Retired Wrencher 7,043 #1 Posted March 1 i’m looking for some information on how to remove overspray paint. It looks like somebody wanted to paint the hood a different color. It’s not the whole hood, but it’s in the front. Especially on the decal on the hood. I’ve heard something about citrus that may work. Any thoughts are welcome 1 Share this post Link to post Share on other sites
Retired Wrencher 7,043 #2 Posted March 1 i’m looking for some information on how to remove overspray paint. It looks like somebody wanted to paint the hood a different color. It’s not the whole hood, but it’s in the front. Especially on the decal on the hood. I’ve heard something about citrus that may work. Any thoughts are welcome Share this post Link to post Share on other sites
953 nut 70,649 #3 Posted March 1 (edited) If it is overspray clay bar will get the job done. If it is lightly painted use Goof off Edited March 1 by 953 nut 4 Share this post Link to post Share on other sites
Achto 32,963 #4 Posted March 1 How much over spray are we talikin' about? Charcoal lighter fluid some times works to get some heavier over spray off. Always try a test spot to make sure it don't take the original paint off. Usually pretty safe though. Safest bet would be a clay bar. Not the easiest, it's gonna take some elbow grease. Use with water & keep kneading the clay bar as it plugs up with paint. One source for a clay bar kit. There are many options out there though. https://www.walmart.com/ip/Meguiar-s-Smooth-Surface-Clay-Kit-Safe-and-Easy-Car-Claying-for-a-smooth-as-Glass-Finish-G191700/279897515 3 Share this post Link to post Share on other sites
702854boy 1,245 #5 Posted March 1 If you feel like spending a fortune I've found that brake clean works good at removing new spray paint over old, just don't let it sit too long and you'll be fine. Also make sure to do it outside or you might get a little loopy. 1 Share this post Link to post Share on other sites
rmaynard 17,659 #6 Posted March 1 Regular compound (not polishing) will work. 1 Share this post Link to post Share on other sites
Retired Wrencher 7,043 #7 Posted March 1 7 hours ago, Achto said: How much over spray are we talikin' about? Charcoal lighter fluid some times works to get some heavier over spray off. Always try a test spot to make sure it don't take the original paint off. Usually pretty safe though. Safest bet would be a clay bar. Not the easiest, it's gonna take some elbow grease. Use with water & keep kneading the clay bar as it plugs up with paint. One source for a clay bar kit. There are many options out there though. https://www.walmart.com/ip/Meguiar-s-Smooth-Surface-Clay-Kit-Safe-and-Easy-Car-Claying-for-a-smooth-as-Glass-Finish-G191700/279897515 Ok Achto I will look into that. What about decals? The front decal has splatters like some one was using it for a table. Share this post Link to post Share on other sites
Retired Wrencher 7,043 #8 Posted March 1 4 hours ago, rmaynard said: Regular compound (not polishing) will work. Thanks Bob. Share this post Link to post Share on other sites
Retired Wrencher 7,043 #9 Posted March 1 7 hours ago, 953 nut said: If it is overspray clay bar will get the job done. If it is lightly painted use Goof off Thanks Richard. Share this post Link to post Share on other sites
