at 01:09 AM The white wire charges the battery through the ignition switch. The diode is on the Kohler side of the connector. Feel the wire for a small lump that is likely taped over - that is the diode rectifier. No regulator because in theory the stator will not put out enough current to overcharge a battery but we have seen it happen. Keep an eye on the voltmeter. Share this post Link to post Share on other sites
wallfish 19,500 #3 Posted Monday at 01:11 AM I believe it's the white wire from the engine. A 3 amp charge circuit does NOT have an external regulator/rectifier. That Magnum engine uses a diode in the wire to achieve the rectifier from AC to DC. The key switch doesn't have ANY circuitry in it, just contacts to direct current and ground. A rectifier - converts the AC current produced by the stator into DC current A regulator - regulates the current for charging a battery to prevent over charging The ignition circuit has nothing to do with the charging circuit and vise versa Starting circuit has nothing to to with either Consider them 3 independent circuits that run through 1 common key switch. 2 3 Share this post Link to post Share on other sites
Railboy 11 #4 Posted Monday at 02:33 PM Ok guys, thank you for the answers. I have been worried that in doing the following if you have not seen my other "Electrical" thread already this is what I am up to. This post I have a feeling may be a little long... I had the engine rebuilt over the winter, and in doing so the "Oil Sender" was taken out do to it is made of plastic and could break causing internal engine damage. Ok, I know I have said it and repeating it now, but for the new people, since I do not have the Oil Sender nor its Positive Circuit of the Dark Blue Wire Connected to the Light Blue Wire, is to mimic the Oil Sender by putting in a Jumper Wire. This jumper wire as I was told to do will be connecting the Purple at the Solenoid to the Light Blue Wire, which the Light Blue Wire ties into the Tan Wire to the ignition. So, have this question, if I am by-passing the Dark Blue Wire, am I getting rid of a circuit that does anything? Why I am into this post's descriptions. See, I do not have the relay that the Orange, Purple, Dark Blue, or Tan Wires run into. It was taken out by a previous owner and I do not have a seat switch, which I guess is why the relay was taken out. Also, the Clutch and PTO now tie into the only relay I have, the Short Purple Wire Relay. But to wrap this up, I was told when I do put the Jumper Wire in between the Purple Wire and Light Blue Wire, to take out the Relay the Short Purple Wire goes to from the Solenoid, for it is by-passed. So, that is why I have the question now of the Dark Blue, with no relays and the Dark Blue Wire omitted from the tractor, is this ok as long as my continuity checks of the 15 Amp. Fuse Red Wire Check out against the chassis(-)? I have been blowing the 15 Amp. Fuse, and the tractor starts when the fuse blows(do to grounding), but, you have to replace the 15 amp. fuse every time when starting. And this development started once the engine was put back in, with out the Oil Sender. So, does the Jumper work out for ya'll and I will keep my "Normal" charging System Operational of the Battery? And do not worry about the Dark Blue Wire? Also, On the Kohler side of the connector, I have a Black, Yellow and White Wire. The Blue's, the light blue and dark blue wires were cut off at the oil sender and prongs removed from the Kolher's Side of the Connector. So more or less the question, do I need to do anything with the Dark Blue Wire to repeat myself or just over-look it when I do the jumper of Purple and Light Blue? Sorry for the rambling, what I stated makes since to me, but I am a Newbie at Wheel Horse Electrical Diagrams, and plus taken direction for the Wheel Horse did great all last year's grass season, just drank oil but since putting the engine back on with out the Oil Sender and no wires from it, this has been taken place and how to fix it has been pointed out to me. And thank y'all for the advise, I have yet to have anything melt, there are no pinched wires or chaffed wires, but getting a ground to the 15 amp. fuse red wire and trying to illuminate it with out upsetting the tractor. And to pass it along, I did find a ground at the relay, at the short purple wire. Oh, after rereading this post, I do have a last question about the Stator and Magneto. When I do a continuity check between the 15 amp. fuse Red Wire, can it ground out continuity wise with either the stator and magneto with no cables to the battery? I do not know much on how stators and magnetos are wired. Thank you for your help, sorry for the long post. Just trying to get my chores layed out before me before diving in on how to go about solving the above. