horseman with no horse 72 #1 Posted February 26 can you hone the bores on a ch18s? im not sure if its got a cast iron liner or nickisil Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,557 #2 Posted February 26 I do not know either but here are some manuals https://www.wheelhorseforum.com/search/?q=ch18&quick=1&type=downloads_file 1 1 Share this post Link to post Share on other sites
Wild Bill 633 943 #3 Posted February 26 (edited) 9 hours ago, horseman with no horse said: can you hone the bores on a ch18s? im not sure if its got a cast iron liner or nickisil Yes. On my Hot Rod Kohler Command, I had to have the cylinders honed a little bit to provide additional piston to cylinder clearance for forged pistons. OEM pistons are cast. Forged pistons are made of low silicon 2618 material for high tensile strength and ductility. The OEM cast pistons are high silicon 4032 material and has lower thermal expansion, thus run less piston to cylinder clearance. Edited February 26 by Wild Bill 633 1 1 Share this post Link to post Share on other sites
horseman with no horse 72 #4 Posted February 26 thank you so muchhhh 1 Share this post Link to post Share on other sites
