Railboy 13 #1 Posted March 21 Hello, I have a what I think is a 1986 Wheel Horse 310-8 Lawn Tractor that did wonders last year. Thing is I ran into a problem this year and trying to solve a riddle of electrical issues with it do to the engine was serviced. Thing is this, please read below... I was told at time of purchase it was a Wheel Horse 310-8 with a Magnum 10 Horse Power. And since then, I have learned through electical diagrams that maybe it is actually a 1987 Wheel Horse 310-8 but with a Stator and Magneto. But what has happened with will be going into the electrical section of the site later, is that I have a color code issue with a wiring diagram I have that the diagram shows Dark Blue wires going to the engine, but on my engine, where the connector picks up going into the Stator, mine meaning the Lawn Tractor has a Yellow Lead going into the Stator behind the Fly Wheel Tin. But in the Wiring Diagram I have, it shows all Dark Blue going to the Stator. So, thing is this, is there another wiring diagram out there with Yellow wires running in either the 1986 or 1987 Models with the Stator and Magneto? If so, I like to see them, I can down load or use the site to follow, but down loading with be great for I am not 100% convinced I have the correct diagram for it shows Dark Blue wires running around and into the Stator, and at the Stator Connector, mine on the Stator side of the connector, picks-up as Yellow, which is not on my diagram. Thank you for your time, and yes, having an issue with Blowing a 15 Amp. Fuse, which is on my current diagram, which is what was in the unit at time of purchase and all last season with no issue. All help will be greatly appreciated in either confirming the year, diagram and or current set-up. Dug into the mower today today, and did not get anywhere but questions, and yes, I have read through the forums, but with no luck. Trying to find out why my 15 amp. fuse holder is grounding out and frying fuses at time of starting. Runs, but fuse fries so no battery charging though stator, and magneto charges so that supplies spark plug power. Have not melted any wires yet either. But one step at a time, first ID the year but I do know it is a 310-8 with the Magnum 10 Horse Power, Plus- Stator used and Magneto. Thank you for your help and reading... Share this post Link to post Share on other sites
JCM 11,470 #2 Posted March 22 to Someone will be along to help you out. Share this post Link to post Share on other sites
oliver2-44 11,848 #3 Posted March 22 Tractor wiring diagrams typically show the wire color of the wires provided by the tractor manufacture. Wires provided by the engine manufactor are typical a different color that the tractor wires. There is usually a plastic connector where these wires change color. I have seen white or yellow wires coming from a Kohler stator. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,557 #4 Posted March 22 Will guess you have a 1987 model 21-10K804. The engine wiring was supplied by Kohler so not illustrated in the Wheel Horse diagrams. Going to the Kohler service manual found their diagram. The magneto is self-powered and the lone ignition wire to the ignition switch grounds the magneto to shut it off. Do not allow any battery voltage into the ignition wire. The wiring diagram shows a diode to protect the magneto but have never seen one. The yellow wire should connect to the dark green that provides AC to the lights only. Added tractor wiring to engine wiring 2 Share this post Link to post Share on other sites
Railboy 13 #6 Posted March 22 Hello, I have or had planned to get into the "Electrical Forums" section of the site to find out a question, but looks that some of ya'll have gathered here since we are talking electrical plus finding out that I do indeed have a 1987 Wheel Horse 310-8 through the model number under the seat. So, to ask, is it often and also do to age, that the relay that follows the fuse which on my 1987 is a 15 amp. fuse also indicated by my diagram I have from an engine builder, that the relay has failed? Just wondering how often ya'll have seen the relays to go out, or "stick" inside? I have a grounding out of the positive lead from the battery to the 15 amp. fuse, thus blowing it. Let me know how to precede, I plan today to gather off the relay I see the fuse going to, its ID Relay Model Number to order one today. Also, do most of ya'll just browse the internet for parts? Meaning random venders? Thank you for ya'lls time and last night's updates on info and all and thank you for the welcome. 1 Share this post Link to post Share on other sites
Lee1977 7,813 #7 Posted March 22 According to the 1987 310 wire degram. The dark Blue wire is the kill wire to the magne termal on key switch. the white wire is DC to accsories termal on key switch. The other wire is AC goes to the head light switch. Share this post Link to post Share on other sites
