ri702bill 13,392 #1 Posted March 13 (edited) We take our gas dryer down off the pedestal it shares with the washer once a year to remove the back, front & drum to give it and the vent hose a through cleaning. It is a PITA to grab it from the rear, so I added a pair of Garage Door Handles. Truss head screws, Thick fender washers & nylock nuts. Much better... Edited March 13 by ri702bill 10 7 Share this post Link to post Share on other sites
ebinmaine 81,281 #3 Posted March 13 Nicely done sir. 1 1 Share this post Link to post Share on other sites
squonk 48,427 #5 Posted March 13 Keep one of these Thermal fuses in stock. My local appliance store has these in a bushel basket out back! They normally burn out on a late Sat afternoon or Sunday! 4 1 Share this post Link to post Share on other sites
peter lena 10,125 #6 Posted March 13 @ri702bill nicely done on that !! , no matter what , a repetitive problem is , its showing you the way , to correct it , make it better . https://www.google.com/search?q=screw+in+eye+bolt+rings&rlz=1C1CHBF_enUS866US866&oq=screw+in+eye+bolt+rings+&gs_lcrp=EgZjaHJvbWUyBggAEEUYO added these to my shed framing , for a spring hook to hold my mower decks off season . makes heavy awkward holding easy . out of the box , pete 1 Share this post Link to post Share on other sites
ri702bill 13,392 #7 Posted March 13 2 hours ago, squonk said: Keep one of these Thermal fuses in stock. My local appliance store has these in a bushel basket out back! They normally burn out on a late Sat afternoon or Sunday! The "word on the street" is that newer Kenmore dryers were cost reduced where the thermal fuse is now inside the plenum and non-serviceable for singular replacement. You now need to drop a pair or Bemjamins for the whole plenum assembly - did i mention it is also not a take-apart design to allow cleaning anymore..... 1 Share this post Link to post Share on other sites
Beap52 2,537 #8 Posted March 13 I'm in the process of replacing the drum rollers for the third time in daughter's dryer. It get's a lot of use with family of five. This time I'm replacing the "axles" the roller rotate on which requires digging quite a bit deeper into the machine. I'm thinking about using dry graphite on the "axles". Of course, replacing rollers means deep cleaning that otherwise wouldn't get done. It irks me that there seems to be planned obsolescence in machinery. I'm sure two dollars more for sealed bearings would make sure they'd last the life of the machine. Those handles are a great add-on. 1 Share this post Link to post Share on other sites
ri702bill 13,392 #9 Posted March 13 19 minutes ago, Beap52 said: It irks me that there seems to be planned obsolescence in machinery. I'm sure two dollars more for sealed bearings would make sure they'd last the life of the machine. Perhaps sealed ball beraings may not be the right choice here due to the proximity of heat involved... And as for the first part, something I learned from breaking parts on our circle track car..... Replacements parts are only as good as the parts they replace.... 1 Share this post Link to post Share on other sites
WHX?? 58,388 #10 Posted March 14 6 hours ago, ri702bill said: not a take-apart design Everything is take apart with the right tool ... 1 2 Share this post Link to post Share on other sites
squonk 48,427 #11 Posted March 14 We used to have a good used appliance store here. Bought Washers, Dryers, Stoves and Fridges from them with great results. They supplied parts and I bought quite a bit from them for the hospital fridges. They closed during covid. The real cool thing was getting a used dryer and taking the front off and digging thru the front seal for treasure. Coins, earrings, screws, paperclips, wire nuts. all sorts of stuff! Share this post Link to post Share on other sites
peter lena 10,125 #12 Posted March 14 @Beap52 on the roller issue , would zero in on the rotational drag , repetitive failure , routinely remove bearing side shields , and clean out original lube , lucas x tra HD green chassis grease , repack , 550 deg flash point / polyurea rating , retains grease . never had a repeat bearing failure with this , transition . all my decks and related pulleys / spindles , are failure free , Walmart $ 8 , do not count on ORIGINAL SEALED BEARING LUBE , KNOW WHATS IN THERE , my mule drive set ups spins by hand , just a suggestion . pete 1 Share this post Link to post Share on other sites
peter lena 10,125 #13 Posted March 14 @Beap52 used to regularly service , drum conveyors in maintenance , COLLECTIVE DRAG was the typical cause , every / any incremental hang up , would eat the drive set up , typically operators would love that ? can,t get the product out , shut down the system , be on break / sleep on midnights . thats my insight on belt driven anything , pete Share this post Link to post Share on other sites
Handy Don 17,735 #14 Posted March 14 16 hours ago, WHX?? said: Everything is take apart with the right tool ... Yep. The putting back together, well, maybe not! 3 Share this post Link to post Share on other sites
squonk 48,427 #15 Posted March 14 17 hours ago, WHX?? said: Everything is take apart with the right tool ... 1 Share this post Link to post Share on other sites
