Joshyg
Kohler 14 hp
Joshyg
Does anyone know the difference between the Kohler k321as and the k321s
gwest_ca
  • Thanks 2
WHX??
AS has the short base for short frame and later shaker plate tractors.
Edited by WHX??
JCM
Whose better than you.     :thumbs:
  • Haha 1
Joshyg
Will a k321s fit on a c145
pfrederi
You will have to remove the shakerplate set up and make a lower mount for the PTO hoop.  If the K321 oil pan isn't drilled and tapped for bolts on the PTO side you may have to use J hooks.
Pullstart
But the engine block is all the same.  I’d suggest if you have a donor engine, use its oil pan and run it.  :handgestures-thumbupright:  If not, that’s ok too.  Just make sure that the crankshaft height is where it needs to be, for the belt guard to properly clutch with the belt.
Edited by Pullstart
