Retired Wrencher
What do you use!
Retired Wrencher
i’m looking for some information on how to remove overspray paint. It looks like somebody wanted to paint the hood a different color. It’s not the whole hood, but it’s in the front. Especially on the decal on the hood. I’ve heard something about citrus that may work. Any thoughts are welcome
Retired Wrencher
953 nut
Posted (edited)
If it is overspray clay bar will get the job done. If it is lightly painted use Goof off
Edited by 953 nut
  • Like 4
Achto
How much over spray are we talikin' about?
Charcoal lighter fluid some times works to get some heavier over spray off. Always try a test spot to make sure it don't take the original paint off. Usually pretty safe though.
Safest bet would be a clay bar. Not the easiest, it's gonna take some elbow grease. Use with water & keep kneading the clay bar as it plugs up with paint.
One source for a clay bar kit. There are many options out there though.
https://www.walmart.com/ip/Meguiar-s-Smooth-Surface-Clay-Kit-Safe-and-Easy-Car-Claying-for-a-smooth-as-Glass-Finish-G191700/279897515
702854boy
If you feel like spending a fortune I've found that brake clean works good at removing new spray paint over old, just don't let it sit too long and you'll be fine. Also make sure to do it outside or you might get a little loopy.
rmaynard
Regular compound (not polishing) will work.
Retired Wrencher
Ok Achto I will look into that. What about decals? The front decal has splatters like some one was using it for a table.
Retired Wrencher
Thanks Bob.
Retired Wrencher
Thanks Richard.
