hotajax 284 #1 Posted March 13 So I have a 48 inch deck to fit on my 314-8, The zerk for the center pulley ( i. e. the big pulley that drives 2 belts ) has a broken zerk. Center of the zerk that fits into the grease gun snapped off, and I have a big open hole the piece that's still threaded into the pulley. Do you gents know the thread sizes for the zerk that goes into the pulley? I'm sure it's a common size, but I don't know what it is. Thanks. Share this post Link to post Share on other sites
ri702bill 13,059 #2 Posted March 13 Most likely 1/4-28 fine thread - maybe 1/8 NPT. You can try using an Easy-out to extract the broken piece. 5 Share this post Link to post Share on other sites
Chaz54 102 #3 Posted March 13 Should be a 1/4-28 thread. Share this post Link to post Share on other sites
Lee1977 7,772 #4 Posted March 13 The lift arm hits that zerk. Some of the later model Wheel Horse had a hole drill in the lift rod for a waher and clip pin to keep it away, 3 1 Share this post Link to post Share on other sites
Ed Kennell 47,320 #5 Posted March 14 I always replace that zerk with a set screw after greasing. 4 Share this post Link to post Share on other sites
WHX?? 58,124 #6 Posted March 14 I'll go with the 1/4 -28 crowd and a 5/16 wrench if there is anything left to bite on. If not a easy out and it should come out fairly easy with the grease being there. They are usually not that tight. 1 Share this post Link to post Share on other sites
WHX?? 58,124 #8 Posted March 14 That's a handy one Paul. Share this post Link to post Share on other sites
hotajax 284 #9 Posted March 14 14 hours ago, Lee1977 said: The lift arm hits that zerk. Some of the later model Wheel Horse had a hole drill in the lift rod for a waher and clip pin to keep it away, I'm not that guy that's lucky enough to have the improved configuration. Share this post Link to post Share on other sites
hotajax 284 #10 Posted March 16 On 3/13/2026 at 5:13 PM, Chaz54 said: Should be a 1/4-28 thread. Chaz: I yanked out one of the good zerks, and the one that came out was that size, but it looked tapered. It's only 1/4 " of thread that goes into the top of the pulley. Not much to hold it. Is that correct - tapered? Thanks. Share this post Link to post Share on other sites
WHX?? 58,124 #11 Posted March 16 Yes they do look tapered. There is a long and a short style. The short style there isn't much for threads. Share this post Link to post Share on other sites
