wh315-8 638 #1 Posted March 9 109791 ASSY UPPER LINK, seeking this part or the Measurements would be a great help. Share this post Link to post Share on other sites
Thor27 892 #2 Posted March 9 (edited) I don't know if this will help you, but it's the best I got. 3"×3/8 flat strap. 14" wide between uprights, ends have 2x 3/8" holes on 2" centers. The uprights on D stuff is 3" narrower. I widened one from a D, but haven't made the actual mounts for the center link yet, but they will just be flat bar. I'd have started from scratch but have no way to bend that heavy of material. Mine will be a dedicated loader tractor so there is no provision for a pto. I've been chasing that part for years. It's rare like bigfoot, There is a set on page 2 of the classifieds right now, linked below. I'm trying to buy these, but have no confirmation from seller at this time and dont know that it will happen. I don't restore, so correctness may be more important for you to pick this up. There are only 4 parts that are unique to a 195, the others are same as a D. #109791. (#11 on tpl) #109787. (#1 on tpl) 2x #109786 (#2 on tpl) these are on a 2-1/2 center, the D's are on a 2" center https://www.wheelhorseforum.com/classifieds/for-sale/wheel-horse-d-seriesc-195-3pt-hitch-r14399/ Edited March 9 by Thor27 Add + link 2 Share this post Link to post Share on other sites
wh315-8 638 #3 Posted March 9 (edited) Thank you for those measurements. I won’t interfere with your possible purchase of the ad you sent, if it’s who I think it is, he is a very busy man and will answer eventually. I have a D also and could see there is a difference just realized that the C stuck out further from pictures. So your information helped me see that. The PTO is even more Rare but I was able to round up and make parts to put one together. Most likely will build this part also, factory standard isn’t a must at this point. I believe the last year of the C195 was only year with 3 point as standard equipment, reckon WH was clearing out the inventory. Thus why we can’t find one. Thanks for pointing out the difference in the pillow blocks, I bought a set and will have to see what I got and improvise. Edited March 9 by wh315-8 Add info 1 Share this post Link to post Share on other sites
Thor27 892 #4 Posted May 26 I did get my hands on one of these, here are the measurements I didn't have. It does sit farther out than I thought. Share this post Link to post Share on other sites
peter lena 10,065 #5 Posted May 26 @Thor27 https://www.google.com/search?q=channel+steel&rlz=1C1CHBF_enUS866US866&oq=channel+steel+&gs_lcrp=EgZjaHJvbWUyBggAEEUYOdIBCTE3MTY2ajBqNKgCALACAA&sourceid=chrome&ie=UTF-8 related to any hitch set up , virtually bombproof , key is picking size you need , might even luck out with metal shop scrap pieces , example my lawn spikers have a 6" channel top frame , for ? WEIGHT TRAY ! https://www.google.com/search?q=channel+steel&rlz=1C1CHBF_enUS866US866&oq=channel+steel+&gs_lcrp=EgZjaHJvbWUyBggAEEUYOdIBCTE3MTY2ajBqNKgCALACAA&sourceid=chrome&ie=UTF-8 , grandson welded this up for me , regularly refer to , HIDING IN PLANE SITE ? do that with everything , pete Share this post Link to post Share on other sites
peter lena 10,065 #6 Posted May 26 @Thor27 sorry about mix up , this what I have been using for many years , also related ball hitch , makes hook ups easier , pete Share this post Link to post Share on other sites
wh315-8 638 #7 Posted May 26 8 hours ago, Thor27 said: I did get my hands on one of these, here are the measurements I didn't have. It does sit farther out than I thought. Thank You, just what I needed 1 Share this post Link to post Share on other sites
