Ed Kennell 46,792 #26 Posted March 1 15 minutes ago, lynnmor said: inspect or replace with a better design Will do..thanks. I did have to retorque the pump mounting bolts that vibrated loose after many years of use. Most of my wood is from 5+ year old dead trees so they are dry when I cut them. If I do get a live green blow down, I do split smaller to speed drying. 1 Share this post Link to post Share on other sites
Ed Kennell 46,792 #27 Posted March 1 I just took a closer look at the 2 way design. With the splitter wedge cantilevered 6-10 inches above the cylinder, seems there has to be some large loads on the splitter slide system. Do we know what it uses for bearings to take these loads? 1 Share this post Link to post Share on other sites
WHX?? 57,628 #28 Posted March 1 30 minutes ago, lynnmor said: yes I use a moisture meter. Yer nuts and a waste of time. Gramps didn't have one and he hand split way before us. A veteran wood stoker can tell the dryness by end fractures and time under a COVERED stack. Different for brand of species ... hardwood softwood etc. Heck burn green pine you like to clean chimneys. What brought this on Big Unit? Weren't you the guy just looking for better cycle times on what you have? 1 Share this post Link to post Share on other sites
Ed Kennell 46,792 #29 Posted March 1 10 hours ago, cafoose said: Thinking it could be used as a press with the right adapters? You got the wheels turning Chuck. 2 1 Share this post Link to post Share on other sites
cafoose 3,785 #30 Posted March 1 1 minute ago, Ed Kennell said: You got the wheels turning Chuck. Be sure to let us know how you do it 2 1 Share this post Link to post Share on other sites
WHX?? 57,628 #31 Posted March 1 Do sound like Pullstart now 'foose 1 1 Share this post Link to post Share on other sites
ebinmaine 80,067 #32 Posted March 1 14 hours ago, Wayne0 said: Looks pretty good, Eric. A bit pricey, especially with the 4 way wedge. I'm not sure about the 2 way splitting. TSC or HF seams to be a better value. Add a 4 way from the jungle for reasonable $. My $.02 We haven't had the greatest experiences with TSC or HF but to save a few hundred dollars it's worth a look. I dont see a TSC that's dual action though. The HF would be about $1130 but has one SERIOUS downfall in that it is NOT certified for road towing. And neither of us is a predator fan... The one Trina's looking at can be had for just under $1700 delivered and has a KOHLER engine. Is the extra $570 worth it? I dunno. On that 4 way wedge, if you can share a link for a direct fit I'd be interested. Share this post Link to post Share on other sites
ebinmaine 80,067 #33 Posted March 1 9 hours ago, WHX?? said: What brought this on Big Unit? Weren't you the guy just looking for better cycle times on what you have? Absolutely. The FRAME of the existing unit is still good. However the rest of the entire system would have to be replaced. Engine. Pump. Valves. Hoses. Cylinder. Not an equal comparison. Share this post Link to post Share on other sites
ebinmaine 80,067 #34 Posted March 1 10 hours ago, Ed Kennell said: I just took a closer look at the 2 way design. With the splitter wedge cantilevered 6-10 inches above the cylinder, seems there has to be some large loads on the splitter slide system. Do we know what it uses for bearings to take these loads? Not yet. Excellent point and one we'd answer before purchase. Share this post Link to post Share on other sites
Wayne0 1,605 #35 Posted March 1 (edited) 1 hour ago, ebinmaine said: On that 4 way wedge, if you can share a link for a direct fit I'd be interested. https://www.amazon.com/s?k=4+way+splitter+wedge&crid=63KGAM25FB01&sprefix=4+way+splitter%2Caps%2C155&ref=nb_sb_ss_p13n-expert-pd-ops-ranker_2_14 Edited March 1 by Wayne0 1 Share this post Link to post Share on other sites
ebinmaine 80,067 #36 Posted March 1 @Wayne0 That's what Boss sells too. The link leads me to a bunch of different types that are all more expensive than the $130 add on though. Share this post Link to post Share on other sites
ebinmaine 80,067 #37 Posted March 1 The biggest game changer differences I can find between the HF and the Boss model are the frame construction and the engines. There are a few mentions of the HF having a bit of a weak beam structure. Share this post Link to post Share on other sites
