Joshyg 40 #1 Posted March 25 Does anyone know the difference between the Kohler k321as and the k321s Share this post Link to post Share on other sites
WHX?? 57,628 #3 Posted March 25 (edited) AS has the short base for short frame and later shaker plate tractors. Edited March 25 by WHX?? Share this post Link to post Share on other sites
JCM 11,341 #4 Posted March 25 6 hours ago, WHX?? said: AS has the short base for short frame and later shaker plate tractors. Whose better than you. 1 Share this post Link to post Share on other sites
Joshyg 40 #5 Posted March 25 Will a k321s fit on a c145 Share this post Link to post Share on other sites
pfrederi 20,991 #6 Posted March 25 You will have to remove the shakerplate set up and make a lower mount for the PTO hoop. If the K321 oil pan isn't drilled and tapped for bolts on the PTO side you may have to use J hooks. 4 Share this post Link to post Share on other sites
Pullstart 70,985 #7 Posted March 25 (edited) But the engine block is all the same. I’d suggest if you have a donor engine, use its oil pan and run it. If not, that’s ok too. Just make sure that the crankshaft height is where it needs to be, for the belt guard to properly clutch with the belt. Edited March 25 by Pullstart 1 Share this post Link to post Share on other sites
Achto 32,243 #8 Posted March 25 3 hours ago, Pullstart said: But the engine block is all the same. Not always true. There are 2 different block configuration where the oil pan mounts. I was going to convert my pulling engine from a shaker mount oil pan to a frame mount oil pan and could not. Note: Oil pan bolts run from the bottom through the oil pan and thread into the block. This engine the bolts run from the top through the block and thread into the oil pan. 3 3 Share this post Link to post Share on other sites
Pullstart 70,985 #9 Posted March 25 Good call. Yeah, I probably knew that too.. 1 1 Share this post Link to post Share on other sites
kpinnc 18,850 #10 Posted March 25 (edited) 4 hours ago, pfrederi said: If the K321 oil pan isn't drilled and tapped for bolts on the PTO side you may have to use J hooks. If you have a drill press and tap set you can easily drill and tap the oil pan to work with a Wheel Horse direct bolt on. I've done several and they are identical to factory. I'm not a fan of J hooks for this application, but it will work so long as they don't stretch or bend. The blocks that have the tabs holding the oil pan (see below) are the ones I am referring to. Edited March 25 by kpinnc 2 2 Share this post Link to post Share on other sites
WHX?? 57,628 #11 Posted March 25 50 minutes ago, Pullstart said: Yeah, I probably knew that too. Or you woulda fingered it out toot sweet like we did ... 1 Share this post Link to post Share on other sites
WHX?? 57,628 #12 Posted March 25 45 minutes ago, kpinnc said: drill press and tap set you can easily drill and tap You lost me there for a second KP but I think I see the light. Are the bosses in the pan to do it or don't need them? 46 minutes ago, kpinnc said: J hooks for this application, but it will work so long as they don't stretch or bend. I don't think yer gonna do that to a 3/8 J bolt! Share this post Link to post Share on other sites
kpinnc 18,850 #13 Posted March 25 (edited) On 3/25/2026 at 1:22 PM, WHX?? said: Are the bosses in the pan to do it or don't need them? To match up to an OEM pan, the two holes on the PTO side that hold the pan on have to pass all the way through the pan. The factory bolt holes in the pan have a beveled cut in the bottom so drilling them with a 1/8 bit from the top on your drill press is easy and they remain centered. Then you flip the pan over and re-drill with a 5/16 bit using the 1/8 hole as a pilot. Flip the pan again and tap from the top with a 3/8 tap so the threads are continuous all the way through. Simple. Just don't do this without using a drill press. Handheld drilling tends to "walk" around and will allow the initial 1/8 drill to drift off center. Edited March 28 by kpinnc 2 1 Share this post Link to post Share on other sites
Joshyg 40 #14 Posted March 27 It might seem like a dumb question but I’m 13 trying to learn, but would it make sense to just bolt the k321s directly to the frame? 1 Share this post Link to post Share on other sites
