Larry Chamberlain 29 #1 Posted February 24 Do they make a delte plate for the fuel pump im putting a electric one on my 417 a narrowed it down to the fuel pump but im not sure that my love might to wore for the pump to work so I said screw it putting a electric in it will be here to marrow with a check valve 1 Share this post Link to post Share on other sites
wallfish 20,375 #2 Posted February 24 I just cut the lines and install the electric pumps and leave the old pumps in place. The only issue could be if the diaphragm has a hole it could pump gas into the crank case. 2 Share this post Link to post Share on other sites
squonk 47,704 #3 Posted February 24 6 minutes ago, wallfish said: I just cut the lines and install the electric pumps and leave the old pumps in place. The only issue could be if the diaphragm has a hole it could pump gas into the crank case. Leave the pump in place and run the hose around it. 4 1 Share this post Link to post Share on other sites
ineedanother 2,768 #4 Posted February 24 Lots out in the jungle but they're nothing special if you just want to make one. https://www.sepw.com/parts/tl-119-3337-pod-lh/?srsltid=AfmBOoo-_j8wS5DgdARGb59cHJ1qtkMQ_6od1IO5soVcfNcj1GwUBJrZsog 3 Share this post Link to post Share on other sites
