horseman with no horse 67 #1 Posted March 12 im wondering if i can stick my 16 hp side cover on my 18 hp as my 18 has a missing dipstick tube, will the crank fit? and will the dipstick be accurate? Share this post Link to post Share on other sites
horseman with no horse 67 #2 Posted March 12 also how do i get the friggen pcv that sits in the valley off? its got one long bolt and idk if it pulls right off or slides, or what. i reefed on it and cracked the nipple on it the the pcv hose goes on Share this post Link to post Share on other sites
horseman with no horse 67 #3 Posted March 12 (edited) the nipple on the PCV question Edited March 12 by horseman with no horse Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,154 #4 Posted March 12 We may have the B&S service manual but do not know the model and spec number of your engine. Post those and will link you to it if we have it. This may be it 1 Share this post Link to post Share on other sites
Achto 31,582 #5 Posted March 12 To my limited knowledge, I believe the 16 & 18 hp blocks are the same. 1 Share this post Link to post Share on other sites
horseman with no horse 67 #6 Posted March 12 they are not the same, the bore and stroke are different the front of the crank where it goes into the babbit is different and briggs made 3 different size o rings for the sump cover to block for the oil pressure. which now that im thinking about it is anther factor. im gonna get some model numbers to help narrow it down 1 Share this post Link to post Share on other sites
horseman with no horse 67 #7 Posted March 17 350447 for the 18 hp, and 303447 for the 16 hp Share this post Link to post Share on other sites
kpinnc 17,909 #8 Posted March 17 On the horizontal shaft Vanguards, the PTO side cover (bearing plate) are the same 12.5 to 23hp. I have 14, 16, and 23hp models and the bearing plates interchange. I can't verify the vertical shaft engines because I only have one small block 16hp vertical. That being said, they probably will interchange. Vanguards use many common parts. 2 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,154 #9 Posted March 17 8 hours ago, horseman with no horse said: 350447 for the 18 hp, and 303447 for the 16 hp That manual has you covered for the 303400 and 350400 series. 1 Share this post Link to post Share on other sites
horseman with no horse 67 #10 Posted March 17 (edited) 14 hours ago, kpinnc said: I can't verify the vertical shaft engines because I only have one small block 16hp vertical. That being said, they probably will interchange. Vanguards use many common parts. vertical did have a different oil pump setup and dipstick. but knowing the horizontal is the same makes me feel better Edited March 17 by horseman with no horse Share this post Link to post Share on other sites
horseman with no horse 67 #11 Posted March 18 i looked at the part number and the o ring that happens to line up with the date code for my 16 hp will not fit on the date code of the newer 18hp cover. i ordered an o ring for the 16 hp based off the model and spec number. i will caliper it and compare it to the 18 to see which is the"bigger of the two style" Share this post Link to post Share on other sites
horseman with no horse 67 #12 Posted March 18 as for the breather it looks like it just gets pulled straight off based on the manual? Share this post Link to post Share on other sites
horseman with no horse 67 #13 Posted March 24 upon looking at the parts breakdown the o rings for the side cover on my particular model 30 and 35 use different numbers and are in fact different upon visual inspection so they arent compatible. Share this post Link to post Share on other sites