WHX?? 57,628 #15 Posted March 28 1 hour ago, Joshyg said: seem like a dumb question Only dumb question is one that doesn't get asked. Our bad for perhaps talking over your head. Early and some late horses they did bolt a AS it directly to the frame. Later models it was deemed to make them more vibration pleasing so they came up with isolation mounts and came up with different designs to do such. You'll see this in many other brands as well. Some K models were even adapted or designed to get a AS model under a short hood where frame to hood clearance was at a premium. As such as what we call a big block in a short frame. This is an example of a AS model directly mounted on the frame. If this doesn't clear things up for you Josh ask away. We are here to help you learn. 1 Share this post Link to post Share on other sites
ineedanother 2,768 #16 Posted March 28 @Joshyg , not to create any additional confusion, but if your k321s has the correct pan for being frame mounted, I believe the only other mechanical conversion you would be faced with would be the PTO Housing Rod ("hoop") and bottom bracket for it. Notice the bottom bracket as part of a shaker plate, and the other one bolted to the mid-tach bracket when the engine is mounted on the frame. The bottom of the "hoops" are of different length as well. All are readily available parts from folks here... Share this post Link to post Share on other sites
WHX?? 57,628 #17 Posted March 28 (edited) 11 hours ago, ineedanother said: create any additional confusion, Well you just confused me Ineed ... and that ain't hard to do. I think what he means is what are you planning to do Josh? or just want to learn? INeed piced a example of a AS mounted on a what we call a shaker plate. His first pic. Where a AS is mounted on a plate with vibration isolators. Not directly mounted to the frame. Edited March 28 by WHX?? Share this post Link to post Share on other sites
ineedanother 2,768 #18 Posted March 28 1 minute ago, WHX?? said: Well you just confused me Ineed ... and that ain't hard to do. Well Jim, I do that to myself sometimes... I might have misunderstood by thinking that @Joshyg was considering removing the shaker plate from a c-145 and mounting a k321 directly to the frame. 1 Share this post Link to post Share on other sites
WHX?? 57,628 #19 Posted March 28 4 minutes ago, ineedanother said: Well Jim, I do that to myself sometimes... I go play with a FEL when that happens ... 1 Share this post Link to post Share on other sites
ineedanother 2,768 #20 Posted March 28 2 minutes ago, WHX?? said: I go play with a FEL when that happens ... I'm playing with wheel weights this evening because they're simpler and the weather is crappy 1 Share this post Link to post Share on other sites
953 nut 68,128 #21 Posted March 28 On 3/25/2026 at 6:48 AM, Joshyg said: Will a k321s fit on a c145 13 hours ago, Joshyg said: It might seem like a dumb question but I’m 13 trying to learn, but would it make sense to just bolt the k321s directly to the frame? None of us were born knowing anything, we asked a bunch of questions and learned from others. We will gladly share information with you, please ask. The K321S will be able to be bolted directly to the frame, as has been said before, the K321AS mounts to the shaker plate and that will need to be removed. 1977 and earlier C Series garden tractors used the same frame and the standard oil pan and the 300 series garden tractors (314) also shared the same basic frame and used the 321S 1 Share this post Link to post Share on other sites
Joshyg 40 #22 Posted March 28 Thanks, I was looking for a simple way to mount this engine without having to take everything off again Share this post Link to post Share on other sites
Joshyg 40 #23 Posted March 28 Whx what I would like to do is get it running smoothly, maybe get a plow, and repaint it. 1 Share this post Link to post Share on other sites
Joshyg 40 #24 Posted March 28 (edited) My dad brought home a k321s, we pulled the carb and air filter of of it and put it on my original engine. Now it’s running smoothly, no more chineseium carbs for this tractor Edited March 28 by Joshyg 1 1 Share this post Link to post Share on other sites