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,076 #5 Posted Monday at 02:49 PM Compare the wiring diagram above to this one. The dark blue wire to the oil lamp has been removed along with the battery power red to the low oil light. Magnetos are self-powered. The ignition wire simply grounds the magneto to shut it off. Do not allow any battery voltage to get to that ignition wire. It will release the magneto magic smoke. 1 Share this post Link to post Share on other sites
Railboy 11 #6 Posted Monday at 03:32 PM So is it recommended to tie the Light Blue and Purple Wire that run into the relay with the Dark Blue and Ground, there, tie those together at the connector of the relay? Also, I was told to dispose of the relay there, correct? Thing is I am not sure if I need to worry of the Dark Blue Wire? And yes, see them on the diagram for both Oil Sender and Magneto, this is the full diagram. Also, don't forget of the other relay I am already missing. On the up and up, I am going to have to do continuity checks on wires if it is more than that for my wires are all painted or something. I have blues( Dark and Light) for the oil sender, but have an additional blue that turns black and a green that turns black at the tractor side of the engine connector. The engine side of the connector is White on top, with Yellow and Black(Painted or Something) below it on the engine side. I don't mind taken the time to do continuity checks on wires to make sure I have a complete wire, but today as of right now is a wash for me to work on it. I have to open up a 10X12 Shed to get to the Tractor and have light and its raining, and I am not sure what the day may hold. I do continuity checks by using Stick Pins through the Shieldings. 1 Share this post Link to post Share on other sites
pfrederi 20,066 #7 Posted Monday at 03:49 PM (edited) Your tractor will operate with just basic wiring. Since you are already missing the seat switch I would rewire just the essentials, get it to run with out blowing the fuse and then start adding back the PTO and clutch safety switches one at time so you will know what is causing the fuse to blow, Pull the plug from the ignition switch and use temporary jumpers only for "S" run it directly to small terminal in the solenoid, The M terminal wire directly to the blue wire coming out of the engine harness. and a jumper from the battery + to the B terminal That will get it running and be able to turn it off. Then start adding things back Edited Monday at 03:50 PM by pfrederi 1 Share this post Link to post Share on other sites
Railboy 11 #8 Posted Monday at 04:15 PM Ok, I tried to follow what you said pfrederi, and the thing here is I do not want to upset the wires or mess with the backing of the original Ignition Switch. It is near 40 years old, lol... But let me get this straight, for I was told this. That is that all wires are "Positive" unless the "Ground" Symbol is indicated on the electrical diagrams. So, at the Oil Sender's Wires on the engine side of the Kohler connector that I am missing the prongs do to clipped wires of the oil sender, on the engine side, if I have this right, both Light Blue and Dark Blue Oil Sender wires are "Positively Charged" for when the Oil Sender is reading Full Oil, the Blues(Dark & Light), are polarized with Positive Power? And if so, the Dark Blue and Light Blue need to be jumped together from the Purple Wire at that connector? For what I have have been thinking is when to ask this and also in doing that, pull the last relay out, and I know, by-passing the safety switches, which for me is no biggy for now, I just need charging and starting and shutting down. And also, with the Engine/Tractor connector disconnected, no chassis continuity of the 15 amp. fuse, Correct? Then I can start, charge and shut down the engine fine? Yea, been wondering when to ask this, but seams a good time. 1 Share this post Link to post Share on other sites
pfrederi 20,066 #9 Posted Monday at 04:41 PM Not sure what you mean about positively charged. What a switch does is either complete a circuit or open it. You have continuity in one position no continuity the other. 1 Share this post Link to post Share on other sites
