hotajax 230 #1 Posted 9 hours ago So I have a 48 inch deck to fit on my 314-8, The zerk for the center pulley ( i. e. the big pulley that drives 2 belts ) has a broken zerk. Center of the zerk that fits into the grease gun snapped off, and I have a big open hole the piece that's still threaded into the pulley. Do you gents know the thread sizes for the zerk that goes into the pulley? I'm sure it's a common size, but I don't know what it is. Thanks. Share this post Link to post Share on other sites
ri702bill 11,388 #2 Posted 8 hours ago Most likely 1/4-28 fine thread - maybe 1/8 NPT. You can try using an Easy-out to extract the broken piece. 4 Share this post Link to post Share on other sites
Chaz54 99 #3 Posted 6 hours ago Should be a 1/4-28 thread. Share this post Link to post Share on other sites
Lee1977 7,572 #4 Posted 4 hours ago The lift arm hits that zerk. Some of the later model Wheel Horse had a hole drill in the lift rod for a waher and clip pin to keep it away, 1 Share this post Link to post Share on other sites
Ed Kennell 45,032 #5 Posted 2 hours ago I always replace that zerk with a set screw after greasing. Share this post Link to post Share on other sites
