Blaine 276 #351 Posted June 22 I’ll be looking for everything needed to convert my K301 from breakerless to points ignition. Points push rod plunger Original Kohler Part Number: 47 411 04-S (often replacing earlier 47 411 01-S or 47 411 01versions) 0.184 " in diameter and 1.550 " in length according to AI search Coil Plug wire Points Cover and gasket w/screws Condenser Or possibly a good trigger module 1 Share this post Link to post Share on other sites
squonk 48,303 #352 Posted June 22 (edited) 20 minutes ago, Blaine said: I’ll be looking for everything needed to convert my K301 from breakerless to points ignition. Points push rod plunger Original Kohler Part Number: 47 411 04-S (often replacing earlier 47 411 01-S or 47 411 01versions) 0.184 " in diameter and 1.550 " in length according to AI search Coil Plug wire Points Cover and gasket w/screws Condenser Or possibly a good trigger module I can make you a brand new coil wire and have a coil Edited June 22 by squonk 1 Share this post Link to post Share on other sites
Blaine 276 #353 Posted June 22 19 minutes ago, squonk said: I can make you a brand new coil wire and have a coil Thank you. That’s 2 items off the list. Share this post Link to post Share on other sites
Ed Kennell 47,791 #354 Posted June 22 1 hour ago, Blaine said: Cover and gasket w/screws Condenser Check the buckets. Share this post Link to post Share on other sites
702854boy 1,199 #355 Posted June 22 Does anyone know if that guy that makes the chrome stacks is going to the show? Share this post Link to post Share on other sites
Blaine 276 #356 Posted June 22 1 minute ago, Ed Kennell said: Check the buckets. Thanks Ed. Sounds like I’ll need to bring an empty bucket or two to fill up. 2 Share this post Link to post Share on other sites
WHX?? 58,341 #357 Posted June 22 6 minutes ago, 702854boy said: guy that makes the chrome stacks If your talking about Jim Kemp @jimkemp I don't think he does but I bet he would be happy to send you one. Share this post Link to post Share on other sites
702854boy 1,199 #358 Posted June 22 23 minutes ago, WHX?? said: If your talking about Jim Kemp @jimkemp I don't think he does but I bet he would be happy to send you one. Yes, thats the guy I was thinking about, I thought his name was Jim Kemp but I didn't remember for sure and I didn't know what his tag here was, thank you 1 Share this post Link to post Share on other sites
Bow_Extreme 584 #359 Posted June 22 Is anyone bringing a decent single stage tall chute blower to the show that they want to sell? Thank you! Share this post Link to post Share on other sites
Mike'sHorseBarn 3,704 #360 Posted June 22 58 minutes ago, 702854boy said: Does anyone know if that guy that makes the chrome stacks is going to the show? Chad Burris will be at the show with his stacks and he makes nice ones as well. 1 1 Share this post Link to post Share on other sites
WHX?? 58,341 #361 Posted June 22 1 hour ago, 702854boy said: chrome stacks is going to the show? I have one I be willing to sell. PM you pics and price. 3 Share this post Link to post Share on other sites
EthanL 69 #362 Posted June 22 I am looking for a new seat for my tractor. The mounts are already custom so bolt pattern doesn’t really matter. Arm rests would be great but definitely not required. 1 Share this post Link to post Share on other sites
WHX?? 58,341 #363 Posted June 22 39 minutes ago, EthanL said: new seat for my tractor. @76c12091520h usually has some. 3 Share this post Link to post Share on other sites
squonk 48,303 #364 Posted June 22 1 hour ago, WHX?? said: @76c12091520h usually has some. Those seats are excellent, I'm planning on getting another! 1 Share this post Link to post Share on other sites
evanloock 269 #365 Posted June 22 (edited) Will be bringing some 1130 pawl springs to the show for the 1955-early 1957 RJ-35 tractors (later 1957 tractors used a different system without the springs). I bought all that Newby's Implement Supply had left back when they were still around. This is the small spring that goes into the pawl that engages/disengages the pawl from the inside of the hub to allow one wheel to freewheel during a turn using the small dimples case into the hub mounting area. (see pic). These are too small to leave out on a table. Come see me if you want a set of 2 springs for $25 (tractor takes 2 springs; one for each side). Edited June 22 by evanloock 2 Share this post Link to post Share on other sites
cafoose 3,883 #366 Posted June 22 1 hour ago, squonk said: 2 hours ago, WHX?? said: @76c12091520h usually has some. Those seats are excellent, I'm planning on getting another! Share this post Link to post Share on other sites
702854boy 1,199 #367 Posted June 22 (edited) Silvery Wheel Horse rims and 22 7.50 12 tires. Tires hold air and have tons of tread left. Sold. Edited June 23 by 702854boy 1 Share this post Link to post Share on other sites
Sparky-(Admin) 26,644 #368 Posted June 22 49 minutes ago, 702854boy said: For Sale: Silvery Wheel Horse rims and 22 7.50 12 tires. Tires hold air and have tons of tread left. 10 bucks I’ll take them. I get to the show Thursday around 10:30am…leave Saturday afternoon. I’ll message you my cell Share this post Link to post Share on other sites
Pullstart 71,498 #371 Posted June 23 7 minutes ago, Blaine said: Is this bad? it’s not great! At first I thought it was the inside of a Unidrive 5 Share this post Link to post Share on other sites
Blaine 276 #372 Posted June 23 Check the buckets? 3 Share this post Link to post Share on other sites
Pullstart 71,498 #373 Posted June 23 15 minutes ago, Blaine said: Check the buckets? I might have a voltage regulator too. 1 Share this post Link to post Share on other sites
Blaine 276 #374 Posted June 23 5 minutes ago, Pullstart said: I might have a voltage regulator too. I’m starting to worry a bit. Nobody has chimed in with a k301 points push rod plunger and a set of points yet. I may have a correct ignition switch to do the points ignition conversion, and i can rob the points from my k161, but without a push rod, i’ll be going home Thursday with a dead horse. Share this post Link to post Share on other sites
702854boy 1,199 #375 Posted June 23 (edited) @BlaineDo you know how long of a push rod you need? I've got one from a k141 and points and cover and the screws if it would work. I'll upload photos and length in a minute Edited June 23 by 702854boy 1 Share this post Link to post Share on other sites