702854boy 590 #10 Posted Monday at 04:43 PM Since the previous owner made it all confusing and the wires are 40 years old, I'd get some new wire, I think some people use trailer harnesses, and rewire the whole thing. That way you can know easier that everything is going where it should, you'd have the reassurance that the wires are good, and if done carefully, you shouldn't harm the ignition switch any. 1 Share this post Link to post Share on other sites
pfrederi 20,066 #11 Posted Monday at 05:12 PM After market ignition switches are less than $15 1 Share this post Link to post Share on other sites
Railboy 11 #12 Posted Monday at 05:18 PM @pfrederi, well here it goes. I was told that wires on the diagram are positive, unless the negative symbol is at an end point. Like, on the only relay I have, the one with the Light Blue, Purple, Dark Blue and the Black has the Symbol to terminate into the chassis(Ground). This is illistatrated, Also, this is the relay that the Purple runs or you can say is a short wire and connects to the Solenoid. That Black has the symbol of ground. This is the illustration I want to point out of the Positive's and Negative Wires in how I was told, and also the Purple Wire I want to pick-up. So, what I am preposing is this. For, I was told that the Dark Blue and Light Blue at the Engine/Tractor Connector of the Oil Sender are Positive. And when actuated, the oil sender, it throws in a negative(ground) for no starts or low oil light, when you have low oil or no oil. True? If so, what I have now is a broken circuit do to the Oil Sender and wiring is gone, So, Connect the Purple Wire from the 1/4" Nut Post of the Solenoid to "Both" of the Light Blue and Dark Blue at the tractor side of the Engine/Tractor Connector. These are easy to find, and this way I am mimicking the Oil Sender for the Light Blue and Dark Blue will be Positive there. True? Then this coencides with mimicking the missing relay and what the previous owner did already, and also I can take out my last relay, and I do not have to touch anymore wiring for the relay is gone like the relay the seat switch went to, but the Tractor will be back to normal like last season, the Wires, Light Blue and Dark Blue are Positive at the Tractor Side of the engine connector. And like above, mimicking the Oil Switch. No more work for there is not a ground of the relay as I illustrated, it will be illuminated. I then can do my continuity checks to see what's up from 15 amp. fuse to what ever. And if there is an issue, be back, lol.. What through me is that the Dark Blue Wire is used for a couple things, and keeping this basic as I can, this is what I came up with. And so you know, the battery cables will be off, both of them. Not that you just need one, just can't afford to fry anything, parts are hard to come by. Items are being discontinued in making all of the time I am learning. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,076 #13 Posted Monday at 05:31 PM If you remove the fuse and connect a 12 volt bulb across the 2 fuse wires you will save some fuses. When the light is on the short exists because one side has battery power and the other has a short to ground. When the light is off the short does not exist. May help you find that short. Requires a blub and socket with 2 wires. Or if you have a test light put the probe to one wire and the ground clamp to the other in place of the fuse. When you get the light on you can work at finding out what will put it out. - short found. Share this post Link to post Share on other sites
Railboy 11 #14 Posted Monday at 08:57 PM (edited) Mr. Mod, I only pick-up the Positive Wire's Solenoid Side of the Fuse for a wire lead to check continuity. Thus also that way the engine is not running nor blowing fuses. The only time I blow a 15 amp. fuse is at time of starting, and why, not sure. I have found two grounds if I recall correctly, and one was a source when I disconnected the Engine/Tractor Connector. And the other when I removed the ground from the relay after the Solenoid, where the short purple wire runs into it. If you can, let me know your take on the Dark Blue Wires.. I know one is a Magneto and not to mess with, but the other is really not needed for in the modified diagram, it is taken out and to the Oil Light. So it is by-passed... So in all I can connect the Purple Wire as I have been told to do to two places to a Light Blue Wire, right at the relay with the Purple Wire at the relay, or at the Engine Connector, which to me makes it easier since, for the wiring has been messed with. Also, there at the engine connector, I am getting a full lead continuity wise from that Light Blue Wire to the Tan Wire that it is tied into that gets to the ignition, and it by-passes the original relay for the PTO and Clutch Safety's that were taken out. This is what I mean by its been messed with. Make since to you? So no need to worry about the Dark Blue Wire, Just Jumper between the Light Blue at the connector to Purple at Solenoid? Makes since to me.... And plan to test continuity before hand, and guess I will be doing that with the Engine Connector taken apart. Edited Monday at 09:10 PM by Railboy Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,076 #15 Posted Monday at 09:40 PM This is what you need - I took the seat switch out and the wires to it. Share this post Link to post Share on other sites