Railboy 13 #8 Posted March 22 On average how often does the "Key Switch" go bad? Also, the "Rectifier" and the starter "Solenoid" go bad? Just wondering why I had a good season with it, not blowing a 15 amp. fuse, and now it is? It does have a 5 amp. fuse, which is staying fine. Thank ya'll for ya'll's input. And yes, I know I have not gone to the "Electrical Section" yet, but this General Section I am getting some great input. Thank ya'll for that. Share this post Link to post Share on other sites
953 nut 70,662 #9 Posted March 22 According to the diagrams the 15 Amp fuse feeds power to the ignition switch and the test switch for the low oil test light. If you have a good 15 amp fuse in place and pushing the test switch eliminates the oil level light then the wires from the battery through the fuse all the way to the light appear to be good. Typically the low oil relay only receives power to its coil if the oil level is very low. With sufficient oil level, the ignition switch is in the start position with the PTO off and the clutch pedal depressed the solenoid should closer and the starter turn over. Could a 38 year old relay develop an internal fault, yes it could but it is much more likely that the insulation on a wire has become compromised. At what point in your operation does the fuse blow? Is it related to the oil level being low? Is it when the key is placed in start without the clutch being depressed? Is it when the clutch is depressed with the key in start? The more specific you can be t5he greater the likelihood we can help diagnose it long distance. Your low oil relay should be a metal can type relay, part # 106833, which has three terminals. There was a service bulletin changing over to the typical automotive five terminal relay at some point, see below. Share this post Link to post Share on other sites
Railboy 13 #10 Posted March 22 To be on the up and up, everything worked fine up till I had the engine "Freshed-Up". I had it rebuilt for I was going through a Quart of Oil every like 4 hours of use. So, the Fuse started to blow at time of engine being put back in. Thing is that was altered, and should be fine, is the "Low Oil Sender" was pulled out and wires cut. So, I have no "Negative" lead going to the rest of the Diagram. And, though the way I understand it, the "Low Oil Sender" "Grounds Out" when you have low oil. And to bear with me, the "Oil Sender" was taken apart at time or Rebuild, so that the "Plastic" of it would not break apart in the engine while running and cause internal engine damage. So, I just have the "Backing" or the "Oil Sender" screwed back in the case, with wires cut. And if I have this right, when the sender did or could read normal, a ground is complete? Correct? I pay close attention to oil levels and all, just one of my habits, but since the "Oil Sender" is made of plastic, it was taken apart and disposed of in my engine, the Magnum 10 Horse Power. But yes, I am looking for all the switches in the unit now. My "Seat" switch was disabled before I purchased the Lawn Tractor. I have not found a "PTO" Switch yet, or, the Clutch Engagement Switch, but did find the "Brake Actuator" switch through the Gear Shifter area below the seat. And yes, looking for wires that can be even "Rubbed" bear or broken internally in there shielding and not getting continuity? But yes, I have worked on many projects with metering things, and know checking for continuity takes time, for there is no line power. It would just blow the fuse anyway. And yes, I can start the engine, and runs great, with the magneto powering the spark plug. But at time of cranking it over is when the 15 amp. fuse pops. And yes, seen a few diagrams, and my fuse selection should be spot on, and unit came with it plus worked out over all last season. But yes, if anyone of ya'll know duration's of how long histories of the above components can last, just let me know, like the "Key Switch", ect. Thank you for reading, yes, there cool units to speak on and they serve a purpose that is great, May as well keep them maintained and functional, plus there just cool, lol... Wheel Horse, yep, to be on the up and up here, I purchased a small home with some land, and the wheel horse does wonders and with the internet have have found a few parts I have needed to maintain the unit, so did an engine rebuild on it, to get another 20 years of life out of the Unit. Thank you and yes, I hope to share knowledge in the future, there are things I am learning and net locations of people for parts plus venders. Hope ya'll continue to have a great day, summer is coming.. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,557 #11 Posted March 22 Added Kohler wiring to the Wheel Horse wiring. 1 Share this post Link to post Share on other sites