Ed Kennell 46,792 #38 Posted March 1 (edited) An up grade for yours Eric? That would keep Trina and Mother busy. Facebook Edited March 1 by Ed Kennell 1 1 Share this post Link to post Share on other sites
ebinmaine 80,067 #39 Posted March 1 25 minutes ago, Ed Kennell said: up grade That would be AWESOME..... other than maybe a missing digit here n there. Share this post Link to post Share on other sites
wallfish 20,375 #40 Posted March 1 15 minutes ago, Ed Kennell said: An up grade for yours Eric? Facebook Kind of a cool set up because it can be operated by either one or two people. I have an old gearbox that was used for a huge conveyor thingy that's built like a tank and could handle something like that. 1 Share this post Link to post Share on other sites
Wayne0 1,605 #41 Posted March 1 7 hours ago, ebinmaine said: @Wayne0 That's what Boss sells too. The link leads me to a bunch of different types that are all more expensive than the $130 add on though. I bought that wedge so long ago I forgot what I paid. Boss seams to be a better deal. 1 Share this post Link to post Share on other sites
ebinmaine 80,067 #42 Posted March 1 Here's a screenshot Trina created on her PC. This shows the overall structural rigidity and ergonomic setup of both machines so you can see why she prefers the Boss model. Of note: The control lever of the Boss is in the center. The Predator has a one sided operation setup. Being able to operate a machine from either side is a HUGE consideration. See the standing structure of each machine. There are several pivot points on the Predator that don't exist on the Boss. Those are areas of concern because of additional wear & tear along with overall stability during operation. 2 Share this post Link to post Share on other sites
Darb1964 1,174 #43 Posted March 1 35 minutes ago, ebinmaine said: Here's a screenshot Trina created on her PC. This shows the overall structural rigidity and ergonomic setup of both machines so you can see why she prefers the Boss model. Of note: The control lever of the Boss is in the center. The Predator has a one sided operation setup. Being able to operate a machine from either side is a HUGE consideration. See the standing structure of each machine. There are several pivot points on the Predator that don't exist on the Boss. Those are areas of concern because of additional wear & tear along with overall stability during operation. The Boss looks a lot like my old Mackinaw splitter. 1 Share this post Link to post Share on other sites
ebinmaine 80,067 #44 Posted March 1 Just now, Darb1964 said: my old Mackinaw splitter. Was that a dual action setup? 1 Share this post Link to post Share on other sites
Ed Kennell 46,792 #45 Posted March 1 1 hour ago, wallfish said: I have an old gearbox I'll watch this build. 2 Share this post Link to post Share on other sites
Darb1964 1,174 #46 Posted March 1 Just now, ebinmaine said: Was that a dual action setup? It automatically goes back after full cycle. It's not capable of splitting upright, it don't have the wedge on the piston. The wedge needs to be on the piston in order to split both ways. When I had very big rounds I would lower the front kickstand. I got it used thirty plus years ago.. I would guess it was at least ten years old then. Hope that helps. It never failed me. 1 Share this post Link to post Share on other sites
Wayne0 1,605 #47 Posted March 1 The only thing I have an issue with is, the piston is under the wedge, not behind it. Looks like a weak point to me. I guess you couldn't have a 2 way that way. Might work out fine. The proof is in the pudding. 2 Share this post Link to post Share on other sites
ebinmaine 80,067 #48 Posted March 1 10 minutes ago, Wayne0 said: The only thing I have an issue with is, the piston is under the wedge, not behind it. Looks like a weak point to me. I guess you couldn't have a 2 way that way. Might work out fine. The proof is in the pudding. We've had the same thought. I'm curious to know if or how Boss compensates for that. Share this post Link to post Share on other sites
ebinmaine 80,067 #49 Posted April 19 As you can see here we got the Boss Industrial splitter delivered here a few days ago. I'll be doing a write-up on it soon. 1 Share this post Link to post Share on other sites
