EB-80/8inPA 1,981 #1 Posted yesterday at 03:41 PM Gearing up for the winter, I had the C160 running nicely. Having swapped the mechanical fuel pump for an electric, the blower mounted, and everything topped off and lubed, it was running great and I was ready for the big snow a few weeks ago; which is when it refused to start and just leaked fuel from the air filter instead. Plug tested ok for spark, btw, the battery was putting out 11.4 volts, and it turned over. I assumed another carburetor swap was easiest at that point and ordered one from the jungle. I drained the tank, swapped out the isavetractors carb previous replaced, added fresh fuel and turned the key. Still refused to fire and was really spewing the fuel at that point. The new carb came with a plastic pump, and I’m tempted to go ahead and install that, thinking it may be the Cardone(?) pump (which really pumps well, I must say, if you ever need to blow lotsa gas out of the front of a carburetor!). Any thoughts? Hard to believe I could have two faulty floats in a row. What am I missing? What could be causing this? Also, does anybody have a spare screw for the air cleaner bracket and where can you find good quality fuel line that’s flexible and not compounded like PVC plastic? TIA. Share this post Link to post Share on other sites
ebinmaine 77,360 #2 Posted yesterday at 03:47 PM 5 minutes ago, EB-80/8inPA said: thinking it may be the Cardone(?) pump (which really pumps well, I must say, if you ever need to blow lotsa gas out of the front of a carburetor!). Any thoughts? Hard to believe I could have two faulty floats in a row. What am I missing? What could be causing this? It could be the electric pump is too strong. What's the ratings etc on it? It's also VERY LIKELY that you got two carbs with sticking floats. Share this post Link to post Share on other sites
ebinmaine 77,360 #3 Posted yesterday at 03:49 PM 6 minutes ago, EB-80/8inPA said: drained the tank Did you REMOVE and CLEAN the tank? Every inch of fuel line replaced? 1 Share this post Link to post Share on other sites
EB-80/8inPA 1,981 #4 Posted yesterday at 03:55 PM 4 minutes ago, ebinmaine said: Did you REMOVE and CLEAN the tank? Every inch of fuel line replaced? No, but I’ll add that to the list before I tighten everything back up. Are you thinking there’s grit getting past the filter that’s mucking up the carb? 2 Share this post Link to post Share on other sites
EB-80/8inPA 1,981 #5 Posted yesterday at 03:57 PM 8 minutes ago, ebinmaine said: It could be the electric pump is too strong. What's the ratings etc on it? It ran great for a while there. Just refused to work when I needed to blow snow! 1 Share this post Link to post Share on other sites
WHX?? 55,036 #6 Posted yesterday at 04:01 PM 3 minutes ago, ebinmaine said: VERY LIKELY that you got two carbs with sticking floats. Could be I had a NIB one that was stuck but didn't take much to unstick. Prolly got stuck jiggled around in shipping. 12 minutes ago, EB-80/8inPA said: anybody have a spare screw for the air cleaner bracket The ones in front? I may have. 13 minutes ago, EB-80/8inPA said: good quality fuel line that’s flexible I like this. amazon.com/gp/product/B000C34OUM/ref=ox_sc_saved_title_1?smid=ATVPDKIKX0DER&psc=1 3 1 Share this post Link to post Share on other sites
pfrederi 19,909 #7 Posted yesterday at 04:02 PM Most of the electric fuel pumps are available with different pressure ratings... Maybe you got the wrong one. You could add a pressure regulator if you think the pressure is too high and you can crank it down to 1 psi that may not overwhelm your float https://www.amazon.com/Pilida-9710-Fuel-Pressure-Regulator/dp/B092DK7W1G/ref=sr_1_2_sspa 5 2 1 Share this post Link to post Share on other sites