Railboy 11 #16 Posted Monday at 09:51 PM (edited) Previous owner took out the seat switch with the relay. Currently the PTO and Clutch Safety Switches go into the Relay after the Solenoid(short purple). But this is what I think is fine... With the Jumper connected to the Engine's Connector Light Blue to Purple I am fine, for then the only relay I have is by-passed. Which means most of my wiring is dead and "out of circuit". See, I am not sure how the wiring goes since the relay of the Seat Switch is missing. This is why my stance. Let me know if I am wrong please. Not sure if I am missing an important ignition wire? By the way, this is out of the main diagram. Edited Monday at 09:52 PM by Railboy Share this post Link to post Share on other sites
squonk 45,817 #17 Posted Monday at 10:45 PM I said it in your other thread. If that fuse blows while starting it's either your solenoid or your switch. I'm leaning towards the switch shorting out when you let go of the key after it starts. The switch and solenoid are the only things on that fuse circuit. 1 Share this post Link to post Share on other sites
702854boy 590 #18 Posted Tuesday at 12:49 AM I'd say rewire the tractor completely and get a new ignition switch 1 Share this post Link to post Share on other sites
Railboy 11 #19 Posted Tuesday at 01:46 PM I am not the wiring guy I was that of in my youth and also, don't have the supplies. And was told what to do, in the other "electrical" thread. Thing is, I am not 100% sure if there is a Solenoid issue or ignition issue, everything was fine up until the engine was put back on with out the oil sender. No 15 amp. fuses blowing all last year, just after engine was remounted. Share this post Link to post Share on other sites
702854boy 590 #20 Posted Wednesday at 09:13 PM Maybe the starter got hooked up wrong or something got pinched when the engine was placed back in Share this post Link to post Share on other sites
Railboy 11 #21 Posted Wednesday at 11:31 PM I got to trace some wires and in doing checks of them. There coated with something. Some colors you can see, but then go dark. I did not have time to mess with it today. But yes, looking at diagrams and backs of Ignitions. Cut grass the other day, so had to put the dash back on to do it, everything worked, just no charge and cooked another fuse in starting it. Have not found a chaffed of pinched wire yet, but did find the Clutch Switch Wiring, its fine. I just need to pull the plate to do a check there as well, damn coloring on the wires, can't tell which is which at certain points. I need to keep the tractor up and running, back to cutting grass once a week now for me. Share this post Link to post Share on other sites
pfrederi 20,066 #22 Posted yesterday at 11:31 AM After it starts and blows the fuse if you replace the fuse while running does it blow immediately 1 Share this post Link to post Share on other sites
Railboy 11 #23 Posted 20 hours ago I was told for I asked a person if putting a fuse into a Wheel Horse could be bad when running? I have never done it on anything to be honest, and not even a car. But, I wanted to see if the fuse would hold and do a charge. Why the question, Like the Fuse is getting a spike then fades. But he said basically that you should not install a fuse in something that is already operational(running), could cause some thing bad to happen, and could be costly. Which makes since... Share this post Link to post Share on other sites
clueless 3,364 #24 Posted 4 hours ago On 3/30/2026 at 7:49 PM, 702854boy said: I'd say rewire the tractor completely and get a new ignition switch This is the best advice for you, you have the colored wiring diagram, you know the correct ignition number. This is a fairly simple wiring diagram so get a new switch some new wires and connector and just do it and stop guessing. 3 Share this post Link to post Share on other sites
