kpinnc
M8 governor sticking
kpinnc
Got a question for the Kohler gurus...
Don @Lee1977 bought a 308-8 last year, and it had what seemed to be a governor issue. I had the engine over the holidays because we thought it would be a simple fix. I found the spark plug wire was in the way of the governor, and I pulled the pan just to visually check for anything broken just in case. The flyweights were there, and the governor rod and tab were all in place and moved free, so I didn't dissasemble anything further. This engine has very low hours and I wanted to avoid removing the piston and cam if it wasn't necessary.
Today Don cranked it up, and even with the throttle all the way down it runs wide open. I pulled the governor over towards the carb and it has a "catch", meaning if you put a decent amount of pressure against it, it clicks past the catch and throttles down. This only happens when running and everything is smooth and free when not running. Nothing external is binding the governor or throttle.
Anybody ever seen this before? I think the governor is bad somehow, but it's so simple that I can't imagine how. When I had the pan off, rotating the engine was enough to make the flyweights move. It just doesn't make sense to me.
Don thinks this tractor sat in the dealer shop for a while, and I knew the PO. He rarely used it, and was always running down closed dealerships to find stuff. We're wondering if it always had issues with the governor because the fully functional hour meter shows around 35 hours on it. I will say that visually, the cleanliness of the inside of the engine certainly implies the hours are accurate. No sludge in the pan at all. Gears are all sharp and nothing has any play like an old engine with years of service on it. It looks brand new.
Anyway, has anyone ever seen a Kohler governor behave like this?
Edited by kpinnc
Achto
It sounds like the governor arm has moved on the shaft to me. Try re adjusting the governor arm.
Loosen the pinch bolt on the governor arm, turn the gov shaft counter clock wise until it stops, Move the gov arm to hold the throttle wide open, hold everything in this position and tighten the pinch bolt.
Pg. 6A.12 - 6A.13
https://resources.kohler.com/power/kohler/enginesUS/pdf/tp_2203_a.pdf
Edited by Achto
  • Excellent 2
wallfish
:text-yeahthat:
And or could that shaft be spinning in the arm even though it "appears" tight. Hold the arm steady and try twisting that shaft with pliers. If it moves there's the problem
kpinnc
I set the arm with the "static" procedure in the manual, but Don might have found the problem. The arm was back against the bushing pretty tight. I might have had the whole thing too tight previously.
Lee1977
It's set up simular to a K-91 the wheel. and spring on the shaft.. Runs one fixed rpm no matter where the throttle is set.  I changed the throttle cable to put more tention on the spring .
Didn't make any difference with the throttle might be running a little slower.
Achto
Does the shaft come to a positive stop when you rotate it counter clock wise? just wondering if the flag on the inside is dammaged.
sqrlgtr
The PO of an 857 I got had ran throttle cable directly to the carb butterfly, bypassing governor. When I finally got around to fixing it I had to take bushing and throttle arm off and dress them up because it was putting everything in a bind and would stick if you tightened bushing up to where it was supposed to be. If Iran bushing loose enough to work, it would work its way loose. Works great now and was probably reason PO had moved it:D.
