FarmallFarmer09 31 #1 Posted March 22 Im currently restoring my 1971 charger 12, and i wanted to know what the best paint is for the rims. Ive heard Rust-Oleum almond or linen white, I just want to know which one looks more like the oem cream color. I also want to know where i can find the plastic dash piece for the charger 12 with the cigarette lighter hole. (2nd picture is a new one from a buddy of mines tractor.) Thanks! 3 Share this post Link to post Share on other sites
AlexR 3,056 #2 Posted March 23 As to rim paint color I used Rust-Oleum Cottage white 4 2 Share this post Link to post Share on other sites
Achto 32,035 #3 Posted March 23 I like to use IH off white. 2 Share this post Link to post Share on other sites
ri702bill 12,386 #4 Posted March 23 And I use the Rustoleum Shell White. 2 Share this post Link to post Share on other sites
squonk 47,247 #5 Posted March 23 (edited) Allis Chalmers cream or Rustoleum Almond Edited March 23 by squonk 4 Share this post Link to post Share on other sites
clueless 3,421 #6 Posted March 23 So in 12 hours you've got 4 different color choices, let's see how many more you get . 2 7 Share this post Link to post Share on other sites
JCM 11,247 #7 Posted March 23 Rust - Oleum # 7789 Canvas White Gloss Protective Enamel 2 1 Share this post Link to post Share on other sites
rmaynard 17,409 #8 Posted March 23 Just like Wheel Horse red, any red will do as long as you like it. The same goes for wheels. As long as it's not bright white, any off white will work. 5 Share this post Link to post Share on other sites
FarmallFarmer09 31 #9 Posted March 23 Would black paint look wierd on the rims 1 Share this post Link to post Share on other sites
squonk 47,247 #10 Posted March 23 2 hours ago, FarmallFarmer09 said: Would black paint look wierd on the rims Depends on the look you want. 1 Share this post Link to post Share on other sites
Brockport Bill 2,406 #11 Posted March 23 3 hours ago, FarmallFarmer09 said: Would black paint look wierd on the rims did a rehab of a C175 with the black rims 2 2 Share this post Link to post Share on other sites
sqrlgtr 3,160 #12 Posted March 24 (edited) 8 hours ago, FarmallFarmer09 said: Would black paint look wierd on the rims To each his own but definitely not my cup of tea... I use Rustoleum Canvas White. Edited March 24 by sqrlgtr 1 Share this post Link to post Share on other sites
WHX?? 57,273 #13 Posted March 24 One thing nice about our horses of a different color is if it doesn't grow on you one can always change it. 2 Share this post Link to post Share on other sites
Lee1977 7,677 #14 Posted March 25 (edited) Here is a !971 Raider with black wheels. Edited March 26 by Lee1977 2 Share this post Link to post Share on other sites
FarmallFarmer09 31 #15 Posted March 27 Would the engine get hot enough to melt normal paint? Not high temp? Share this post Link to post Share on other sites
953 nut 67,202 #16 Posted March 27 2 hours ago, FarmallFarmer09 said: Would the engine get hot enough to melt normal paint? Not high temp? The cooling fins should have ONE LIGHT COAT of high temperature paint. Paint will act as an insulation preventing the heat from being transferred to the moving air passing over them. Share this post Link to post Share on other sites
WHX?? 57,273 #17 Posted March 28 4 hours ago, FarmallFarmer09 said: hot enough to melt normal paint? No not unless you have some fin plugging that reduces cooling. For a putt around resto painting fins will have no adverse effect. If you are going to work the snot out of it yes just a light coat or nothing. No head paint no matter what the tractor is used for. This motor @Achto just painted got it with just regular paint and will only darken or burn off around the exhaust but for a show tractor will be just fine. 2 1 Share this post Link to post Share on other sites
lynnmor 8,875 #18 Posted March 28 Some engine paints will tolerate higher temperatures than the usual decorative spray paints found in hardware stores, but the colors are more limited. Share this post Link to post Share on other sites
Racinbob 13,016 #19 Posted March 28 For me the Rusty almond is too dark. White isn't my choice either. So I mixed the two. One part almond and two parts white through a cheapo HVLP is what I ended up with. 1 Share this post Link to post Share on other sites
squonk 47,247 #20 Posted March 28 Kohler, Tecky, Briggsy all painted their heads from the factory. Whilst I agree, too much paint would be a deterrent to cooling a couple of coats aren't going to amount to a hill of beans! 5 Share this post Link to post Share on other sites
WHX?? 57,273 #21 Posted March 28 (edited) I like the way no painted heads look Squonkies. The painted washers kinda pop. Dan reamed me a new one for painting the one on this 1055 but it was that really thin gold stuff. Really don't see it all said and done. Edited March 28 by WHX?? 2 Share this post Link to post Share on other sites
squonk 47,247 #22 Posted March 28 I paint them to keep the Al you minium corrosion down to a dull roar. 1 Share this post Link to post Share on other sites
Pullstart 70,425 #23 Posted March 28 On 3/23/2026 at 1:42 PM, FarmallFarmer09 said: Would black paint look wierd on the rims Hammered black here. 1 Share this post Link to post Share on other sites
