FLtractor
Pulling Sulky behind 856
squonk
Absolutely! Looks like a Gravely sulky
  • Like 5
ri702bill
Nice! You may wish to improve the size & placement of the foot rest though...
FLtractor
Posted (edited)
If I drive extra careful slow and on flat ground… could I put the sulky behind a metal yard wagon that weighs a couple hundreds pounds of steel. Big huge  turf saver tires.  Welded hitch holes for pins on each end and handle on one that pivots the front wheels.. it was a roofing cart used to move materials on buildings.. I could put tractor- roofing cart- sulky.
Thinking along the lines of having someone help me do yard work, load cart, and just be able to hop off the sulky similar to hangin on back of recycle truck ect
Edited by FLtractor
FLtractor
Posted (edited)
Good points, will have to see in person. Recommendation on what tires I should put on? Such those ones that never go flat
Edited by FLtractor
WHX??
Any 4/4.8-8 tires. Wheelbarrow tires you want to keep the cost down. Be sure to tube them.
  • Like 5
FLtractor
Is this what the orginal color scheme would have been? Might have to see about getting one of those seat cover online that fits and looks the same colors
ri702bill
If it were "The Mother-in-Law" seat, the tongue would have been about 4X longer... :ROTF:
  • Haha 7
squonk
Plus an "Emergency Quick Release!"
  • Haha 5
sqrlgtr
I been watching James Bond movies in order they were made, and my first thought was ejector seat. Still believe Sean Connery made the best 007. Haven't decided which super villain is my favorite though
Retired Wrencher
Posted (edited)
I agree with you on Sean being the best.I believe I have all of the older J.Bond moves. These are on VHS. They are still a thrill to watch. Back in the 60,s I had the slot racing J.B. set. Today that would worth some $$.
Edited by Retired Wrencher
Lane Ranger
You need to add a basket on that sulky to place all those parts you end up finding at Shows and Swap Meets!
You won't regret adding that during your redo!
FLtractor
What kind of hitch pin to connect the sulky to the tractor hitch? This kind?
squonk
That used a ball and clamshell connection. cut that off and make your own for the Horse.
Gravely Walk Behind Sulky Clamshells Ball Roller Rest Hitch Parts Lot (180)
FLtractor
Posted (edited)
Have a picture of what kind I should look for? Seller about 50 miles away is selling this.. says it weighs 15lbs.. asking $20.00. Would it be ideal to mount on the sulky, if so how would I go about doing so?
Edited by FLtractor
FLtractor
Interesting, haven’t ever seen one
Streetrodchev
Put a handle/ grab bar of some sort on there.
The first time my wife rode on our sulky, I let out the clutch and she almost fell off backwards.
FLtractor
Posted (edited)
Yea I was thinking of one of those faucet with the coil that bends.. yet a handle that’s somewhat flexible with two handlebars each side so it’s rigid to be safe yet could bend to reach the sulky rider hands. If that makes sense, could probably just find a piece of rebar and add a T handle at the top and it would do the same ideal easier.
Edited by FLtractor
gwest_ca
Be nice if you could find a ball for the clam shell hitch.
They mount upside down to a normal trailer ball. The drawbar on the sulky is 1-1/4" schedule 40 water pipe. Slide the clam shell into the pipe and insert the pin to hold them there. This was used with a heavy front attachment on the 2-wheel tractors.
The other casting with the hole in it is for when no front mounted heavy attachment was used. It is called a roller rest and the roller on the front rides on a flat bar to keep the 2-wheel tractor and sulky horizontal. The roller allows for turns.
FLtractor
Posted (edited)
So if I kept the clamshell on the sulky.. the ONLY piece I need to safely tow it with the tractor is this ball here and it goes on upside down with the nut on top- just sits in the clamshell.. nothing else needed? More than I’d like to spend, gonna see if I can find cheaper option.. would this chrome ball 2 3/4 on eBay work as well upside down?
Edited by FLtractor
FLtractor
Would it be safe and good ok idea to have : tractor - sulky - yard cart or wagon attached to sulky rear bolt hole on frame??