Easton Rich 1,297 #12 Posted March 22 As you can see wiring in these is super simple. Take some sit down and go through it, check all connections. Anytime I have problems with wiring, I go ahead and replace it, it'll only take a few hours. Share this post Link to post Share on other sites
953 nut 70,662 #13 Posted March 22 18 minutes ago, Railboy said: I am looking for all the switches in the unit now. My "Seat" switch was disabled before I purchased the Lawn Tractor. I have not found a "PTO" Switch yet, or, the Clutch Engagement Switch, but did find the "Brake Actuator" switch through the Gear Shifter area below the seat. The PTO switches are located inside the steering tower, removing the battery will make them more accessible. The clutch switch is located on the right side of the tunnel between the operator's legs, belt guard needs to be removed to see it. With the low oil switch being removed you should be able to connect the light blue and purple from the low oil relay and eliminate the rest of the wires to that relay. Share this post Link to post Share on other sites
Railboy 13 #14 Posted March 22 On the Light-Blue wire that you want me to connect, is that a positive wire or negative? See, the wires from the "Oil Sender" were cut off, and wiring prongs removed from the connector of the engine but "Stator" wires go into. Just trying to see and like you said, there is not much to go wrong. And I think from what I have read and seen the "Oil Sender" wires were (-) based. Do not know if this could be "Blowing the Fuse", which to me does not seam likely? But have a quick question on the Clutch Switch. If I can start the engine and run it, the Clutch Switch should be fine and no reason to pull the belt guard off to check it? But both the Clutch Switch and PTO Switch should be examined do to wiring rubbing and all? I really do not want to be opening a bag of worms up and creating more havoc, lol.. But up for investigations. Thing is, that I can not see in my diagrams is the "Polarity" of the wires, thus leading to the Blow Fuse? There is no smell or smoke when the fuse pops, just a Blown Fuse that you can see in the Fuse itself. Share this post Link to post Share on other sites
953 nut 70,662 #15 Posted March 22 Is the low oil relay connected to anything? The wires in the red circle would be the wires from the low oil switch, they should be gone leaving only the light blue and purple wires on the relay. Polarity is not an issue. 1 Share this post Link to post Share on other sites
Railboy 13 #16 Posted March 22 (edited) 953 Nut, yes the wires have been cut-off at the "Oil Sender", and thus nothing going to the Connector were the "Stator" wires go into the engine connector of the "Stator". Is this bad, for as you said, there is no Polarity going to the Light Blue or Purple wires, no wiring present to reconnect them to the Light Blue or Purple? Thing is this, I have seen that the polarity of the "Oil Sender" coming into it is "Negative". is this true? I can do some simple test, but either grounding or positively charging the Light Blue or Purple, but with no Polarity indicated as the Diagrams said, and reading and hearing that the "Oil Sender" was a "Ground Based"(-) circuit, why the worry, seeing that the above is true, that the input of the "Oil Sender" is a negative lead. Thus the only input into a circuit would be negative into the Light Blue or Purple wire. Is this the direction I need to seek for the Light Blue or Purple wires? Please explain, basically lost here for it can or could complete a circuit of a relay or something else. in that it would keep the Fuse from Blowing? Thank you for your input, the Wheel Horse is a new unit to me and been into a crash course of diagrams and learning the electric's of them, trying to beat the grass season being in Virginia. Yea, with out a "Key" of wire color corresponding to polity of the diagrams has been to me the "uphill" fight. Thank ya'll for working with me. Edited March 23 by Railboy 1 Share this post Link to post Share on other sites
Railboy 13 #17 Posted March 23 (edited) 953 nut, there are no wires from the "Oil Sender" to connect. There cut at the outside of the sender at the block and removed from the wiring diagram thus illiminated from the connector of the "Stator" Wires of the connector of the engine to the lawn tractor, (Wiring). From what I know, there is no big deal that the "Oil Sender" wires were removed, there Negative based. Meaning, when the "Oil Sender" actuates, it would complete a "Negative" Circuit to I think, shut down the tractor and or illuminate the Low Oil Light(Test Light). So, no big deal there missing, the "Oil Sender" leads connecting anything. And what they did was to complete a circuit to trigger a Postive Pole on a relay to illuminate the Light and from what I have heard, the engine either does not start or cuts off. But the circuit going through the "Oil Sender" is a negative lead that is isolated from the block until the "Oil Sender" actuates. Edited March 23 by Railboy 1 Share this post Link to post Share on other sites
