WHX?? 54,931 #1 Posted 5 hours ago Well maybe not quite free but dang cheap. No offense Lowell but they can get somewhat pricey when one has more than one tractor. No idea if this will work but won't be for lack of tryin. Hardware store cable with a blob of braze on the end. 3 Share this post Link to post Share on other sites
c-series don 11,363 #2 Posted 5 hours ago I’m really curious to see if that works!👍🏻 1 Share this post Link to post Share on other sites
WHX?? 54,931 #3 Posted 5 hours ago (edited) Here's one that will get the real test. Off the 1054 that broke when I was installing The @Pullstart's new drainage ditch. Brand new and again if Lowell was just down the road I know he'd give me a new one. For those who don't know about the weight of a long beam 953/1054 plow the cable sees humongous stress. This is why not having an extra on the plow field can put you out of action for the day. Edited 5 hours ago by WHX?? 3 Share this post Link to post Share on other sites
Handy Don 15,928 #4 Posted 5 hours ago It’ll be up to the cable strength where the heat of the braze might have affected its temper and how well the braze penetrated into the braid for adhesion. Frankly, I’m glad someone is giving this a try! Good luck 🤞 👍 😀 1 1 Share this post Link to post Share on other sites
WHX?? 54,931 #5 Posted 5 hours ago 2 minutes ago, Handy Don said: heat of the braze might have affected its temper and how well the braze penetrated into the braid f One thing that might affect it ... temper temper ... but flowed in the braid like water. As they say nothing ventured nothing gained. 3 1 Share this post Link to post Share on other sites
Pullstart 68,870 #6 Posted 4 hours ago If the women don’t find you handsome, they should at least find you handy! 1 4 Share this post Link to post Share on other sites
squonk 45,498 #7 Posted 4 hours ago Make sure you drive it across your "yard " at high speed in transport mode. 4 1 Share this post Link to post Share on other sites
adsm08 4,192 #8 Posted 4 hours ago 34 minutes ago, Pullstart said: If the women don’t find you handsome, they should at least find you handy! They find me handsy. Is that close enough? 3 Share this post Link to post Share on other sites
John2189 562 #9 Posted 4 hours ago They sell crimp on ends for cable. 1 Share this post Link to post Share on other sites
ri702bill 11,251 #10 Posted 4 hours ago 1 hour ago, WHX?? said: Well maybe not quite free but dang cheap. No offense Lowell but they can get somewhat pricey when one has more than one tractor. No idea if this will work but won't be for lack of tryin. Hardware store cable with a blob of braze on the end. Do they come with the exclusive "Tail light Warranty"?? It excludes everything!! 1 Share this post Link to post Share on other sites
ineedanother 1,867 #11 Posted 3 hours ago We have a 20 ton press at work and I've considered crimping these a try. https://www.uscargocontrol.com/collections/single-shank-ball-swage-stainless-steel-t316 I've also considered running parallel lift cables but the only thing I lift is a tiller which just hasn't motivated me enough yet... 2 Share this post Link to post Share on other sites
Pullstart 68,870 #12 Posted 2 hours ago 1 hour ago, John2189 said: They sell crimp on ends for cable. its astounding the pressure these cables must hold up to.i’m not saying that wouldn’t work, but that might not work. Share this post Link to post Share on other sites
AlexR 2,576 #13 Posted 2 hours ago Another option is this brake cable from napa around $20 and you can get 2 cables out of it, by cutting it in half. It's handled everything I have thrown at it. Or since this is for around a 2004 Chevy crew cab long bed brake cable you can get it for free by cutting it out of @Pullstart's truck 2 Share this post Link to post Share on other sites
WHX?? 54,931 #14 Posted 2 hours ago (edited) 2 hours ago, squonk said: Make sure you drive it across Kevin's "yard " at high speed in transport mode. There fixed that for ya. 1 hour ago, John2189 said: They sell crimp on ends for cable. Yep thought of that and had one in my grubby mitts but I couldn't get enough crimp on it. 59 minutes ago, ineedanother said: I've considered crimping these a try I'm sure that's what Lowell uses and if a guy could make a die for his HF press. 13 minutes ago, AlexR said: brake cable from napa Does that come with the plastic coating on it? I like that ...smooth operation greasy Pete approved. What did you use for the crimp? Edited 2 hours ago by WHX?? Share this post Link to post Share on other sites
ineedanother 1,867 #15 Posted 2 hours ago 6 minutes ago, WHX?? said: I'm sure that's what Lowell uses and if a guy could make a die for his HF press. Exactly my thought. My hydraulic hand crimper has carbon steel inserts but I suspect I could crush them in my floor press. 1 Share this post Link to post Share on other sites
AlexR 2,576 #16 Posted 2 hours ago 13 minutes ago, WHX?? said: Does that come with the plastic coating on it? I like that ...smooth operation greasy Pete approved. What did you use for the crimp? Yes it does come with the coating on it, No need to crimp, both ends are already factory crimped the same. All you have to do is cut in little less then half and cable clamp the other end at the lift lever. (Not completely sure on the length needed for some of those other tractors like your 1054 may only be able to do one) 1 Share this post Link to post Share on other sites