peter lena 9,770 #8 Posted yesterday at 04:22 PM @ebinmaine totally agree on that phase ! often refer to do that since changing over to adding STA BIL to my fuel , from that point on there is NO DEBRIS , OR FULE HOSE BREAK DOWN , IN ANY RELATED FILTERS , only use regular leaded fuel , ounce or two to any tank top off , also my fuel hose check valve just before carb , clear vinyl fuel rated hose , so I am consistently looking at what's in the carb , my generator has the same set up , no fuel hose breakdown , doing this for years , as you know repetitive issues , show you the way , that frame length 5/16 steel brake line, also ELIMINATES a long fuel holding , area , always trying something , pete 1 1 Share this post Link to post Share on other sites
peter lena 9,770 #9 Posted yesterday at 06:22 PM @EB-80/8inPA thanks for the hit ! just about anything I do is based on REPEITIVE FAILURE , do you repair / fix , exactly as was there , or think of a change ? this could apply to ,chafed wiring , linkage issue , bearing noise , belt wear , whatever . that fuel issue used to my problem too , that was years ago , there was a regular trail of rubber break down , STABIL STOPS THAT , then what i did was replace all related hose , dropped carb bowl , clean out added a filter just before carb , and just after leaving tank , which also has to be cleaned out , drop fuel valve , like synthetic grease on the related O rings , makes installation much easier . I only use regular gas , STA BIL corrects rubber break down , my stand by gen , also uses STA BIL , no fuel hose break down at all , filter / bowl always clean clear , instant sarts , 5/16 steel brake line , makes a very good long fuel run inside frame ,upper angle corner , tie wrap it off in place , no fuel hose break down , there ! just talkin , pete 2 Share this post Link to post Share on other sites
ebinmaine 77,360 #10 Posted 22 hours ago 5 hours ago, EB-80/8inPA said: where can you find good quality fuel line that’s flexible and not compounded like PVC plastic? We've switched to using a Briggs and Stratton fuel line. I buy it in 25 foot rolls. It's alcohol compatible (we use E-free gas but others don't) & very supple. 1 Share this post Link to post Share on other sites
EB-80/8inPA 1,981 #11 Posted 21 hours ago 4 hours ago, peter lena said: just about anything I do is based on REPEITIVE FAILURE I know! I’m probably about to fail to fix this danged fuel system one more time yet again! 1 Share this post Link to post Share on other sites
ebinmaine 77,360 #12 Posted 21 hours ago 2 minutes ago, EB-80/8inPA said: I know! I’m probably about to fail to fix this danged fuel system one more time yet again! You’ll succeed just fine if you replace ALL of what's needing to be done. 1 Share this post Link to post Share on other sites
EB-80/8inPA 1,981 #13 Posted 21 hours ago 6 hours ago, pfrederi said: Maybe you got the wrong one. Could be, I got the 5-9psi unit. Share this post Link to post Share on other sites
ebinmaine 77,360 #14 Posted 21 hours ago 4 minutes ago, EB-80/8inPA said: Could be, I got the 5-9psi unit. That's a little too much for a carbureted engine. Especially a smaller size. 1 to 4 PSI is the standard. 5 1 Share this post Link to post Share on other sites
EB-80/8inPA 1,981 #15 Posted 21 hours ago (edited) 3 minutes ago, ebinmaine said: That's a little too much for a carbureted engine. Especially a smaller size. 1 to 4 PSI is the standard. But I can win in a gas pissing contest, so there’s that! I think I found my new transfer pump. Edited 20 hours ago by EB-80/8inPA 1 4 Share this post Link to post Share on other sites
oldlineman 1,653 #16 Posted 4 hours ago Ya thats too much pressure,it is overcoming the float valve I believe. 1 Share this post Link to post Share on other sites
peter lena 9,770 #17 Posted 3 hours ago @EB-80/8inPA my carbole electric pumps are 2-3.5 psi , no issues , pete 2 Share this post Link to post Share on other sites
kwalshy 242 #18 Posted 1 hour ago 19 hours ago, EB-80/8inPA said: Could be, I got the 5-9psi unit. right there's your smoking gun, pressure is too high. Share this post Link to post Share on other sites
