WHX??
Free Lift Cables
WHX??
Well maybe not quite free but dang cheap.
No offense Lowell  but they can get somewhat pricey when one has more than one tractor.
No idea if this will work but won't be for lack of tryin.
Hardware store cable with a blob of braze on the end.
  • Like 6
c-series don
I’m really curious to see if that works!👍🏻
WHX??
Here's one that will get the real test. Off the 1054 that broke when I was installing The @Pullstart's new drainage ditch. :lol:
Brand new and again if Lowell was just down the road I know he'd give me a new one.
For those who don't know about the weight of a long beam 953/1054 plow the cable sees humongous stress.
This is why not having an extra on the plow field can put you out of action for the day.
Edited by WHX??
  • Like 4
Handy Don
It’ll be up to the cable strength where the heat of the braze might have affected its temper and how well the braze penetrated into the braid for adhesion.
Frankly, I’m glad someone is giving this a try! Good luck 🤞 👍 😀
WHX??
One thing that might affect it ... temper temper :angry-nono:... but flowed in the braid like water.
As they say nothing ventured nothing gained.
  • Like 4
squonk
Make sure you drive it across your "yard " at high speed in transport mode. :lol:
  • Like 5
  • Haha 2
adsm08
34 minutes ago, Pullstart said:
If the women don’t find you handsome, they should at least find you handy!
They find me handsy. Is that close enough?
  • Haha 6
John2189
They sell crimp on ends for cable.
ri702bill
Do they come with the exclusive "Tail light Warranty"?? It excludes everything!! :ROTF:
  • Haha 2
ineedanother
We have a 20 ton press at work and I've considered crimping these a try. https://www.uscargocontrol.com/collections/single-shank-ball-swage-stainless-steel-t316
I've also considered running parallel lift cables but the only thing I lift is a tiller which just hasn't motivated me enough yet...
Pullstart
its astounding the pressure these cables must hold up to.i’m not saying that wouldn’t work, but that might not work.
AlexR
Another option is this brake cable from napa around $20 and you can get 2 cables out of it, by cutting it in half. It's handled everything I have thrown at it.
Or since this is for around a 2004 Chevy crew cab brake cable you can get it for free by cutting it out of @Pullstart's truck :ROTF:
IMG_20251210_151715503_HDR.thumb.jpg.97c9e2310fca658396649f3e14d44a2a.jpgIMG_20251210_163136124_HDR.jpg.854c40d0179c446e8ac6e5daf9261407.jpgIMG_20251210_152714614_HDR.thumb.jpg.995e188d2313f7137e8b6872a7878e40.jpg
Edited by AlexR
  • Like 6
  • Heart 1
WHX??
2 hours ago, squonk said:
Make sure you drive it across Kevin's "yard " at high speed in transport mode. :lol:
There fixed that for ya.
Yep thought of that and had one in my grubby mitts but I couldn't get enough crimp on it.
I'm sure that's what Lowell uses and if a guy could make a die for his HF press. :eusa-think:
Does that come with the plastic coating on it? I like that ...smooth operation greasy Pete approved. What did you use for the crimp?
Edited by WHX??
ineedanother
Exactly my thought. My hydraulic hand crimper has carbon steel inserts but I suspect I could crush them in my floor press.
AlexR
Yes it does come with the coating on it,
No need to crimp, both ends are already factory crimped the same. All you have to do is cut in little less then half and cable clamp the other end at the lift lever. (Not completely sure on the length needed for some of those other tractors like your 1054 may only be able to do one)
kpinnc
4 hours ago, AlexR said:
Deleted
Edited by kpinnc
Retired Wrencher
Kev that is and old saying that still works today.
953 nut
The first home-made lift cable with a big glob of braze I made up didn't last very long, broke right near the braze.
I cut "V" notches in a couple pieces of scrap steel to make a die. They were a PITA to align but got the job done.
Handy Don
7 hours ago, JoeM said:
I tried this contraption a few years ago, worked pretty good.
Interesting since this appears to double the amount of cable pull for a given amount of lift lever movement. What effect did that have on the implements being lifted?
JoeM
Successful, I never calculated the total advantage, but the load was manageable. I used components that fit.
the whole idea was born from an extra heavy box scraper. thinking with the manual lift It was less work to raise the heavy load.
I later went to a hydro and the issue was null.
I suppose the concept would work, say a given load like a tiller, could be lifted with a lot less effort using the sheave, while reducing the stress on the connection, just from an mechanical advantage??
8ntruck
Drawback, though.  This setup will also double the force required to lift the implement.
WHX??
I'm lost Truck ... I would think it would greatly decrease the force required? Kinda like a $natch block for a winch.
No matter Joe that's using the old noggin for other than a hat rack. :thumbs2:
What I'm afraid of Richard. Oh well it's a experiment.
Edited by WHX??
ACman
We have about everything you needed to keep your farm up and running . We made custom hydraulic hoses, roller chain, spreader/elevator chain, spark, plug wires, battery cables, plus much more, including cables. Have any old farm stores , hardware store or dealerships nearby that might have a hydraulic crimper . Now days all the large farms around us have all this equipment and supplies in their shops . Our local NAPA has ability to make most of these items nowadays. I’m just throwing stuff out there Jim as I’m sure you have racked your brain thinking of solutions .