oliver2-44 11,848 #18 Posted March 23 8 hours ago, gwest_ca said: Added Kohler wiring to the Wheel Horse wiring. What is indicated as "black wires" or wires with the "triangle going to ground "on this diagram are negative. Some of what looks like black wires on the diagram are just that piece/part directly bolted to the tractor chassis (so no actual wire exist) and thus grounded through the chassis. All other wires are positive. 2 Share this post Link to post Share on other sites
Railboy 13 #19 Posted March 23 (edited) So the Polarity of the Light Blue wire to tie into from the "Oil Switch/Sender" is what? Positive or Negative? This is what is missing. When the "Oil Sender" was taken out, all the wires were cut at mount to the block coming out from there. So, just wondering what ya'll may know to tie the Light Blue into at the Tractor's Side of the Engine Connector, Positive or Negative? And ya'll have read what I know. The "Oil Sender" is Ground based, but I could be totally wrong, thus blowing fuses... So Oliver 2-44, you are saying that going into the Light Blue is a Positive Input from the "Oil Switch" for normal operation of the lawn tractor in action? Edited March 23 by Railboy 1 Share this post Link to post Share on other sites
Railboy 13 #20 Posted March 23 (edited) @Oliver2-44, @953 Nut, I am reading over the diagram this morning and see that there are 3 wires attached to the Oil Sender on the engine. Looks like a Dark Blue, Light Blue, and a Black wire(Ground). Can you go over how the Oil Sender Switch works when you have full oil and indicate how the wires are polarity wise please and what to "Energize" with I believe what ya'll are saying, Positive Power? Thank you, sorry for the submissions, but on the learning curve. Edited March 23 by Railboy 1 Share this post Link to post Share on other sites
JCM 11,470 #21 Posted March 23 @Railboy FYI Type the screen name who you want to answer your response as I did to get your attention. It works . 1 Share this post Link to post Share on other sites
953 nut 70,662 #22 Posted March 23 21 hours ago, oliver2-44 said: What is indicated as "black wires" or wires with the "triangle going to ground "on this diagram are negative. Some of what looks like black wires on the diagram are just that piece/part directly bolted to the tractor chassis (so no actual wire exist) and thus grounded through the chassis. All other wires are positive. As @oliver2-44 has said polarity is not an issue on a . Various switches throughout the wiring system turn on or off to control battery voltage from the battery to ground. Some go through the 15 amp fuse and ignition switch first and then on to a component like the solenoid, volt meter or hour meter. Your low oil switch has been removed, it no longer exists and you can foregit it ever existed. The low oil relay will not activate because the wires to the switch are gone. There should be a low oil RELAY (probably the three wire metal relay) with a light blue wire coming from the clutch switch and a purple wire going to the small terminal on the solenoid. Connecting these two wires will allow the start signal from your ignition switch to go through the PTO switch (PTO OFF) and then through the clutch switch (clutch pressed down) and activate the starter solenoid which in turn will activate the starter. I do not own this model year 310-8 so can not say for sure where the relay is physically located but my guess is it would be mounted somewhere below the battery. 1 Share this post Link to post Share on other sites
Railboy 13 #23 Posted March 23 953 nut, so in a nut shell, I can eliviate the oil sender from my puzzle of the 15 amp. fuse blowing? Thing is this, that is the only thing that has changed and then after the fuse has been blowing. And wonder why? I am lost, ran great with non fuse issues all last season till the engine was rebuilt and oil sender yanked. And if I have this right, you on board that a relay or something went, frying the fuse. And, to pass it along, the fuse blows during start up, but the engine runs fine do to magneto, but the voltmeter does not charge do to blown fuse. 1 Share this post Link to post Share on other sites
953 nut 70,662 #24 Posted March 23 Time to look over all of the wires to see if something got crimped or insulation cut. 1 Share this post Link to post Share on other sites
Railboy 13 #25 Posted March 23 (edited) Where about in the Belt Tunnel for the clutch is the switch for preventing to start the engine set-up at? Thinking I may have cut it with the cover or belt. I did have to pull that apart, I just pulled the cover, but never saw the switch. And it is a 1987 Wheel Horse 310-8. All other wiring looks for so far. But, I did not pull the battery out to get the battery tray out. What do you advise on a good day? Edited March 24 by Railboy 1 Share this post Link to post Share on other sites
